Fergus Kyle
Joined: 03 Jun 2007 Posts: 291 Location: Burlington ON Canada
Posted: Sat May 21, 2011 6:54 am Post subject: Oil filter removal 914 |
OK, I’m slow – but what did you use to remove the installed oil filter on your 914? It’s ti-ight.
It’s been on for some time and I had a proper strap wrench but cannot find it – and, apparently nobody makes cloth strap wrenches in my part of spaceship Earth* any more. They’re all made of rubber bands which snap at first try......
Your creative solutions most humbly accepted.
Ferg
*Burlington ON Canada [quote][b]
| - The Matronics RotaxEngines-List Email Forum - | | Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
Ivor Phillips
Posted: Sat May 21, 2011 8:35 am Post subject: Oil filter removal 914 |
I use a large adjustable Pipe wrench placed just were the filter meets the block, with the lower cowling removed,
A old but messy solution assuming you don't want to check the filter element for metal particles is to drive
a long screwdriver through the filter and use the extra leverage it gives you, Keep a lid of a biscuit tin
under the filter to catch the old oil,
regards
ivor
G-IVER
On 21 May 2011 15:51, Fergus Kyle <VE3LVO(at)rac.ca (VE3LVO(at)rac.ca)> wrote:
Ferg
*Burlington ON Canada Quote: |
ist" target="_blank">http://www.matronics.com/Navigator?RotaxEngines-List
ttp://forums.matronics.com
Posted: Sat May 21, 2011 8:41 am Post subject: Oil filter removal 914 |
If you can get your hand on it, but can't grip tightly enough to keep from slipping, try wrapping it with sandpaper- grit side in. It often works.
Bill Sullivan
--- On Sat, 5/21/11, PHILLIPS I <ivor.phillips(at)ntlworld.com> wrote:
Quote: |
Subject: Re: Oil filter removal 914
Date: Saturday, May 21, 2011, 12:31 PM
regards
ivor
G-IVER
Ferg
ist" target=_blank rel=nofollow>http://www.matronics.com/Navigator?RotaxEngines-List
| [quote][b]
Fergus Kyle
Posted: Sat May 21, 2011 9:39 am Post subject: Oil filter removal 914 |
William and Ivor,
Thank you both for rapid weekend replies....
Fact is, after a week of searching the hawkers, I tripped over my afore-mentioned cloth strap wrench, applied same and after some invective managed a grudging move – so I’m OK Jack. But it was not without some wrangling and am thankful for your solutions. These may come in handy later.
The thing is – I have not replenished the oil for a couplke of years – it has been in the spare bedroom and dry – and I want to remove the filter only to replenish the unused oil, so filter destruction not wanted.
I now turn my attention to filling the oil according to the Rotax persuasion and discover I have badly sited various components unknowingly frustrating the ucoupling of hoses in the 914’s dark interior spaces. Nothing seems easy.
Cheers, and I owe you
Ferg
PS: It appears I owe so many of the hops variety I’ll have to come over for the Christmas dinner to comply with glib promises. [quote][b]
Posted: Sat May 21, 2011 1:06 pm Post subject: Oil filter removal 914 |
Ferg
you should come to the Christmas Dinner, good place to see all your old frineds!
Graham
To: 1ROTAXnet <rotaxengines-list(at)matronics.com>
Sent: Saturday, 21 May, 2011 18:37:11
Subject: RotaxEngines-List: Oil filter removal 914
William and Ivor,
Ferg
lank" href="http://www.matronics.com/Navigator?RotaxEngines-List">http://t; http://www.matronics.com/contrib===============
pchristensen10(at)austin. Guest
Posted: Sun May 22, 2011 8:28 am Post subject: Oil filter removal 914 |
On my Kitfox I put a big hose clamp around the filter and use a long screw driver and a hammer to twist the filter off banging on the clamp screw mechanism.
Pete
On 5/21/2011 11:38 AM, william sullivan wrote: [quote]  If you can get your hand on it, but can't grip tightly enough to keep from slipping, try wrapping it with sandpaper- grit side in. It often works.
Â
                                           Bill Sullivan
                                         Â
--- On Sat, 5/21/11, PHILLIPS I <ivor.phillips(at)ntlworld.com> (ivor.phillips(at)ntlworld.com) wrote:
Quote: |
From: PHILLIPS I <ivor.phillips(at)ntlworld.com> (ivor.phillips(at)ntlworld.com)
To: rotaxengines-list(at)matronics.com (rotaxengines-list(at)matronics.com)
regards
ivor
G-IVER
       It’s been on for some time and I had a proper strap wrench but cannot find it – and, apparently nobody makes cloth strap wrenches in my part of spaceship Earth* any more. They’re all made of rubber bands which snap at first try...... |
Ferg
| [b]
rickofudall
![](images/avatars/6819866474ce9fe39455d6.jpg)
Posted: Sun May 22, 2011 9:45 am Post subject: Oil filter removal 914 |
If you have the room between the #2 exhaust pipe and the filter you might give these a try.
http://www.harborfreight.com/automotive-motorcycle/engine/4-piece-end-cap-oil-filter-wrenches-94096.html
[/url]I haven't used them on a 914, but I haven't found a car filter yet that can't be removed with one of the four.
For what it's worth
Rick Girard
On Sun, May 22, 2011 at 11:25 AM, Pete Christensen <pchristensen10(at)austin.rr.com (pchristensen10(at)austin.rr.com)> wrote:
Quote: | On my Kitfox I put a big hose clamp around the filter and use a long screw driver and a hammer to twist the filter off banging on the clamp screw mechanism.
Pete
On 5/21/2011 11:38 AM, william sullivan wrote: Quote: | If you can get your hand on it, but can't grip tightly enough to keep from slipping, try wrapping it with sandpaper- grit side in. It often works.
Bill Sullivan
regards
ivor
G-IVER
On 21 May 2011 15:51, Fergus Kyle <[url=http://us.mc839.mail.yahoo.com/mc/compose?to=VE3LVO(at)rac.ca]VE3LVO(at)rac.ca> wrote:
Ferg
Zulu Delta
Mk IIIC
Thanks, Homer GBYM
It isn't necessary to have relatives in Kansas City in order to be unhappy.
- Groucho Marx
Fergus Kyle
Posted: Mon May 23, 2011 8:15 am Post subject: Oil filter removal 914 |
Richard Girard and Pete Christensen,
Thank you both for replying. I had given up on the commercial strap wrenches offered locally and panicked. Fortunately I stumbled across my original wrench (when I stopped searching) and went for something else. It is a proper cloth strap job and it dented the skin of the filter but it lifted it.
I’ll keep your suggestions for future use, and thanks again.
Ferg
oil all over the place [quote][b]
