		david.hunter68(at)btinter Guest
				 Posted: Thu Jan 12, 2006 11:36 am    Post subject: NSI EA81 Engines. |
				I am in need of help with an NSI EA81 engine following the upheaval of NSI. The new company no longer supports these engines and my aircraft is due to be completed fairly soon. Problem is I have no Vacuum pump drive and the company cannot supply. Has anyone got a  pump drive or knows of one anywhere that I could buy? A used one would be fine and I have a new housing so even one with a damaged housing would be useful, or just a serviceable shaft and gear. I could also use a spare isolator unit for the ignition. Any information would be gratefully received.
   I am on email at david.hunter68(at)btinternet.com or phone +44 (0)1666 503330 ( England)
		ami(at)mcfadyean.freeserv Guest
				 Posted: Thu Jan 12, 2006 1:03 pm    Post subject: NSI EA81 Engines. |
				Dave,
 I can't help you with this one.
 In passing, Richard Mole was looking for a discarded monowheel outrigger
 (nylon 'stalk', wheel and carrier).
 Have you got any lying around from TD/Tri gear conversions?
 Best Regards,
 Duncan.
		acrojim(at)cfl.rr.com Guest
				 Posted: Thu Jan 12, 2006 2:15 pm    Post subject: NSI EA81 Engines. |
				David
 Try this link to Jan Eggenfellner. He has been doing Subaru Engine Conversions for a long time here in Florida. He should be able to help you...
 Jim Brown
 http://www.eggenfellneraircraft.com/
 DAVID HUNTER wrote:
