mp.gamble(at)talktalk.net Guest
Posted: Tue May 10, 2011 8:41 am Post subject: rudder pedal adjustment |
Re sent due bounce--
Sent: 16 April 2011 21:37
Subject: rudder pedal adjustment
How do we adjust the rudder pedals for short ar—s like myself after aircraft completion? The manual suggests cable shortening using home made triangular 3 bolt clamps in the rear fuse but these would bounce around the fuselage bottom of the XS with the extended tail wheel. So far I have been using cushions to adjust the body. What are others doing?
XS mono
G-CFMP
kevinmarie(at)blueyonder. Guest
Posted: Tue May 10, 2011 9:45 am Post subject: rudder pedal adjustment |
I am 5' 8" and the standard set up is fine. I know someone shorter who has a thicker seat back & bottom which can be slipped in. This setup works well with no permanent mods being required.
Kevin
On 10 May 2011, at 17:38, "Mike Gamble" <mp.gamble(at)talktalk.net (mp.gamble(at)talktalk.net)> wrote:
To: [url=mailto:europa-list(at)matronics.com]europa-list(at)matronics.com (europa-list(at)matronics.com)[/url]
XS mono
G-CFMP
Ivor Phillips
Posted: Tue May 10, 2011 9:59 pm Post subject: rudder pedal adjustment |
I flitted two turnbuckle's in the rear fuselage to eliminate cable stretch, but so far they are fine, It would
be a awkward job but they could be retro fitted through the D panel,
Ivor
G-IVER
On 10 May 2011 17:38, Mike Gamble <mp.gamble(at)talktalk.net (mp.gamble(at)talktalk.net)> wrote:
XS mono
G-CFMP
Quote: |
arget="_blank">http://www.matronics.com/Navigator?Europa-List
tp://forums.matronics.com
member(at)flyers.freeserv Guest
Posted: Wed May 11, 2011 12:23 am Post subject: rudder pedal adjustment |
CABLE TENSIONERS are the easiest way to go.eg: http://cgi.ebay.co.uk/Straining-Screw-Cable-Tensioner-20mm-Jaw-49cm-73cm-/110685980396?pt=LH_DefaultDomain_3&hash=item19c56606ecAviation quality are available from Light Aero Spares.[quote]===============Message Received: May 10 2011, 06:49 PMFrom: "Kevin Challis" To: "europa-list(at)matronics.com" Cc: Subject: Re: FW: rudder pedal adjustment
I am 5' 8" and the standard set up is fine. I know someone shorter who has a thicker seat back & bottom which can be slipped in. This setup works well with no permanent mods being required.Kevin
On 10 May 2011, at 17:38, "Mike Gamble" <mp.gamble(at)talktalk.net (mp.gamble(at)talktalk.net)> wrote: Quote: |
Re sent due bounce-- Sent: 16 April 2011 21:37To: (europa-list(at)matronics.com)europa-list(at)matronics.com (europa-list(at)matronics.com)Subject: rudder pedal adjustment How do we adjust the rudder pedals for short ar—s like myself after aircraft completion? The manual suggests cable shortening using home made triangular 3 bolt clamps in the rear fuse but these would bounce around the fuselage bottom of the XS with the extended tail wheel. So far I have been using cushions to adjust the body. What are others doing?ThanksMike XS monoG-CFMP Quote: | =================================== href="http://www.matronics.com/Navigator?Europa-List" mce_href="http://www.matronics.com/Navigator?Europa-List">http://www.matronics.com/Navigator?Europa-List =================================== ums.matronics.com">http://forums.matronics.com =================================== http://www.matronics.com/contribution">http://www.matronics.com/contribution ========== | <= --> htt====== | [b]
john firth
Joined: 29 Jan 2011 Posts: 11 Location: Yorkshire England
Posted: Wed May 11, 2011 9:52 am Post subject: rudder pedal adjustment |
i have recently replaced the rudder cables after the port one started to destrand just as it goes through the fin bulkhead. The cause appears to be the fitting of two sleeves on the rudder end which hit the bulkhead on full deflection (go and check yours). My aircraft has two turnbuckles in the rear fuselage and when setting these up you need to use the ruder pedal stops so shortening the cable may create trouble here. Regards, john.
On 11 May 2011, at 06:33, PHILLIPS I wrote:
[quote]I flitted two turnbuckle's in the rear fuselage to eliminate cable stretch, but so far they are fine, It would
Ivor
G-IVER
XS mono
G-CFMP
| [b]
Posted: Wed May 11, 2011 11:19 am Post subject: rudder pedal adjustment |
Thanks for the input re rudder pedal adjustment.
If I find the use of cushions too much trouble I shall shorten the cables by moving the thimbles at the rudder end.
G-CFMP
rparigoris
Posted: Wed May 11, 2011 2:41 pm Post subject: Re: rudder pedal adjustment |
I have mentioned it before, I think it is worth mentioning again:
If you use turnbuckles with thimble eyes, the cable eyes can become tangled effective shortening the cable. Bad no question on a Tri-gear but even worst on a tail-dragger!
See page 2 for tangle, and resolution (heat shrink):
http://www.europaowners.org/forums/gallery2.php?g2_itemId=27732&g2_page=2
Ron Parigoris
