peteohms
Posted: Tue May 10, 2011 7:30 am Post subject: Brake sticks |
I have a bit of a problem with a sticking brake on My Kitfox III. When I taxi for a long distance my left brake drags and eventually binds up. I am careful not to apply any brake and this still happens. Any ideas??
_________________ Pete
Leander, TX
Kitfox III, 912ul, Grove |
KeysFox
Posted: Tue May 10, 2011 8:27 am Post subject: Brake sticks |
If the brakes are mid to early 1990 Matcos, Make sure brake pedal(s)
return completely back to thier stops after applying brakes at any point.
My Matco copilot side brake pedals did not always fully return after being
depressed and as pads and rotors warm up, and things expand, braking
occured.
Matco has provided good technical help when I have called them by the way.
<apeterchristensen(at)sbcglobal.net>
I have a bit of a problem with a sticking brake on My Ktfox III. When I
Pete
Leander, TX
http://forums.matronics.com/viewtopic.php?p=339433#339433
_________________ B Jones
N154K
443-480-1023 |
sourdostan(at)aol.com Guest
Posted: Tue May 10, 2011 9:35 am Post subject: Brake sticks |
If I recall correctly, there was a similar problem in the mid-nineties, and Matco sent out a kit to rectify the problem. Seems like the kit included a couple of sleeves/bushings to solve the problem.
Stan Specht
Lakewood, CO
Kitfox IV Speedster
912 ul 1750+ hours
Paul A. Franz, P.E.
Posted: Wed May 11, 2011 4:44 am Post subject: Brake sticks |
On Tue, May 10, 2011 8:31 am, peteohms wrote:
I have a bit of a problem with a sticking brake on My Ktfox III. When I taxi for a
Have you checked the wheel bearings?
Paul A. Franz
Registration/Aircraft - N14UW/Merlin GT
Engine/Prop - Rotax 914/NSI CAP
Bellevue WA
Office 425.440.9505
425.241.1618 Cell
_________________ Paul A. Franz, P.E.
Bellevue WA
425.241.1618 Cell
425.440.9505 Office |
Roger Lee
Posted: Wed May 11, 2011 5:31 am Post subject: Re: Brake sticks |
They are right that the master cylinder needs to come all the way back out to it's stop for the brake to fully release. If that isn't the problem then there is another thing that can cause this. You will need to pull the caliper and remove the piston. There you will see an "O" ring that needs to be checked and possibly replaced and then check for any corrosion. This is where it will take place if any moisture or dirt has migrated into this area. You can use a scotch bright pad to clean the piston and it's mating surface, but don't get carried away.
_________________ Roger Lee
Tucson, Az.
Rotax Instructor & Rotax IRC
Light Sport Repairman
Cell 520-349-7056 |
pchristensen10(at)austin. Guest
Posted: Wed May 11, 2011 5:46 am Post subject: Brake sticks |
Thanks to everyone who commented. I have a few things to try. The
simple solution is to squirt a little antifreeze on the brake pad before
I fly. Works great. But then, I use duck tape for cosmetic repairs.
Pete
On 5/11/2011 8:31 AM, Roger Lee wrote:
Roger Lee
Tucson, Az.
Light Sport Repairman - Maintenance Rated
Rotax Repair Center
Cell 520-349-7056
http://forums.matronics.com/viewtopic.php?p=339549#339549
