bnanton(at)pld.com Guest
Posted: Wed May 10, 2006 3:33 pm Post subject: Sam James Cowl |
I'm close to finishing my RV-8 and have chosen to install the SJ cowl,
plenum, and wheel pants. I am using the 200hp Lycoming IO360 A1B6 in
conjunction with the Whirlwind 200RV prop. The first -8 cowl was received 6
months ago and we've just begun the installation. The cowl will not work
without a prop extension without extensive fiberglass work. Will James
directed me to a company called Sabre Manufacturing that machines a very
beautiful prop extension. In speaking with the owner, he assures me that
there will be no prop restrictions with the use of this extension and that
they have never had a problem with this. I have heard that the heavier
Hartzell CS prop could have some restriction with an extension. You should
check with Sabre Mfg for their input.
The original cowling would not fit the engine and Will James is in the
process of redesigning the cowling to fit the RV-8 with the 200hp lyc. He
has changed the design, including materials used, to create a lighter and
stronger cowling than previously offered. The plenum with baffling has been
installed and looks great. At this point I can't answer any of the
questions regarding increased speed etc. I chose the SJ products because I
like the appearance and wanted something a little different. Hopefully,
there will be some speed and/or economy benefits. It will be difficult to
quantify without apple to apple comparisons which are hard to come by with
all the different ways the RVs are built.
Bill
| | - The Matronics RV8-List Email Forum - | | | Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
