zsmith3rd(at)earthlink.ne Guest
Posted: Thu Jan 12, 2006 12:32 pm Post subject: 800 pound crate |
Some have used a flatbed trailer behind a pickup truck and picked up the crate at the frieght terminal.
The trailer is only 18 inches or so above ground, and by cranking up the trailer's jackstand the rear will tilt down to a foot from the ground. Makes a ramp easier to scrounge.
Only problem is if freight company can put box on trailer. Most utility trailers have side rails that a forklift can't negotiate.......they can load from the rear, if they will.
Two creepers used to service automobiles will roll the crate, especially after you remove the top and some of the stuff from inside once you arrive at home.
Others will have much better suggestions.
regards,
Zed/701/R912/etc
