Dwayne
Posted: Tue Apr 12, 2011 11:04 am Post subject: Model IV Speedster Extensions |
Would someone please email me the plans for the Model IV Speedster wing extensions???? I have a nice 912 Speedster which I hope to add the wing extensions and fat tires............. any help with either would be appreciated!!!!!!!!!!!!
Tom Jones
Joined: 12 Mar 2006 Posts: 752 Location: Ellensburg, WA
Posted: Wed Apr 13, 2011 5:23 am Post subject: Re: Model IV Speedster Extensions |
[quote="Dwayne"]Would someone please email me the plans for the Model IV Speedster wing extensions???? I have a nice 912 Speedster which I hope to add the wing extensions and fat tires............. any help with either would be appreciated!!!!!!!!!!!!
Dwayne, if I remember correctly the removable wing extensions were a Model 5 option. The model 4 and 5 wing are the same so it would probably work.
The removable wing extension didn't seem to catch on. There are probably not many people around that have them or the instructions. There is a permanent wing extension kit available for the Avid Flyer which has a very similar wing.
I think it wouldn't be too complicated. A tube or I beam incert and a few feet of the round spar material.
_________________ Tom Jones
Classic IV
Ellensburg, WA |
lcfitt(at)sbcglobal.net Guest
Posted: Wed Apr 13, 2011 6:47 am Post subject: Model IV Speedster Extensions |
Dwayne,
I saw your post as well, and likely everyone else did too. I agree with
Tom. I suspect that plans are not available, at least not from those that
monitor this list. Ask if anyone has ideas on how it can be done and you
will likely get tons of opinions, if that would suffice. I will give you
mine. I'd find some telescoping tubing and make something like a fishing
pole ferrule for the spars and use the same structure to attach the
extension that you likely have on the wing tip, but maybe a bit more beefy
depending on what you have. I am helping a friend with his Kitfox and the
original builder found some thin aluminum angle and was able to form it to
the contour of the rib capstrip and riveted it to both the capstrip and the
rib web - top and bottom. Then he put an aluminum doubler over the wingtip
fiberglass at the edge. For one rib bay, I suspect that would be a tough
attachment.
Lowell
Sent: Wednesday, April 13, 2011 6:23 AM
Subject: Re: Model IV Speedster Extensions
> [b]
similar wing.
Tom Jones
Classic IV
Ellensburg, WA
http://forums.matronics.com/viewtopic.php?p=336815#336815
WurlyBird
Joined: 16 May 2008 Posts: 207 Location: North Pole, Alaska
Posted: Wed Apr 13, 2011 12:53 pm Post subject: Re: Model IV Speedster Extensions |
Doesnt Airdale Inc sell a kit for this? None Of their products are inexpensive but I also wouldn't consider them expensive considering the engineering that has already been done for you.
_________________ James
Kitfox 3 / 582 / 70" IVO 2 blade GA
50 hrs on the 582 swapping for HKS 700E and Avid Cowl. |
