barry.collman(at)air-brit Guest
Posted: Sat Mar 12, 2011 4:01 pm Post subject: aol.com email addresses |
Hello Bert Berry & Capt JimBob,
I’ve tried to send an email, twice to each of you, but seem to be having a problem with having “aol.com” in your email address.
The message I’m getting back, is saying they were undeliverable and the reason was:
5.3.0 - Other mail system problem 554-'5.2.1 : (HVU:B2) http://postmaster.info.aol.com/errors/421hvub2.html '
Well, the link to website does indeed give the reasons for various rejections, but to a non-geek like this old age pensioner, they are totally not understandable.
Why they have to use what is, to me anyway, jargon, is absolutely useless.
For example:
“Reverse DNS is a way of associating an IP address with its hostname. The reverse DNS identifier is contained in the PTR portion of the IP Zone File. The IP Zone File contains all the different ways that your IP and domain name can be associated; each association serves a different need.
<![if !supportLists]>· <![endif]>AOL requires that all connecting Mail Transfer Agents have established reverse DNS, regardless of whether it matches the domain.
<![if !supportLists]>· <![endif]>Reverse DNS must be in the form of a fully-qualified domain name. Reverse DNS containing in-addr.arpa are not acceptable, as these are merely placeholders for a valid PTR record. Reverse DNS consisting of IP addresses are also not acceptable, as they do not correctly establish the relationship between an IP address and its associated domain.
<![if !supportLists]>· <![endif]>Reverse DNS that may be similar to dynamic IP space (containing pool, dhcp, dyn, etc.) may be treated as suspect, and should therefore should be changed to reflect a fully-qualified domain name with standard MTA reverse DNS. [Example: mail.aol.com]”
So, nothing anywhere near resembling a clear and precise reason then.
Why not state what the reason is in simple English, whether it’s UK or US English?
I’ll try again tomorrow . . . and the next day . . . . and the next . . . then on my next Birthday!!
Best Regards,
Barry
| | - The Matronics Commander-List Email Forum - | | | Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
http://www.matronics.com/Navigator?Commander-List |
comserv500s(at)gmail.com Guest
Posted: Sun Mar 13, 2011 9:51 am Post subject: aol.com email addresses |
Barry: I think someone from the Federal Government wrote the message
you received regarding the aol email message. I read it several
times, still do not know what it says or means. Morris
On Sat, Mar 12, 2011 at 3:56 PM, Barry Collman
<barry.collman(at)air-britain.co.uk> wrote:
| Quote: | Hello Bert Berry & Capt JimBob,
reason was:
not understandable.
For example:
· AOL requires that all connecting Mail Transfer Agents have
· Reverse DNS must be in the form of a fully-qualified domain name.
· Reverse DNS that may be similar to dynamic IP space (containing
English?
Best Regards,
Barry
LLOYDSSS11(at)MSN.COM Guest
Posted: Sun Mar 13, 2011 11:12 am Post subject: aol.com email addresses |
<?xml:namespace prefix="v" /><?xml:namespace prefix="o" /><![endif]--> MORRIS, THE NITROGEN LANDING GEAR SUPPLY ON MY 500B LEAKS TO 0 PRESSURE IN 3 OR 4 DAYS. WE CAN'T LOCATE THE LEAK. HAVE YOU SEEN THIS BEFORE ? ANY CLUES. THANKS, LLOYD SILVERMAN
n55bz(at)cox.net Guest
Posted: Sun Mar 13, 2011 11:42 am Post subject: aol.com email addresses |
<?xml:namespace prefix=3D"v" /><?xml:namespace prefix=3D"o" = /><![endif]--> MORRIS, THE NITROGEN LANDING GEAR SUPPLY ON MY 500B LEAKS TO 0 = PRESSURE IN=20 3 OR 4 DAYS. WE CAN'T LOCATE THE LEAK. HAVE YOU SEEN THIS BEFORE ? ANY = CLUES.=20 THANKS, LLOYD SILVERMAN
bertberry1(at)aol.com Guest
Posted: Sun Mar 13, 2011 12:43 pm Post subject: aol.com email addresses |
Bill,
Saw that fine looking machine at ARA a while back. Looks great.
Bert
On Mar 13, 2011, at 2:39 PM, n55bz(at)cox.net (n55bz(at)cox.net) wrote:
[quote] I experienced that. The cause was a loose fitting on the emergency extension cylinder. Found it with soap solution, it was on the starboard side the last connection we checked. Required about 1/8 turn with a wrench.
Kindest regards,
Bill
N670CB the last remaining Grand Renaissance Shrike. Sn. 3319.
Sent via BlackBerry by AT&TFrom: "lloyd silverman" <LLOYDSSS11(at)MSN.COM (LLOYDSSS11(at)MSN.COM)>
Sender: owner-commander-list-server(at)matronics.com (owner-commander-list-server(at)matronics.com)
Date: Sun, 13 Mar 2011 15:10:34 -0400
To: <commander-list(at)matronics.com (commander-list(at)matronics.com)>
ReplyTo: [url=mailto:commander-list(at)matronics.com]commander-list(at)matronics.com (commander-list(at)matronics.com)[/url]
Subject: Re: aol.com email addresses
jtaddington(at)verizon.ne Guest
Posted: Sun Mar 13, 2011 1:08 pm Post subject: aol.com email addresses |
Barry, If you like send it to me and I will forward it. Jim Addington
Posted: Sun Mar 13, 2011 1:13 pm Post subject: aol.com email addresses |
Give me a call next time- 337-519-5081 cell.
From: owner-commander-list-server(at)matronics.com [mailto:owner-commander-list-server(at)matronics.com] On Behalf Of Bert Berry
Sent: Sunday, 13 March, 2011 15:41
Bill,
Bert
Kindest regards,
Bill
ReplyTo: commander-list(at)matronics.com (commander-list(at)matronics.com)
Posted: Sun Mar 13, 2011 1:22 pm Post subject: aol.com email addresses |
Hi Jim,
It's OK now, aol seem to have fixed what seems to have been a glitch in the
system yesterday.
Your offer of help though is much appreciated.
Very Best Regards,
Barry
Posted: Sun Mar 13, 2011 1:43 pm Post subject: aol.com email addresses |
All of us seniors have to look out for each other. I am glad you got it
fixed though. Jim
yourtcfg(at)aol.com Guest
Posted: Sun Mar 13, 2011 5:44 pm Post subject: aol.com email addresses |
HI BARRY.Did you get the email with the link to the "deer hunter"?? jb
Posted: Sun Mar 13, 2011 7:21 pm Post subject: aol.com email addresses |
<?xml:namespace prefix="v" /><?xml:namespace prefix="o" /><![endif]--> THANKS BILL, I'LL TRY THAT SATURDAY.MOST CUNNECTIONS HAVE BEEN SOAP BUBBLED, NOT THAT ONE. LLOYD
Posted: Mon Mar 14, 2011 2:27 am Post subject: aol.com email addresses |
Hi JimBob,
Yes, I did!
I tried to email you to say “Thanks”, but it seems aol.com email addresses had a glitch and I got messages saying my emails were undeliverable.
I was going to try again today!
Very Best Regards,
Barry
From: owner-commander-list-server(at)matronics.com [mailto:owner-commander-list-server(at)matronics.com] On Behalf Of yourtcfg(at)aol.com
Sent: 14 March 2011 01:40
