gengrumpy(at)aol.com Guest
Posted: Wed Feb 23, 2011 7:03 pm Post subject: Wheel bolt info |
I'd appreciate it if one of the builders who has not yet put their wheels together would give me the AN bolt numbers off both main and nose wheels.
Van's doesn't have it, nor does Cleveland have it in any of their manuals and won't answer the request.
I need to stock some extras.
Thanks - grumpy
Kellym
Posted: Wed Feb 23, 2011 8:53 pm Post subject: Wheel bolt info |
Well, the best I can give you is parts breakout in the Spruce catalog,
pg 232, 5:00X5 Cleveland has either AN4-31A for most, or AN4-22A for
the rest. For 6:00X6 it is most likely AN5-35A
On 2/23/2011 8:00 PM, Miller John wrote:
Thanks - grumpy
KCHD |
Kelly McMullen
Posted: Thu Feb 24, 2011 8:08 am Post subject: Wheel bolt info |
If I remember, I can measure the bolts in my uninstalled main wheels
when I next get to the hangar, but I don't have a nose wheel yet, as I
declined to buy Van's erroneous nose wheel selection.
On Wed, Feb 23, 2011 at 9:50 PM, Kelly McMullen <kellym(at)aviating.com> wrote:
Well, the best I can give you is parts breakout in the Spruce catalog, pg
232, 5:00X5 Cleveland has either AN4-31A for most, or AN4-22A for the
> Thanks - grumpy
A&P/IA, EAA Tech Counselor
KCHD |
Posted: Thu Feb 24, 2011 10:58 am Post subject: Wheel bolt info |
Kelly,
Unfortunately not correct.
I called both Matco and Cleveland this am. Here are the sizes (for those of you who would like to stock some spares.......ask me why I know).
Nose: AN 4-23A
Main: AN 5-34A (for the 40-59A wheel itself)
grumpy
On Feb 23, 2011, at 10:50 PM, Kelly McMullen wrote:
Well, the best I can give you is parts breakout in the Spruce catalog, pg 232, 5:00X5 Cleveland has either AN4-31A for most, or AN4-22A for the rest. For 6:00X6 it is most likely AN5-35A
> Thanks - grumpy
