Posted: Tue Feb 22, 2011 1:51 pm Post subject: Replacement Prop Governor Suggestion |
Dear list,
We are very close to flying the 8A and have run our 400 TTSOH engine with new Hartzell BA Prop. Everything runs great with the exception of the Prop Governor direction. The unit came off a Lake Amphibian LA-4-200 with a different prop. Unfortunately it seems to work backwards, the engine smoothes out and rpm increases when you pull the lever back. We believe we have the wrong Gov and it is time for a replacement.
Here are the specifics:
Prop: New Hartzell, HC-C2YR-1BFP/F7497
Engine: IO-360-AIB 200 Hp
Hartzell Prop. Gov: The alum. tag is hard to read. Model F-6-5 **
Prior Aircraft: Lake LA-4-200 Ser. No. 465
My question; is there a preferred Prop Governor on the market for this prop & engine combination? I read on the Hartzell site the recommended Hartzell governor is the S-1-10. Any comments or recommendations?
Robin
RV-4 Sold
RV-6A Sold
RV-10 210 Hours
RV-8A Soon
** Model F-6-5 I'm sure about the "F" and the "6", pretty sure about the "5", it could have another digit after the 5, can't tell. Ser. no. -7310T, the dash could be an "A" or "?-"
Gary.A.Sobek
Posted: Tue Feb 22, 2011 3:22 pm Post subject: Replacement Prop Governor Suggestion |
All I can say is look into the PCM5000. All the prop shops that I have talked to have recommended that unit. The PCM5000 is available in an experimental version that is a little less expensive.
Gary A. Sobek
2,475+ Flying Hours So. CA, USA
Date: Tue, 22 Feb 2011 13:46:54 -0800
Subject: Replacement Prop Governor Suggestion
To: rv8-list(at)matronics.com; rv-list(at)matronics.com; rv7-list(at)matronics.com
.ExternalClass p.ecxMsoNormal, .ExternalClass li.ecxMsoNormal, .ExternalClass div.ecxMsoNormal {margin-bottom:.0001pt;font-size:11.0pt;font-family:'Calibri','sans-serif';} .ExternalClass a:link, .ExternalClass span.ecxMsoHyperlink {color:blue;text-decoration:underline;} .ExternalClass a:visited, .ExternalClass span.ecxMsoHyperlinkFollowed {color:purple;text-decoration:underline;} .ExternalClass span.ecxEmailStyle17 {font-family:'Arial','sans-serif';color:windowtext;font-weight:normal;font-style:normal;} .ExternalClass .ecxMsoChpDefault {;} (at)page WordSection1 {size:8.5in 11.0in;} .ExternalClass div.ecxWordSection1 {page:WordSection1;}
Dear list,
Robin
RV-4 Sold
RV-6A Sold
RV-10 210 Hours
RV-8A Soon
[quote]<//www.matronics.com/Navigator?RV-List" target="_blank">http://www.matroni="http://forums.matronics.com" target="_blank">http://forums.matronics.= --> [b]
aerobubba(at)earthlink.ne Guest
Posted: Wed Feb 23, 2011 11:06 am Post subject: Replacement Prop Governor Suggestion |
Could you perhaps flip the control arm on the governor 180 degrees to reverse the operation?
| Quote: | a different prop. Unfortunately it seems to work backwards, the engine
Glen Matejcek
