keithmckinley
Posted: Thu Feb 17, 2011 8:30 pm Post subject: cnc cutting for inst panel |
Can anyone recommend a shop that is familiar with our instruments (CJ-6) and would likely have a stock CAD file they could manpulate. I have a blank panel from Doug that I'd like cut.
I know I can cut the holes myself but the CNC machine does a MUCH nicer job!
Keith
CJ6XXK
Posted: Thu Feb 17, 2011 11:37 pm Post subject: Re: cnc cutting for inst panel |
Hi
I can cnc cut what ever you would like.Has someone got a CAD file of the dash?
Daniel
cjpilot710(at)aol.com Guest
Posted: Fri Feb 18, 2011 5:26 am Post subject: cnc cutting for inst panel |
I did this a number of years ago. I had drawn up a panel in AutoCad, and a local shop (now out of business) cut the panels that Doug sells. The programing of the cnc took about 4 hours, the actual cutting took :30 minutes. Really fascinating to watch! The fit and finish is perfect.
However I had believe I have that file around anymore. Although I still do a lot of cad drawing its for fun.
Jim "Pappy" Goolsby
In a message dated 2/17/2011 11:32:49 P.M. Eastern Standard Time, keith.mckinley(at)townisp.com writes:
Quote: | --> Yak-List message posted by: "keithmckinley" <keith.mckinley(at)townisp.com>
Keith
Keith McKinley
700HS
KFIT
http://forums.matronics.com/viewtopic.php?p=331393#331393===============================================
_-= e ties Day ================================================ - MATRONICS WEB FORUMS ================================================ - List Contribution Web Site sp; ===================================================
Cliff.Coy
Posted: Fri Feb 18, 2011 8:42 am Post subject: cnc cutting for inst panel |
Haven't done a CJ panel, but we design and waterjet panels 4-5 times a year.
Contact me off list for examples.
Cheers!
Cliff
On Fri, Feb 18, 2011 at 08:15, <cjpilot710(at)aol.com (cjpilot710(at)aol.com)> wrote:
Quote: | I did this a number of years ago. I had drawn up a panel in AutoCad, and a local shop (now out of business) cut the panels that Doug sells. The programing of the cnc took about 4 hours, the actual cutting took :30 minutes. Really fascinating to watch! The fit and finish is perfect.
Jim "Pappy" Goolsby
In a message dated 2/17/2011 11:32:49 P.M. Eastern Standard Time, keith.mckinley(at)townisp.com (keith.mckinley(at)townisp.com) writes:
Quote: | --> Yak-List message posted by: "keithmckinley" <keith.mckinley(at)townisp.com (keith.mckinley(at)townisp.com)>
Keith
Keith McKinley
700HS
KFIT
e ties Day ======================= - MATRONICS WEB FORUMS ======================= - List Contribution Web Site sp; =
Quote: |
et="_blank">http://www.matronics.com/Navigator?Yak-List
Clifford Coy
Border Air Ltd.
629 Airport Rd.
Swanton, VT 05488
802-868-2822 TEL
802-868-4465 FAX
Skype: Cliff.Coy
threein60(at)yahoo.com Guest
Posted: Fri Feb 18, 2011 9:47 am Post subject: cnc cutting for inst panel |
I had two different front panels custom cut for my CJ now. CAD and water jet is the way to go if available to you. fantastic job and tight tolerances are achieved.
Larry Pine
--- On Fri, 2/18/11, cjpilot710(at)aol.com <cjpilot710(at)aol.com> wrote:
Quote: |
From: cjpilot710(at)aol.com <cjpilot710(at)aol.com>
Subject: Re: cnc cutting for inst panel
To: yak-list(at)matronics.com
Date: Friday, February 18, 2011, 6:15 AM
Jim "Pappy" Goolsby
Keith
Keith McKinley
700HS
KFIT
http://forums.matronics.com/viewtopic.php?p=331393#331393============================= - MATRONICS WEB FORUMS ======================= - List Contribution Web Site sp; ==========================
Quote: |
et=_blank rel=nofollow>http://www.matronics.com/Navigator?Yak-List
Sonic1
Joined: 10 Feb 2009 Posts: 21 Location: Vancouver, BC
Posted: Fri Feb 18, 2011 3:45 pm Post subject: Re: cnc cutting for inst panel |
I designed Adrian Cooper's panel in AutoCAD and had it laser cut. Laser cutter programming took about a half an hour, and the actual laser cutting was about 90 seconds. Page one of the attached pdf is the layout, and page two is fresh out of the laser cutter.
Jeff.
Description: |
 Download |
Filename: |
Adrian CJ Panel.pdf |
Filesize: |
136.75 KB |
Downloaded: |
562 Time(s) |
keithmckinley
Posted: Sat Feb 19, 2011 6:13 pm Post subject: Re: cnc cutting for inst panel |
NICE!
Jeff, what dimensions did you use for the small Chinese instruments as they are a tad bigger than the standard 2.25". It seems the large Chinese stuff is
right at the standard 3 1/8"
Keith
CJ6XXK
Posted: Sat Feb 19, 2011 11:35 pm Post subject: Re: cnc cutting for inst panel |
Hi
How did you go pressing the sides over? What size material did you use.
If someone can get me a CAD file or dimensions i will draw them up and cut some.
I am also going to do the fuel filler covers as well that i will send to Doug Sapp so he can supply them to all.
Daniel
keithmckinley
Posted: Sun Feb 20, 2011 6:27 am Post subject: Re: cnc cutting for inst panel |
Doug Sapp has those blank panels custom made.
Jeff I sent you a PM.
Keith
fish(at)aviation-tech.com Guest
Posted: Mon Feb 28, 2011 4:51 pm Post subject: cnc cutting for inst panel |
Keith,
I am working on building a CNC machine, but it is probably a couple
of years away from being completed.
It will be delayed about a year, while I am recalled to active duty
(June or Jul 2011), and saving up for the electronics.
My best estimate so far on cost is $7-$10K.
I initially started researching CNC routers, for a 1:1 scale F-16
cockpit project.
But the found I could do so much more with it (build parts for my L-5
& PT-19 restorations).
I had not even thought of building custom instrument panels with it.
Thanks for adding to my list of things to use it for
John Fischer
Keith
Keith McKinley
700HS
KFIT
