raymondj(at)frontiernet.n Guest
Posted: Fri Jan 28, 2011 11:39 pm Post subject: OT-potting with RTV silicone |
Is RTV silicone acceptable for potting electronics? I know Bob
recommends E6000 or equivalent but I have several 1/2 tubes of RTV I'd
like to use up. The item I'm potting is the "ballast for some cheap
fluorescent fixtures that buzz. I'm hoping I can quiet them down.
Thanks for all replies.
Raymond Julian
Kettle River, MN
Posted: Sat Jan 29, 2011 6:03 am Post subject: OT-potting with RTV silicone |
On 1/29/2011 1:25 AM, rayj wrote: | Quote: | --> AeroElectric-List message posted by: rayj <raymondj(at)frontiernet.net> (raymondj(at)frontiernet.net)
Is RTV silicone acceptable for potting electronics? I know Bob recommends E6000 or equivalent but I have several 1/2 tubes of RTV I'd like to use up. The item I'm potting is the "ballast for some cheap fluorescent fixtures that buzz. I'm hoping I can quiet them down.
| If the label doesn't say 'sensor safe' or something similar, it's likely that it will be corrosive. If you're just potting the transformer, it might not corrode fast enough to matter, but I'd be really leery about using it on a circuit board.
Posted: Sat Jan 29, 2011 7:11 am Post subject: OT-potting with RTV silicone |
At 02:25 AM 1/29/2011, you wrote:
"Potting" implies a material that will set up
in what's called "deep section". Exemplar materials
are those that use a catalyst to effect a chemical
reaction throughout the mass of potting compound.
RTV's I've encountered come in both catalytic
and environmentally "set". I think that
materials that come in tubes are set up
by moisture in the air. E6000 and other cements
set up when solvents evaporate. Both will eventually
get firm throughout the mass but E6000 can take
days, RTV might take months.
Rather than "pot", try "coating". The buzzing will
be mitigated by adding any dampening mass to the devices
that vibrate. Use a thin layer of any non-catalytic
material over the offending devices. Let that set
up (perhaps a couple days) and apply another coat
if the first treatment is insufficient.
But putting the devices in a potting form and filling
it with any non-catalytic material will leave a
liquid interior that may take a very long time
to firm up. The garden variety RTV's smell like
vinegar . . . not sure about the details of their
functional chemistry but I do know that the acetic
acid is antagonistic to metals during the cure
cycle. I observed that fact in a $thousand$ boo-boo
at Cessna about 40 years ago!
There are RTVs that don't smell like pickles, if
that's the variety you have, you can go forward
with very little risk.
pwmac(at)sisna.com Guest
Posted: Sat Jan 29, 2011 7:36 am Post subject: OT-potting with RTV silicone |
Correct and that brand uses an acid .
Having said that you can still buy RTV that contaons no acid.
The no acid type is what the Kitfox guys use to bond the fiberglass
tank to the Al spar.
Avoid the acetic acid mentioned on the label.
All use moisture as the curing catalyst.
PaulW
At 06:06 AM 1/29/2011, Robert L. Nuckolls, III wrote:
| Quote: | The garden variety RTV's smell like
vinegar . .
Tundra10
Joined: 14 Jun 2010 Posts: 102 Location: Scarborough, Ontario
Posted: Sun Jan 30, 2011 8:37 am Post subject: OT-potting with RTV silicone |
You can buy silicone without acetic acid at the pet store - used for
sealing aquariums. I haven't tried it for potting though.
Jeff Page
Dream Aircraft Tundra #10
Posted: Sun Jan 30, 2011 11:57 am Post subject: OT-potting with RTV silicone |
At 10:30 AM 1/30/2011, you wrote:
Thank you! I'd forgotten about that. I think the
same grade of RTV is approved for situations that
come into contact with food.
I'm pretty sure this stuff would do the job if applied
in several layers of 1/4" or less and allowed to cure
before more is added.
(o o)
===========o00o=(_)=o00o=========
< Go ahead, make my day . . . >
< show me where I'm wrong. >
Posted: Wed Feb 02, 2011 10:23 pm Post subject: OT-potting with RTV silicone |
Thanks to all for the info. I'm going to go with a coating of E 6000
and I'll add additional layers of RTV, if necessary.
Raymond Julian
Kettle River, MN
On 01/30/2011 01:15 PM, Robert L. Nuckolls, III wrote:
<nuckolls.bob(at)aeroelectric.com>
(o o)
