369PL
369PL
mikeperkins
Posted: Wed Jan 26, 2011 7:20 am Post subject: Re: 582 throttle cable |
Thinking about an in-flight loss of throttle control is pretty scary. It was something I considered when I built my Kitfox. My conclusion was that throttle reliability would come from smooth operation and took care to insure that. Still a little worried, I added a visual examination of the throttle linkage to my preflight checklist. Indeed the cable bends a bit as the lever travels from min to max, but it's a smooth bend with no stress point. And there's never any kind of a kink that forms. The pivot gets greased at every annual. Myself and two Kitfox friends have not added a spring nor have we done anything other than insure operation is smooth - between us we probably have 1800 hours.
As another thought, the pivot has a single point that digs into the cable wire. If that loosened, throttle control would be lost. So some guys on the List here (including me) have added a brass cable stop (AutoZone p/n 03338) to both sides of the pivot.
Hope this helps.
Mike
369PL
Posted: Wed Jan 26, 2011 5:49 pm Post subject: Re: 582 throttle cable |
I just recently put the oil injection back on my engine. This added another spring for the throttle wire to push against.
Warren Miller
mikeperkins
Posted: Thu Jan 27, 2011 7:05 am Post subject: Re: 582 throttle cable |
Hi Warren,
I remember when I built my aircraft, I did not like the geometry of the throttle linkage - the arc of the lever causes some sideways movement in the cable wire. I fiddled around with it for quite a while. I resisted any temptation to put an offset in the wire. But being I've only worked on Model I and Model II aircraft, perhaps your Model IV throttle linkage is a bit different. I'm hoping you can find a way to keep the wire from binding or kinking. If you sent a photo, I'd be happy to look at it: flybyewire(at)gmail.com
- Mike
