WurlyBird
Joined: 16 May 2008 Posts: 207 Location: North Pole, Alaska
Posted: Fri Jan 21, 2011 2:32 am Post subject: Composites and mold work |
I am sure there are some people on here with a good amount of experience with composites and I have a few questions for you. I am looking to make a few parts for my plane when I get home and I want to play with composites and molds.
One of my biggest concerns is with preparing a mold properly, everything I have been reading involves waxing the mold with several layers and then spraying with a mold release. Is there any type of mold release that skips the waxing step? I am considering using some molds with a lot of sharp inside corners so I am concerned about not getting enough wax on and a spray would be much more convenient.
There are countless resin combinations available. Are any of them better suited to mold work? I plan on doing some work with carbon fiber for aesthetics, are some resins better for this as far as coloring goes? I have seen some resins claim to be more clear then others. I have also seen mention of UV protection. Still trying to figure all this out so any insight is appreciated.
Does anyone have a preferred method for pulling a plug from an existing part? The techniques I have read most about and am leaning towards is gel coat painted over the part and then backed with a two part mold putty or fiberglass for strength.
I am sure I will think of more of the questions rolling around in my head after responses. In the mean time thanks for any input.
_________________ James
Kitfox 3 / 582 / 70" IVO 2 blade GA
50 hrs on the 582 swapping for HKS 700E and Avid Cowl. |
poasttown(at)yahoo.com Guest
Posted: Fri Jan 21, 2011 5:52 am Post subject: Composites and mold work |
James
Check out www.fibreglast.com for information concerning composite work. They are a supplier of products and they also have a section on this website with demonstrations. I've ordered from them in the past.
Mike
Kitfox IV
Jabiru 2200
--- On Fri, 1/21/11, WurlyBird <james.t.trizzino(at)us.army.mil> wrote:
Subject: Composites and mold work
--> Kitfox-List message posted by: "WurlyBird" <james.t.trizzino(at)us.army.mil (james.t.trizzino(at)us.army.mil)>
James
50 hrs on the Fox in between deployments,
now she lies in wait
http://forums.matronics.com/viewtopic.php?p=327758#32775= Use the Matronics List Features Navigator to f="http://www.matronics.com/Navigator?Kitfox-List" target=_blank>http:/http://forums.matronics.com/" target=_blank>http://forums.matronics.com
Guy Buchanan
Posted: Fri Jan 21, 2011 8:41 am Post subject: Composites and mold work |
On 1/21/2011 2:32 AM, WurlyBird wrote:
| Quote: | One of my biggest concerns is with preparing a mold properly,
I've never seen a reliable mold release that's a simple spray-on. I and
the professionals I've worked with have always done 6-8 layers of wax
plus PVA mold release. Done correctly you won't have corner build-up.
You'll want to minimize sharp corners, particularly for hand-laid parts.
The various woven goods just don't like to turn corners very sharply so
you'll be forced to vacuum bag. Otherwise, you'll have to use a milled
fiber build-up (fillet) in the corner and have the cloth turn inside
that which leaves the corner material relatively weak and not very
aesthetic.
| Quote: | There are countless resin combinations available. Are any of them better suited to mold work? I plan on doing some work with carbon fiber for aesthetics, are some resins better for this as far as coloring goes? I have seen some resins claim to be more clear then others. I have also seen mention of UV protection. Still trying to figure all this out so any insight is appreciated.
The resin you use for tooling depends on how you intend to cure the
part. In general you want a very long pot life and slow, low temperature
cure for tooling because molds are thick and relatively unstable. If you
intend to heat cure the part you may will want a tooling resin that you
can post cure at an elevated temperature so it remains stable when you
cook the part. See
http://www.ptm-w.com/dynamicdata/data/docs/pt2520%20bulletin.pdf for a
likely tooling resin.
For parts I like the System-Three Silver Tip series for clarity. You're
right that some are clearer than others. You hint that you'll be leaving
the part natural. For UV protection I rely on the clear-coat I use over
the cured part. I use Stirling urethane clear coats because they're
very, very clear and spray on nicely. Expensive, though. I saw that they
have clear gel-coat now so I suppose it's possible to pull a "finished"
part from a tool, though I've never seen it done and don't know how
clear clear gel-coat is.
One more note on clear carbon parts. As you probably well know black
surfaces get quite hot in the sun. It's possible for black painted steel
to get up to over 250F in the sun. You're clear-coated carbon part will
also get quite hot if it's exposed to direct sunlight. This means your
part will have to be cured at least somewhere near the service
temperature so it doesn't get all soggy in the sun. This means your tool
will have to be able to withstand an elevated cure temperature without
getting all soggy. When I did my clear carbon glare shield I cured it at
140F on the tool using a black bag and hot air blower, then I post cured
it at 250F in a crude foam insulation oven with hot-air blower.
| Quote: | Does anyone have a preferred method for pulling a plug from an existing part? The techniques I have read most about and am leaning towards is gel coat painted over the part and then backed with a two part mold putty or fiberglass for strength.
You've got it, though don't forget the mold-release.
Guy Buchanan
Ramona, CA
Kitfox IV-1200 / 592-C / Warp 3cs / 500 hrs. and grounded
Deceased K-IV 1200
A glider pilot too. |
WurlyBird
Posted: Fri Jan 21, 2011 9:51 pm Post subject: Re: Composites and mold work |
Thanks for the great information. Here is the first followup question.
What does baking a composite part do to the build up?
Does heating the resin while it is curing cause it to more thoroughly cure? From the way you phrased it it sounds like if you expect your part to be exposed to 200 deg in use then it should be baked at a minimum of 200 deg during build up, is this about right?
I do plan on leaving some of the parts natural. If I get the HKS when I get home I am going to need a new instrument panel and I figure it might as well be carbon or carbon/kevlar. Light, functional, and sexy, you cant beat it. With the Kitfox being as low tech and old school as it is, I anticipate that the carbon on the dash will look a little out of place so there will need to be a little carbon here and a little there just to balance it out aesthetically. I am conceiving a part that will be a LOT of sharp corners but I plan on getting into bagging and maybe even infusion. If the part I have in my head works out I will be telling you all about it, until then it is hush hush.
In case anyone else has been toying with the idea of bagging but can not find a reasonable set up, check this out:
http://www.veneersupplies.com/
http://www.joewoodworker.com/
Joe Woodworker has designed and has free plans for venturi style vacuum press and vennersupplies sells the kit. This set up has the benefit of having a vacuum reservoir that can easily be made a little larger and even as published should be great for dash sized projects.
Float Flyr
Posted: Sat Jan 22, 2011 6:15 am Post subject: Composites and mold work |
Sharp corners in composites usually translates into a place where cracks can
originate. The same can be true of aluminium which was the major problem
with the old comet airliner. The windows were all nice square units which
often cracked.
Noel
_________________ Noel Loveys
Kitfox III-A
Aerocet 1100 Floats |
Guy Buchanan
Posted: Sat Jan 22, 2011 8:02 am Post subject: Composites and mold work |
On 1/21/2011 9:51 PM, WurlyBird wrote:
| Quote: | Does heating the resin while it is curing cause it to more thoroughly cure? From the way you phrased it it sounds like if you expect your part to be exposed to 200 deg in use then it should be baked at a minimum of 200 deg during build up, is this about right?
Perfect.
| Quote: | Joe Woodworker has designed and has free plans for venturi style vacuum press and vennersupplies sells the kit. This set up has the benefit of having a vacuum reservoir that can easily be made a little larger and even as published should be great for dash sized projects.
I did the verturi thing once and it required an ENORMOUS amount of air
which I didn't have. I got a surplus vacuum pump instead.
Guy Buchanan
Ramona, CA
Deceased K-IV 1200
Lynn Matteson
Posted: Sat Jan 22, 2011 10:04 am Post subject: Composites and mold work |
I bought the air compressor-powered vacuum bagging kit and have yet
to finish the completion of the pump. I got mine over a year ago,
after seeing one that a friend built from one of He likes the way it
works, but cautioned me that using the bagging system....any bagging
system....is very costly in materials. He said that the raw materials
used up and thrown away counts up, and he found that he doesn't use
his bagging method as much since he discovered that. Just be aware of
the cost of doing vacuum bagging, and see if you really need to "bag
it" or if it just sounds like a really cool thing to do....like I
did. : )
By the way, I bought my kit when I was thinking of using it to make a
pair of skis, then went in another direction. I will finish the
vacuum pump one of these days, and then actually use it, but the
cost of the supplies that are scrapped during its use should justify
the use. If you can make the part light without bagging, that part
will be a lot cheaper.
Lynn Matteson
Jabiru 2200, #2062
Sensenich 62"x 55.5 Wood (winter) until the Prince prop arrives
Rotec TBI-40 injection
Status: flying...1078+ hrs (since 3-27-2006)
On Jan 22, 2011, at 12:51 AM, WurlyBird wrote:
question.
projects.
James
http://forums.matronics.com/viewtopic.php?p=327856#327856
_________________ Lynn
Kitfox IV-Jabiru 2200
N369LM |
lcfitt(at)sbcglobal.net Guest
Posted: Sat Jan 22, 2011 10:25 am Post subject: Composites and mold work |
Just a couple of comments on the project. I have a lot of experience -
amateur type - with composites and getting it right takes some real effort
and perfect? - lots of remakes. I can't say, I have ever gotten a part out
of the mold perfect. Most of mine are for painting and a little micro goes
a long way for nice. Not to discourage, but with the cost of the equipment,
materials and time, it seems to me that a one off part would be less
expensive if farmed out to a pro shop. If you like the challenge, as I do,
or like to learn new skills, then go for it, but in reality plan on paying a
premium for the home brew parts.
One idea for the sharp edged parts, though. I think a female mold would
work best and if the part is not too large, I have experimented with a very
soft silicone rubber sheet as the vacuum bagging material. The typical
material will not stretch enough to get into the tightest corners and as Guy
suggested, the glass doesn't like to bend. One way to help a bit there is
to cut the cloth on a bias. Then there is the issue of getting all the air
out of the corners. A vacuum bagging system will remove all air that it has
access to. Air trapped in a sharp corner will be there to stay, unless
there is clear access for it's escape into the vacuum - not sure how I would
manage that.
You also mentioned the infusion method. I think as Guy suggested, this
technique would require a good quality vacuum pump. A venturi wouldn't give
the vacuum you will need to move the resin. I don't know what you are
planning, planning but this would help in the sharp corner area unless it
would be a box as I can't visualize the resin flow. Something long like a
lift strut fairing might work.
Also keep in mind that the way you handle the release film (type) and
bleeder ply will determine the density of the part and if there are
pinholes - not desirable in your panel lay-up. An example of this is the
fuel tanks we use - all vacuum bagged and pinholes galore to the point of
the need for sloshing to keep the gas in.
Lowell
Sent: Saturday, January 22, 2011 7:57 AM
Subject: Re: Re: Composites and mold work
Perfect.
Guy Buchanan
Ramona, CA
WurlyBird
Guy Buchanan
Posted: Sat Jan 22, 2011 8:52 pm Post subject: Composites and mold work |
On 1/22/2011 9:59 AM, Lynn Matteson wrote:
| Quote: | By the way, I bought my kit when I was thinking of using it to make a
pair of skis, then went in another direction. I will finish the vacuum
pump one of these days, and then actually use it, but the cost of the
supplies that are scrapped during its use should justify the use. If
you can make the part light without bagging, that part will be a lot
cheaper.
HAHAHAHAHA! C'mon Lynn. When did ANYTHING in aviation get justified on a
cost basis. We do it because it's COOL. Way COOL. (Besides, who can pass
up an opportunity to get more tools.)
Guy Buchanan
Ramona, CA
Deceased K-IV 1200
WurlyBird
Posted: Sun Jan 23, 2011 12:12 am Post subject: Re: Composites and mold work |
Good point Guy, I completely forgot to mention the TOOL factor (not me, the actual tools). I am always collecting more tools, it drives my wife crazy. I always claim I can build something for less then it can be bought, of course I never factor in all the tools I don't yet have to that cost. One day though, I will have all the tools I need
Lynn Matteson
Posted: Sun Jan 23, 2011 3:48 am Post subject: Composites and mold work |
OK, if the part being built is a flat instrument panel, then no bag
is required. Just lay out your shape on a plate of glass. The glass
side will be the outside of the panel. You probably won't even have
to wax it. By the way, I bought and used the mold release wax, and
the spray-on release compound, and they both work fine, but so did
the Johnson's Paste Wax that I have used prior to buying the
"professional mold releases"...and a lot cheaper, too. A friend of
mine made a very nice clip board using carbon fiber which he laid out
on glass and it came out looking super...very smooth, because he
squeeged the excess resin off the layup, and used the glass side as
the front surface....a sheet of nylon or plastic works too.
Lynn Matteson
Jabiru 2200, #2062
On Jan 22, 2011, at 2:23 PM, WurlyBird wrote:
> did. : )
C'mon, we are talking about not structural parts for a Kitfox. It
is not necessary to use composites at all much less vacuum
bagging. It is definitely because it sounds like the cool thing to
do. I have a tendency to have visions of grandeur with my
projects, especially sitting here in a crappy country dreaming
about it for a year! I have been interested in vacuum bagging for
as long as I have understood what composites are good for. I keep
adding to my "wish list" at Aircraft Spruce and it certainly costs
noticeably more to bag anything. I am also trying to figure out
how much I will actually use the system as it is only NEEDED for
one idea I have right now and all I have come up with besides
making the occasional part is using it to instantly marinate
meats. I can hear it now;
friend- "What is James doing in the garage?"
wife- "Marinating the chicken."
now confused friend- "With an air compressor?!?!"
[Shocked]
James
N369LM |
Lynn Matteson
Posted: Sun Jan 23, 2011 6:37 am Post subject: Composites and mold work |
I can NEVER pass up a new tool...especially if it's high on the "cool
tool" barometer. : ) Hell, I've got some cool tools that are so
beyond my personal (used once) usage, that I have to use them on my
CFI' s airplanes just to *justify* their purchase.
By the way, when I was waiting for the air compressor-powered vacuum
bagging kit to arrive, I made do with a vacuum cleaner just to run a
test sample of bagging. It worked, but who wants to listen to the
vacuum cleaner run for hours...certainly not the dog! : )
Lynn Matteson
Jabiru 2200, #2062
On Jan 22, 2011, at 11:48 PM, Guy Buchanan wrote:
> make a pair of skis, then went in another direction. I will finish
> the vacuum pump one of these days, and then actually use it, but
> the cost of the supplies that are scrapped during its use should
> justify the use. If you can make the part light without bagging,
> that part will be a lot cheaper.
on a cost basis. We do it because it's COOL. Way COOL. (Besides,
who can pass up an opportunity to get more tools.)
Guy Buchanan
Ramona, CA
N369LM |
Float Flyr
Posted: Sun Jan 23, 2011 6:49 am Post subject: Composites and mold work |
Most if not all commercial parts are cured in an autoclave. They use vacuum
inside the bagging and pressure outside with of course heat. The heat is
required to make the Layup cloths cure. Without the heat the cloth can
actually never properly cure.
Noel
Kitfox III-A
Float Flyr
Posted: Sun Jan 23, 2011 7:03 am Post subject: Composites and mold work |
Vacuum bagging results in very strong light parts when done properly. There
is another problem with bagging and that is the possibility of voids inside
the part which you can only find with ultrasound or industrial X-ray. Even
the commercial composite companies spend a lot of time checking each and
every part they make looking for weaknesses and voids.
For repair work there is a machine available, called a Hot Shot, which comes
in a suitcase. It has hoses, sniffers and a heat blanket in the case to
cure Pre-Preg cloth. Don't ask how much!
Noel
Kitfox III-A
Lynn Matteson
Posted: Sun Jan 23, 2011 7:26 am Post subject: Composites and mold work |
Noel-
Using the terms "layup cloths" and "the cloth can never properly
cure" sounds like you're referring to "pre-pegs", right? I just never
figured the pre-pegs were in my league for the parts that I was
looking to make, let alone an autoclave.
By the way, the ski "spats" that I just made (to keep the snow off
the airplane's skis) were laid up over Poly-fiber fabric, which was
painted with a spray can (just to seal the weave of the fabric, waxed
with mold release wax, then sprayed with PVA release film. I applied
the Polyfiber fabric over the skis, tightened it down, painted it and
went to work with the fiberglass....e-glass, that is. Two layers of
this came out to 28-32 thousandths thick, and strong. The resulting
spats weigh about 20 ounces each. I just wish the skis were
relatively light as well....that'll come next.
Lynn Matteson
Jabiru 2200, #2062
use vacuum
heat is
can
Noel
N369LM |
Guy Buchanan
Posted: Sun Jan 23, 2011 8:39 am Post subject: Composites and mold work |
On 1/23/2011 2:51 AM, great bear wrote:
| Quote: | I definitely agree that
vacuum bagging parts is a waste of material and time for the projects we are
doing...if you were building one of rutans space planes or 50 foot windmill
props I could see a reason....but fuel tanks and speedcuffs, cowling..little
fairings....not worth the time and extra material..
Hi. Would you please put your full name, location and aircraft type /
status in your signature line? We, the moderators, find it makes for a
much more congenial atmosphere. Thanks.
Regarding vacuum bagging. It is far more expensive but I recommended it
based on a suggestion of sharp corners in the part. There's no way to
get female corners sharp in a contact laminate, and male corners are
deucedly hard. (Though it can be done with some crude tooling.) Glasairs
and Lancairs and most other composite kit aircraft were designed very
carefully to avoid vacuum bagging, with all the sharp corners in the
provided kit parts.
Guy Buchanan - List moderator
Ramona, CA
Deceased K-IV 1200
Pat Reilly
Posted: Sun Jan 23, 2011 9:03 am Post subject: Composites and mold work |
James, The problem is once you have that many tools you either can't find them or can't remember if you have a specific tool. Hell, I got divorced 11 years ago, and sold virtually all my tools at that time. In the last 6 years I once again have accumulated a hanger and a garage full of tools, often duplicated because if I need it at home the tool is at the hanger and visa versa. By the way has anybody got an auto lift for sale. When I buy the hanger next to mine I have it figured out how I can install it and still get 2 planes in. I have a stick welder, wire welder and acyletlene set up. But, I still need a TIG unit if you have one you aren't using.....HA It's an addiction! But, I have been able to resist ever buying vaccume bagging equipment. And researching what vaccume bagging takes, I'll stick with West System products and hand layup.
Pat Reilly
Mod 3 582 Rebuilt
Rockford, IL
On Sun, Jan 23, 2011 at 2:12 AM, WurlyBird <james.t.trizzino(at)us.army.mil (james.t.trizzino(at)us.army.mil)> wrote:
| Quote: | --> Kitfox-List message posted by: "WurlyBird" <james.t.trizzino(at)us.army.mil (james.t.trizzino(at)us.army.mil)>
James
http://forums.matronics.com/viewtopic.php?p=327979#327979
ist Un/Subscription,
www.matronics.com/Navigator?Kitfox-List" target="_blank">http://www.matronics.com/Navigator?Kitfox-List
ronics.com/" target="_blank">http://forums.matronics.com
Matt Dralle, List Admin.
Pat Reilly
Mod 3 582 Rebuild
Rockford,IL
Lynn Matteson
Posted: Sun Jan 23, 2011 10:10 am Post subject: Composites and mold work |
The West System 5:1 pumps are great, too...IF that's what the ratio
needs to be....but I use a way to make less than the 1-ounce of mix
that one stroke of the pumps puts out. It's no big deal, but if you
need, say, a partial ounce to finish up a job, or just a small job
that will need less than an ounce, just use two equal-size cups on
the balance scales...one on each side...and put a 10-32 nut in one
cup and *carefully* pump hardener until the scales balance again.
Then add 5 nuts of the same size and pump the resin until the scales
balance again...simple math/physics, and you've cheated the waste
basket of some otherwise wasted epoxy.
Lynn Matteson
Jabiru 2200, #2062
On Jan 23, 2011, at 11:54 AM, Patrick Reilly wrote:
| Quote: | James, The problem is once you have that many tools you either
Pat Reilly
Mod 3 582 Rebuilt
Rockford, IL
N369LM |
michael.logan1(at)verizon Guest
Posted: Sun Jan 23, 2011 10:17 am Post subject: Composites and mold work |
Chrissi and Randi of the Cozy Girrrls
(http://www.cozygirrrl.com/menupage.htm) have developed a low cost vacuum
bagging process that is pretty cool and does not cost much in wasted
materials. I watched them makes some pieces at Sun-n-Fun last year and it
really works.
Mike Logan
Series 5 RAM EA81
