Posted: Fri Jan 21, 2011 9:52 pm Post subject: AFS AOA flap switch |
I don't understand why I have a Ray Allen flap position sensor which doesn't replace the flap switch for the AOA. Seems like a software issue which could supercede the hardware issue.
Anyone have pictures of the AOA flap switch installed.
I have the Ray Allen flap sensor already completed.
amekler
Posted: Sat Jan 22, 2011 3:42 am Post subject: AFS AOA flap switch |
John,
I have the Ray Allen POS12 flap sensor. It displays the flap position on the AFS EFIS as well as gives the info to the AOA, It has nothing to do with the flap switch which does not connect into the AFS EFIS.
Alan
From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of John Gonzalez
Sent: Saturday, January 22, 2011 12:47 AM
To: RV 10 group
Subject: AFS AOA flap switch
| Quote: | | http://www.matronics.com/Navigator?RV10-List | 0123456789
18.09 KB |
6213 Time(s) |
rleffler
Posted: Sat Jan 22, 2011 4:35 am Post subject: AFS AOA flap switch |
Alan,
I’ve not seen anyone mount the POS12 like you did. I like it!
bob
From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Alan Mekler
Sent: Saturday, January 22, 2011 6:36 AM
Subject: RE: AFS AOA flap switch
John,
Alan
To: RV 10 group
_________________ Bob Leffler
N410BL - Phase I
amekler
Posted: Sat Jan 22, 2011 4:48 am Post subject: AFS AOA flap switch |
It wasn’t my idea but I don’t remember who on the forum came up with it.
Alan
From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Bob Leffler
Sent: Saturday, January 22, 2011 7:22 AM
Alan,
bob
John,
Alan
To: RV 10 group
[quote] http://www.matronics.com/Navigator?RV10-List http://forums.matronics.com http://www.matronics.com/contribution
Posted: Sat Jan 22, 2011 5:41 am Post subject: AFS AOA flap switch |
Does this look familiar? [img]cid:1C33A638-4382-4C89-90F3-6DB637A0958A(at)myhome.westell.com[/img]
On Jan 22, 2011, at 7:45 AM, Alan Mekler wrote:
| Quote: | st1\:*{behavior:url(#default#ieooui) } <![endif]--> <![endif]--> <![endif]-->
Alan
From: owner-rv10-list-server(at)matronics.com (owner-rv10-list-server(at)matronics.com) [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Bob Leffler
Alan,
bob
From: owner-rv10-list-server(at)matronics.com (owner-rv10-list-server(at)matronics.com) [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Alan Mekler
John,
Alan
From: owner-rv10-list-server(at)matronics.com (owner-rv10-list-server(at)matronics.com) [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of John Gonzalez
To: RV 10 group
Michael Kraus
n223rv(at)wolflakeairport.net (n223rv(at)wolflakeairport.net)
1.13 MB |
6209 Time(s) |
Posted: Sat Jan 22, 2011 7:27 am Post subject: AFS AOA flap switch |
John, I don't have a photo handy but the AOA switch just tells the
EFIS when the flaps are down. Mine triggers when they're about 1/3
down.
Yes, I suppose the software might be able to pick the data off the
position sensor but I don't mind that the AOA has a redundant system
in that respect.
Dave Saylor
AirCrafters
140 Aviation Way
Watsonville, CA 95076
831-722-9141 Shop
831-750-0284 Cell
On Fri, Jan 21, 2011 at 9:47 PM, John Gonzalez <indigoonlatigo(at)msn.com> wrote:
| Quote: | I don't understand why I have a Ray Allen flap position sensor which doesn't
amekler
Posted: Sat Jan 22, 2011 7:56 am Post subject: AFS AOA flap switch |
Mike,
Thanks. It works great!
Alan
From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Michael Kraus
Sent: Saturday, January 22, 2011 8:29 AM
Subject: Re: AFS AOA flap switch
Does this look familiar? [img]cid:image001.jpg(at)01CBBA22.85AA3550[/img]
Alan
Alan,
bob
John,
Alan
To: RV 10 group
012345678
Michael Kraus
135.6 KB |
6202 Time(s) |
Posted: Sat Jan 22, 2011 10:22 am Post subject: AFS AOA flap switch |
Dave, I think everyone except you misunderstood what I was trying to say. My flap position device(ray allen pos 12) is in place. I need a photo which show the the AOA switch. My mind is trying to grasp how to make the which through when it has less than 1/4" travel when all the other areas on the flap mechanism travel much greater distances.
I guess I might be able to use it on the inside of the arc on the flap servo arm(closer to the rotation point)
JOhn
| Quote: | From: dave.saylor.aircrafters(at)gmail.com
Date: Sat, 22 Jan 2011 07:15:50 -0800
--> RV10-List message posted by: Dave Saylor <dave.saylor.aircrafters(at)gmail.com>
down.
in that respect.
Dave Saylor
AirCrafters
140 Aviation Way
831-722-9141 Shop
831-750-0284 Cell
> Thanks
> John
Posted: Sat Jan 22, 2011 11:36 am Post subject: AFS AOA flap switch |
This is what I did. I riveted a tab on the flap mechanism and mounted the switch on the bulkhead behind the flap weldments (see photos).
On Jan 22, 2011, at 1:16 PM, John Gonzalez wrote:
| Quote: | Dave, I think everyone except you misunderstood what I was trying to say. My flap position device(ray allen pos 12) is in place. I need a photo which show the the AOA switch. My mind is trying to grasp how to make the which through when it has less than 1/4" travel when all the other areas on the flap mechanism travel much greater distances.
JOhn
| Quote: | From: dave.saylor.aircrafters(at)gmail.com (dave.saylor.aircrafters(at)gmail.com)
--> RV10-List message posted by: Dave Saylor <dave.saylor.aircrafters(at)gmail.com (dave.saylor.aircrafters(at)gmail.com)>
down.
in that respect.
Dave Saylor
AirCrafters
140 Aviation Way
831-722-9141 Shop
831-750-0284 Cell
On Fri, Jan 21, 2011 at 9:47 PM, John Gonzalez <indigoonlatigo(at)msn.com (indigoonlatigo(at)msn.com)> wrote:
> Thanks
> John
Michael Kraus
528.4 KB |
6190 Time(s) |
496.37 KB |
6190 Time(s) |
Posted: Sat Jan 22, 2011 11:43 am Post subject: AFS AOA flap switch |
This might be a better picture. [img]cid:28591404-0B70-44F1-B09E-39949917C0C3(at)myhome.westell.com[/img]
JOhn
down.
in that respect.
Dave Saylor
AirCrafters
140 Aviation Way
831-722-9141 Shop
831-750-0284 Cell
> Thanks
> John
Michael Kraus
1 MB |
6190 Time(s) |
Posted: Sat Jan 22, 2011 4:26 pm Post subject: AFS AOA flap switch |
IIRC, mine uses a cam attached to the torque tube. The OD of the cam
lobe doesn't go all the way around the travel.
I'll have the whole thing apart for the annual next month. Let me
know if that's not too late for a photo.
Dave Saylor
AirCrafters
140 Aviation Way
831-722-9141 Shop
831-750-0284 Cell
On Sat, Jan 22, 2011 at 10:16 AM, John Gonzalez <indigoonlatigo(at)msn.com> wrote:
JOhn
> To: rv10-list(at)matronics.com
> down.
> in that respect.
> Dave Saylor
> AirCrafters
> 140 Aviation Way
> 831-722-9141 Shop
> 831-750-0284 Cell
> > doesn't
> > could
> > Thanks
> > John
