Ianrat
Joined: 31 Mar 2008 Posts: 43 Location: Brisbane AUSTRALIA
Posted: Sun Jan 09, 2011 3:05 am Post subject: OAT Sensor |
Where is the best position to install an Out Side Temp Probe on a 601 XL.
Thank you
Ianrat
CH 601 XLB
Brisbane Australia
jeffrey_davidson(at)earth Guest
Posted: Sun Jan 09, 2011 7:04 am Post subject: OAT Sensor |
Under the saddle in the bulkhead is protected from the direct sun, not
readily visible, and exposed to direct outside air.
Jeff Davidson
jaybannist(at)cs.com Guest
Posted: Sun Jan 09, 2011 8:10 am Post subject: OAT Sensor |
Ian,
I mounted my OAT probe inside the right NACA intake fiberglass molding. I figured it would have adequate outside air, not be affected by cowling temps nor the exhaust stream and would be out of the sunlight. It is also a short wiring run from the probe to my Dynon, which has an OAT readout. .
Jay
138.74 KB |
6187 Time(s) |
bryanmmartin
Posted: Sun Jan 09, 2011 1:33 pm Post subject: OAT Sensor |
That's where I put mine also.
On Jan 9, 2011, at 11:07 AM, jaybannist(at)cs.com wrote:
| Quote: | Ian,
Jay
_________________ --
Bryan Martin
do not archive. |
Ianrat
Posted: Mon Jan 10, 2011 1:49 pm Post subject: Re: OAT Sensor |
Thank you.
I think I will go with the inlet position. This will keep the wiring short and also out of the way.
Ianrat
CH 601 XLB
Brisbane Australia.
