aurbo(at)ak.net Guest
Posted: Wed May 03, 2006 5:46 am Post subject: RV7-List Digest: Silicon dab in elevators - how important i |
Jon,
Don't drill out the elevator, you will likely do more damage than the lack of silicon will cause. If your elevator does crack, and that is only a maybe, then you can fix it later. Build on.
Mike Ice RV-9 fuselage, installing tail wheel
Anchorage, Alaska
| - The Matronics RV7-List Email Forum - | | Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
http://www.matronics.com/Navigator?RV7-List |
Posted: Wed May 03, 2006 6:37 pm Post subject: RV7-List Digest: Silicon dab in elevators - how important i |
Dog67(at)aol.com wrote:
Quote: | Help!
I'm slowly working my way thru my elevator only to realize i did the final
riviting before I put a dab of silicone or sealant between the stiffeners.
How important is this? Should I drill out all the rivits and do it again?
jon
If you're still worried after the previous posts, try running some of
that 1/4" translucent semi-rigid tubing from the building supply into
the trailing edge from the end. On my elevators, I could slip it in past
the stiffeners. If it will fit in yours, you can force the silicone into
the tubing a couple of inches, insert the tube along the trailing edge a
measured distance to the innermost stiffener, & force the silicone out
with a little compressed air.
