Windows
fredorosa(at)gmail.com
PostPosted: Fri Dec 24, 2010 1:00 pm    Post subject: Windows Reply with quote
Hi all.  Just thought I'd break the silence with my unique window installation method.
I decided to have the windows easily removable for replacement when the time comes.
[img]cid:ii_12d1a1f39b2644ec[/img]
A 1/4" thick moulding is formed with fiberglass over the outside of window cutout.
[img]cid:ii_12d1a22352d74782[/img]
I used packaging tape as mould release.
[img]cid:ii_12d1a24ccf552b29[/img]
Rubber gasket applied to the back of the moulding.
[img]cid:ii_12d1a2627d9039dd[/img]
Window is set with 3M auto glass adhesive.
[img]cid:ii_12d1a27f4e7da4e9[/img]
Moulding is attached with 8/32 ss screws and ss acorn nuts.
[img]cid:ii_12d1a2aa9a11c923[/img]
Outside view.
 Filesize:  325.92 KB
 Viewed:  3216 Time(s)
 Filesize:  341.18 KB
 Filesize:  362.97 KB
 Filesize:  442.72 KB
 Filesize:  330.79 KB
 Filesize:  388.78 KB
ftyoder(at)yoderbuilt.com
PostPosted: Fri Dec 24, 2010 2:35 pm    Post subject: Windows Reply with quote
Very nice Al!
 Filesize:  362.97 KB
 Viewed:  3213 Time(s)
 Filesize:  341.18 KB
 Filesize:  442.72 KB
 Filesize:  325.92 KB
 Filesize:  330.79 KB
 Filesize:  388.78 KB
sstearns2(at)yahoo.com
PostPosted: Sat Dec 25, 2010 6:21 pm    Post subject: Windows Reply with quote
I did basically the same thing, except I bonded the inner frame in. I can peel it out with a heat gun if I ever need to replace the window and then make a new frame pretty quickly.  I think the most time consuming part for both of us would be getting the old window out and cleaning off the 3M window adhesive.
I put some silver trim tape around the windows. I think it looks great and it saves the time of cleaning up the intersection of the window and fuselage skin.
Scott
--- On Fri, 12/24/10, ALFRED ROSA <fredorosa(at)gmail.com> wrote:
Subject: Windows
To: "kisbuilders" <kis-list(at)matronics.com>
Date: Friday, December 24, 2010, 12:56 PM
[img]cid:1.2337438798(at)web32406.mail.mud.yahoo.com[/img]
[img]cid:2.2337438798(at)web32406.mail.mud.yahoo.com[/img]
[img]cid:3.2337438798(at)web32406.mail.mud.yahoo.com[/img]
[img]cid:4.2337438798(at)web32406.mail.mud.yahoo.com[/img]
[img]cid:5.2337438798(at)web32406.mail.mud.yahoo.com[/img]
[img]cid:6.2337438798(at)web32406.mail.mud.yahoo.com[/img]
Outside view.
 Filesize:  362.97 KB
 Viewed:  3206 Time(s)
 Filesize:  341.18 KB
 Filesize:  442.72 KB
 Filesize:  325.92 KB
 Filesize:  330.79 KB
 Filesize:  388.78 KB
