JohnF
Posted: Mon Dec 20, 2010 2:45 pm Post subject: Octane degrading with storage time |
Are there any real octane enhansers readily available? I get the impression that the ones generally advertised are pretty much 'snake oil'
Second question: what lowering of octane rating can you expect in the real world? In other words, how long is 91-octane 'good' in a 912uls?
Thanks for your views.
Roger Lee
Posted: Mon Dec 20, 2010 6:29 pm Post subject: Re: Octane degrading with storage time |
Hi John,
I wouldn't keep fuel longer that 4 weeks. That's what Rotax recommends. No matter what type of container you store fuel in it will evaporate and or have octane degradation and loose other additives. Don't store any more than you will use in that time and don't fill your plane up if you plan on letting it set for months. If you plan on not flying for a couple of months just drain the fuel at a low point bleed. Octane booster won't work for us and unless you feel like throwing the dice with $10-$12k in rebuild cost then just use fresh fuel. It will drop down to to 87-88 octane before you know it. If that happens either drain and put fresh 91 oct. in or add at least 50% of 100LL.
_________________ Roger Lee
Tucson, Az.
Rotax Instructor & Rotax IRC
Light Sport Repairman
Cell 520-349-7056 |
JohnF
Posted: Mon Dec 20, 2010 6:59 pm Post subject: Octane degrading with storage time |
Thanks, Roger. I was not looking to increase octane in the mogas (91) but
wondered about 'rejuvenating' 91 that has been in the plane longer than I
would be comfortable with...says something over 3 weeks. If the weather
would cooperate I could keep the gas fresh by simply flying a lot, which is
what I want to do, but winds have been so darn bad of late that flying
wasn't worth the beating you'd take doing it. I will note your
recomendations and follow them. Thank you.
m.tucciarone(at)hotmail.c Guest
Posted: Tue Dec 21, 2010 4:26 am Post subject: Octane degrading with storage time |
?I have been flying a 912S for about 7 years now. I have had gas in the
plane for longer than 4 weeks. As soon as I buy gas, I add Stabil to it even
if I plan to fly that day. I have never had a problem. I have never seen any
varnishing in my float bowls. My engine has never even hiccupped. I learned
this at a Rotax seminar taught by Phill Lockwood.
Thom Riddle
Posted: Tue Dec 21, 2010 5:21 am Post subject: Re: Octane degrading with storage time |
I've heard this "octane degrades over time" story a lot over the years. Several years ago I researched this and found (and lost) a petroleum engineer's explanation of how gasoline goes bad over time. He explained all of this in layman's terms and debunked the "octane degrades" part, i.e. octane does not degrade. However, gasoline does go bad for other reasons. I wish I could find this but have failed to do so, so far but will keep looking.
However, I did find the following which I believe to be a reliable authoritative source (but can't guarantee that) which does not even mention octane but does describe how gasoline does go bad over time.
http://www.straightdope.com/columns/read/2668/why-does-gasoline-go-stale-so-quickly
As this source recommends, I have been adding Sta-bil to my stored gasoline beginning in the late fall when my flying frequency falls off dramatically. It works well in my experience.
_________________ Thom Riddle
Buffalo, NY (9G0)
- Anonymous |
Dick Maddux
Posted: Wed Dec 22, 2010 6:04 am Post subject: Octane degrading with storage time |
John,
I too always add Sta-bil to my fuel and it does help. .In the past I sometimes had run-on at engine shutdown with my 912 when I had "vintage' fuel in my tanks. It acted like an old car with bad gas. As an experiment I added Lucas brand octane booster to the fuel and it stopped that from happening.I have actually done this on a few occasions and for that reason I will say octane booster does work. Some brands contain alcohol so if you were decide to try it be selective as to the brand.
Best option of course is to have fresh gas but if I can't fly for awhile ,I would use the booster . There is an unknown here and that is octane booster chenicals and its effect on fiberglas tanks(in my case)
Dick Maddux
912UL
Milton,Fl
