Elevator Adjustment
kearney
PostPosted: Sun Dec 12, 2010 4:51 pm    Post subject: Elevator Adjustment Reply with quote
Hi
Today I finished fitting my empennage (love that word!) to the tail. Per the plans I checked the elevator travel up and down. The up travel is 28.5 degrees versus the 30 degrees required. This will require filing of the F1012D elevator stop and should be no problem.
The down travel however is on 22 degrees versus the required 25. This I am not sure how top correct as the limitation is where the forward push rod connects to the F635 elevator bellcrank located just aft of the baggage area in the tail. As the forward rod travels aft, the F635 contacts the end of the control tube and stops any further movement. The elevator horn still has room to move so that is not and won't be a problem.
The only solution I can think of would be to shift the F1090 control forward by screwing the froward rod end deeper into the tube and the aft rod end out. My only concern would be the amount of thread left engaged by the aft rod end.
Has anyone else had this problem and if so how did you deal with it.
Inquiring minds need to know…
Cheers
Les
#40643 [quote][b]
Jim Combs
PostPosted: Sun Dec 12, 2010 5:18 pm    Post subject: Elevator Adjustment Reply with quote
Les,
I had to quite a bit of adjusting to ALL the control rod ends in the elevator system to get things to not hit (Other than the elevator stops).  Do you have the tail cone attached to the cabin section?  I think I spend a couple of hours getting everything just right.  There are two bell cranks and the control arm at the front to deal with.
Jim C N312F (200 Hours)
On Sun, Dec 12, 2010 at 7:48 PM, Les Kearney <kearney(at)shaw.ca (kearney(at)shaw.ca)> wrote:
Hi
Cheers
Les
#40643
_blank">www.aeroelectric.com
.com" target="_blank">www.buildersbooks.com
tp://forums.matronics.com
RV-10 -> N312F - Flying as of 12/2008
Bob Turner
PostPosted: Sun Dec 12, 2010 5:25 pm    Post subject: Re: Elevator Adjustment Reply with quote
Certainly having the bellcrank hit the push tube, and limiting travel, is not right. The limit should be at the rudder horn. Have you peeked ahead to the section on rigging, to make sure that when the elevator is neutral, the bell crank is at the proper angle?
To answer your question, I've been told the minimum engagement depth for a rod end is 1.5 times the diameter of the threaded end. You need to either safety wire the rod end so it can't back out; or make certain that if you rotate the push tube the other rod end will come tight (all the way in) before this rod end falls out (or I should say comes to less than 1.5 times its diameter of falling out).
Bob Turner
RV-10 QB
daveleikam(at)wi.rr.com
PostPosted: Sun Dec 12, 2010 5:55 pm    Post subject: Elevator Adjustment Reply with quote
Hi Les,If you check section 5, you will find a max and min range for the travel. I don't have my plans with me but I think you are within the acceptable limits. I experienced the same issue until a friend told me to check section 5.
Dave Leikam.
On Dec 12, 2010, at 6:48 PM, Les Kearney wrote:
Hi
Cheers
Les
#40643
href="http://www.aeroelectric.com/">www.aeroelectric.com
href="http://www.buildersbooks.com/">www.buildersbooks.com
href="http://www.homebuilthelp.com/">www.homebuilthelp.com
David Leikam
RV10
N89DA
Kellym
PostPosted: Sun Dec 12, 2010 7:11 pm    Post subject: Elevator Adjustment Reply with quote
Put out the APB. Les has escaped the fiberglass prison. We need him back. Razz
[img]cid:part1.08090205.02010501(at)aviating.com[/img]
On 12/12/2010 5:48 PM, Les Kearney wrote:
Elevator Adjustment
Hi
Cheers
Les
#40643
 Filesize:  1.97 KB
 Viewed:  10396 Time(s)
Kelly McMullen
KCHD
jesse(at)saintaviation.co
PostPosted: Sun Dec 12, 2010 7:16 pm    Post subject: Elevator Adjustment Reply with quote
I seem to remember this as well. I think you have a little more flexibility on the nose-down elevator.
Jesse Saint
I-TEC, Inc.
jesse(at)itecusa.org
www.itecusa.org
www.mavericklsa.com
C: 352-427-0285
O: 352-465-4545
F: 815-377-3694
On Dec 12, 2010, at 8:52 PM, David Leikam <daveleikam(at)wi.rr.com> wrote:
[quote] Hi Les,
kearney
PostPosted: Sun Dec 12, 2010 7:39 pm    Post subject: Elevator Adjustment Reply with quote
Jim
My empennage (there's that word again!), spent about 2 1/2 years hanging from my garage ceiling since being built. Over the past few months I have moved to a hanger, attached the tail cone and have just attached the stabs and elevators / rudder. This was the first time any of these components have been attached.
Using the 91.4 degree template, I first adjusted the front two control rods so the bell crank was aligned correctly.
After attaching the elevators, I adjusted the rear control arm.
As it sits now, the control tube lengths are spot on perfect. The more I think about it and based on the comments received, I need to shift the middle control tube forward so it does not touch the bell crank when the tail is fully down. This should bring the elevator control arm into contact with the forward elevator stop and also give me a few degrees more travel.
Cheers
Les
From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Jim Combs
Sent: December-12-10 6:15 PM
Subject: Re: Elevator Adjustment
Les,
Hi
Cheers
Les
#40643
href="http://www.matronics.com/contribution">http://www.matronics.com/chref="http://www.matronics.com/Navigator?RV10-List">http://www.matronics.com/Navigator?RV10-List
kearney
Hi Dave
I checked my section 5 and didn't find anything related to elevator travel. That being said, I still need to deal with the bell crank being the limiting factor. I agree with Bob Turner's comments in this regard.
If the 28.5 degree up travel is okay, I will avoid filing the elevator stop. I still have about 1/4" clearance on the front stop so I should be able to get the missing 3 degress of down travel. I just hope I can adjust the rod ends enough to make this happen.
Cheers
Les
From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of David Leikam
Sent: December-12-10 6:52 PM
Hi Les, If you check section 5, you will find a max and min range for the travel. I don't have my plans with me but I think you are within the acceptable limits. I experienced the same issue until a friend told me to check section 5.
Dave Leikam.
Hi
Cheers
Les
#40643
David Leikam
RV10
N89DA
rv10rob(at)gmail.com
PostPosted: Sun Dec 12, 2010 7:42 pm    Post subject: Elevator Adjustment Reply with quote
Relevant section of the doc attached.  As an aside, I found out about this doc only a few weeks ago.  Apparently I didn't get it and the W&B doc in whatever kit they usually come in.
-Rob
On Sun, Dec 12, 2010 at 7:12 PM, Jesse Saint <jesse(at)saintaviation.com (jesse(at)saintaviation.com)> wrote:
Jesse Saint I-TEC, Inc.
www.itecusa.org
www.mavericklsa.com
C: 352-427-0285
O: 352-465-4545
F: 815-377-3694
On Dec 12, 2010, at 8:52 PM, David Leikam <daveleikam(at)wi.rr.com (daveleikam(at)wi.rr.com)> wrote:
Dave Leikam.
Hi
Cheers
Les
#40643
David Leikam
RV10
N89DA
http://www.matronics.com/contribution">http://www.matronics.com/contribution
ums.matronics.com">http://forums.matronics.com
"_blank">www.aeroelectric.com
.com/" target="_blank">www.buildersbooks.com
Rob Kochman
RV-10 "Finishing" Kit
Woodinville, WA (near Seattle)
http://kochman.net/N819K
 Filesize:  83.84 KB
 Viewed:  10395 Time(s)
kearney
PostPosted: Sun Dec 12, 2010 8:05 pm    Post subject: Elevator Adjustment Reply with quote
Kelly
I am on day parole. I still have lots of F/G to do but needed to visit some AL tools for a while.
Cheers
Les
From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Kelly McMullen
Sent: December-12-10 8:06 PM
[img]cid:833030004(at)13122010-34FE[/img]
Hi
Cheers
Les
#40643
 Filesize:  1.97 KB
 Viewed:  10394 Time(s)
kearney
PostPosted: Sun Dec 12, 2010 8:26 pm    Post subject: Elevator Adjustment Reply with quote
Rob
Many thanks. I am well within the limts which is good to know. I will call Van's tomorrow and ask about the WB docs as well (as I didn't get them either).
Cheers
Les
From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Rob Kochman
Sent: December-12-10 8:38 PM
-Rob
www.itecusa.org
www.mavericklsa.com
C: 352-427-0285
O: 352-465-4545
F: 815-377-3694
Dave Leikam.
Hi
Cheers
Les
#40643
David Leikam
RV10
N89DA
Rob Kochman
Bob Turner
PostPosted: Sun Dec 12, 2010 9:19 pm    Post subject: Re: Elevator Adjustment Reply with quote
W&B docs (and limits, etc) come with the finishing kit.
Bob Turner
RV-10 QB
kearney
PostPosted: Mon Dec 20, 2010 4:47 pm    Post subject: Elevator Adjustment Reply with quote
Hi
Well, I spoke t Van's a few days ago and spoke to Joe who was most helpful. Today I was at the hanger and was able to "adjust" the problem away by moving the center push tube forward so the conical end does not contact the bell crank. IN doing so, the elevator horn now touches the forward stop. Problem solved!
Joe did give me a a "Plan B" in case this did not work. He suggested scabbing an extra piece of AL onto the forward stop so it contacts the elevator horn before the push tube / elevator problem came into play.
Merry Christmas to all.
Les
#40643
Hi
Cheers
Les
#40643
