Matt Dralle Site Admin
Joined: 08 Nov 2005 Posts: 27563 Location: Livermore CA USA
Posted: Sun Nov 21, 2010 12:27 pm Post subject: Test Flight Video - Part 2 - Landing... |
This Part II of my RV-8 Test Flight documents slow flight testing and landing configuration testing, a couple more circuits around the airport, landing, taxi back, and returning to the hangar.
Note that on the taxi back, the windsock is almost a direct crosswind at about 10 knots as I recall. Makes me even more proud of that first landing, and the fact that I put it right down on the numbers!
Be sure to check out Part I of this video which documents the startup, taxi out, take off, and first circuit around the field.
This Video is in full 1080p HDTV, so be sure to select a viewing resolution that works with your computer and is higher than the standard 360p default. At least the 760p mode, for example. And don't forget to try full-screen mode for the most impact!
http://www.youtube.com/user/MattsRV8#p/u/1/2b4C8fb-XAc
Enjoy,
Matt
RV-8 #82880 N998RV
http://www.mattsrv8.com - Matt's RV-8 Construction Log
Status: 124+ Hours TTSN - The Fun Never Stops...
108.48 KB |
1767 Time(s) |
_________________ Matt Dralle
dickseiders(at)gmail.com Guest
Posted: Mon Nov 22, 2010 7:12 am Post subject: Test Flight Video - Part 2 - Landing... |
Matt, what kind of a recorder are you using to capture the audio?
Thanks for feedback.
Dick Seiders
On Sun, Nov 21, 2010 at 3:23 PM, Matt Dralle <dralle(at)matronics.com (dralle(at)matronics.com)> wrote:
Enjoy,
Matt
RV-8 #82880 N998RV
Posted: Mon Nov 22, 2010 7:20 pm Post subject: Test Flight Video - Part 2 - Landing... |
The video in the cockpit and on the ground was shot with Sony HDR-CX550v HD camcorders ( www.sonystyle.com/product/en/hdrcx550v ). The audio was captured with the camcorder using its Audio Line Level input plugged into the "rear passenger 1 headphone output" (not the co-pilot output which is connected to the RV-8's rear passenger headphones) from the PS Engineering 3000 intercom though a homemade impedance matching circuit. The PS3000 mixes the Comm/Intercom/Music nicely and Music audio pull-down during Comm/Intercom is being done by a combination of the PS3000 and the auto-gain control on the camcorder. I installed a 1/8" stereo jack in the backseat area on the right side (see attached pictures). If I were going to do it again I would definitely go with a pair of RCA-style line-level bulkhead jacks instead of the 1/8" stereo jack. I've had some trouble with the right-channel cutting in and out because of the jack/vibration. RCA's would hold much tighter.
RV-8 #82880 N998RV
At 07:09 AM 11/22/2010 Monday, you wrote:
| Quote: | Matt, what kind of a recorder are you using to capture the audio?
Dick Seiders
On Sun, Nov 21, 2010 at 3:23 PM, Matt Dralle <<mailto:dralle(at)matronics.com>dralle(at)matronics.com> wrote:
<http://www.youtube.com/user/MattsRV8#p/u/1/2b4C8fb-XAc>http://www.youtube.com/user/MattsRV8#p/u/1/2b4C8fb-XAc
Enjoy,
Matt
153.71 KB |
1755 Time(s) |
108.09 KB |
1755 Time(s) |
