kentpyle(at)iland.net Guest
Posted: Fri Nov 12, 2010 1:39 pm Post subject: Fuel Leaks |
If you have been following this for a while, you are aware that I have been chasing fuel leaks for a few years. I learned from this exhange that fuel would creep through the wing skins. I didn't know that and thought I had new leaks.
Earlier in the week, I fixed a fuel drip in a quick drain and now there is not further leaks, seeps or drips. Apparenty, fuel was creeping through the skin and coming to the surface where I thought the leaks were. Oh! Happy Day!!
Kent
| - The Matronics KIS-List Email Forum - | | Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
gbrighton(at)skymesh.com. Guest
Posted: Sun Nov 14, 2010 4:09 am Post subject: Fuel Leaks |
Yeah ..something to think about .. fuel migrating through the honeycomb skin... I have (and the previous owner ) a mystery fuel smell in the cockpit when the tank levels are high ...have searched every where but never found a stain or any wetness .... annoying, but nothing ever found visible .... as yet .!!!
Graham
TR1 s/n 80
galinhdz(at)gmail.com Guest
Posted: Sun Nov 14, 2010 6:53 am Post subject: Fuel Leaks |
Once in a while I have had a "mystery fuel smell in the cockpit" that seemed to come from the co-pilot side but haven't been able to figure it out. It also seemed to happen more often, but not always, when the tanks were very full.
I just completed a conditional inspection yesterday and found the hose between the fuel tank and the fuselage on the co-pilot side had a tiny crack in it. Nothing seeping until I wiggled it around firmly. Then a drop of fuel would form. I replaced the hoses on both sides with new ones. My A&P said that on some other airplanes, these hoses are replaced every 5yrs.
Since I will be flying from Houston to Puerto Rico via Savannah, Tampa and Miami starting next week I will get a good opportunity to see if the "mystery smell" will finally go away.
Galin
N819PR
On Sun, Nov 14, 2010 at 6:07 AM, Graham Brighton <gbrighton(at)skymesh.com.au (gbrighton(at)skymesh.com.au)> wrote:
[quote] Yeah ..something to think about .. fuel migrating through the honeycomb skin... I have (and the previous owner ) a mystery fuel smell in the cockpit when the tank levels are high ...have searched every where but never found a stain or any wetness .... annoying, but nothing ever found visible .... as yet .!!!
Graham
TR1 s/n 80
Posted: Sun Nov 14, 2010 7:55 am Post subject: Fuel Leaks |
Galin, I used the fuel hoses that have the steel mesh incorporated into the hose. Hopefully this will prevent the leaks in that area.
By the way, I was talking to my mechanic about fuel leaks. He said how would you know it was an airplane, if you couldn't smell fuel.
Kent
Posted: Sun Nov 14, 2010 3:33 pm Post subject: Fuel Leaks |
HAHAHA I like your mechanic's point of view which is so true!
My mechanic told me to stay away from wing/in-line filters if possible. They just insert another possible failure point in the fuel line. More lines clog at a filter than anywhere else. He says a properly designed fuel system with a good gascolator is more than sufficient unless you have fuel injection which is another story.
Galin
N819PR
On Sun, Nov 14, 2010 at 9:54 AM, kent pyle <kentpyle(at)iland.net (kentpyle(at)iland.net)> wrote:
[quote] Galin, I used the fuel hoses that have the steel mesh incorporated into the hose. Hopefully this will prevent the leaks in that area.
Kent
