jason(at)hills.org Guest
Posted: Tue Nov 09, 2010 11:37 pm Post subject: Fuel level sender repair? |
Last night I tracked down problems with my left fuel level to the sender in the tank. The sender is a Westach 395-5S (http://www.aircraftspruce.com/catalog/inpages/westfuelqty2.php) or similar. I've confirmed the wiring to it is good, but the output resistance "never" changes as the fuel level changes (it is known to work intermittently actually, and based on the reading I'm seeing, I suspect that the probe is shorting out when it stops working).
So, not having built this plane, I don't really know if replacement is realistic or not... I suspect the probe is secured inside the wing/tank towards the inboard end of the tank, plus the head is bolted to the outboard end of the tank (accessible through an inspection plate). My best guess is that the top of the wing would have to be cut into to gain access to the far end and then the top of the wing would have to be re-glassed and painted. Yikes!
I'm not about to do this myself, but conceivably I could have my A&P who worked at Glassair in the past do it (i.e. he's pretty good with glasswork, even if he prefers working on RV's).
I've lived with this issue for a long time, but having just installed a new engine monitor (JPI EDM 740) getting the fuel probes setup and working was a major ordeal, and now I should be able to get fairly accurate tank readings compared to the old analog gauge which was basically only really good for "full", "empty" or "somewhere in between". I finally got the EDM talking to the right tank last night and confirmed that the left tank was not behaving the same as the right as I added/removed fuel.
Any recommendations?
Thanks!
..Jason
| - The Matronics KIS-List Email Forum - | | Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
richard_trickel(at)yahoo. Guest
Posted: Wed Nov 10, 2010 3:36 am Post subject: Fuel level sender repair? |
Jason
The outboard end of the probe is probably not secured. I would unbolt it at the root and try to pull it out before mas surgury.
The big problem is replacing the probe in to the holes through the ribs. this really bepends on how long your probe is.
Rich
--- On Wed, 11/10/10, Jason Hills <jason(at)hills.org> wrote:
Quote: |
Subject: Fuel level sender repair?
To: kis-list(at)matronics.com
Date: Wednesday, November 10, 2010, 7:25 AM
--> KIS-List message posted by: Jason Hills <jason(at)hills.org (jason(at)hills.org)>
Any = this year's Terrific Free Incentive Gifts provided
fredorosa(at)gmail.com Guest
Posted: Wed Nov 10, 2010 6:50 am Post subject: Fuel level sender repair? |
Jason,
If you have a capacitance fuel probe, the head is bolted to the outside of the innermost rib. Take off the underneath wing/fuselage fairing and you will see it.
How far the actual probe goes through the wing was the option of the builder. It could end anywhere along the length of the fuel tank. Mine goes through the entire length of the tank. Removing the probe is easy if the wing is off but I never tried it with the wing on. Don't know if it's possible. My probes were from Skysports and since my airplane isn't flying, I can't tell you how well it's working. Hope this helps.
Al
On Wed, Nov 10, 2010 at 2:25 AM, Jason Hills <jason(at)hills.org (jason(at)hills.org)> wrote:
[quote] --> KIS-List message posted by: Jason Hills <jason(at)hills.org (jason(at)hills.org)>
Thanks!
..Jason
="_blank">www.aeroelectric.com
ooks.com" target="_blank">www.buildersbooks.com
et="_blank">www.homebuilthelp.com
le, List Admin.
rget="_blank">http://www.matronics.com/Navigator?KIS-List
http://forums.matronics.com
Keith.Miller(at)esa.int Guest
Posted: Wed Nov 10, 2010 8:38 am Post subject: Fuel level sender repair? |
if the probes are installed from the inboard section going outwards then it
would be impossible to extract the long probes from the wing without
removing the wing first . The probes themselves are most likely not
straight since for the probes to work correctly they had to be bent
downwards so they touched the bottom of the wing then bent upwards so they
went to the top of the outboard section .
Much will depend on how the original builder installation was made ,but it
should be possible to remove them and bend new ones up and install . last
resort would be cut anything open
Keith
Date: 10/11/2010 15:52
Subject: Re: Fuel level sender repair?
Sent by: owner-kis-list-server(at)matronics.com
Jason,
will see it.
Al
painted. Yikes!
Thanks!
...Jason
le, List Admin.
Thanks! I guess I had just assumed the far end would be clamped or bolted somehow to secure it. If it's "just" running through holes in the ribs maybe there is some tiny chance of a replacement without major surgery.
Mine must be setup a little oddly, as the head is on the outboard end, not at the wing root. Probably means the probe is both long and unlikely to be able to really indicate empty.
...Jason
On Nov 10, 2010, at 3:19 AM, Richard Trickel wrote:
[quote]Jason
Rich
--- On Wed, 11/10/10, Jason Hills <jason(at)hills.org (jason(at)hills.org)> wrote:
Quote: |
From: Jason Hills <jason(at)hills.org (jason(at)hills.org)>
[/url] | [url=http://forums.matronics.com/]
ftyoder(at)yoderbuilt.com Guest
Posted: Wed Nov 10, 2010 9:24 am Post subject: Fuel level sender repair? |
As I recall, some did put them in the wing tip so they could be easily replaced. Maybe Rich did that. I think it was also described as a instillation option in the instructions. I believe they are touted as pretty reliable. I have had no trouble with mine in 12 years of use.
Posted: Wed Nov 10, 2010 10:10 am Post subject: Fuel level sender repair? |
I put mine in the inboard rib close to the fuselage. In the three planes I built in the states they rarly worked right or at all. I hated them and praised the person who designed the clock since it was reliable.
Rich
Date: Wednesday, November 10, 2010, 5:14 PM
