hansjd(at)online.no Guest
Posted: Sun Oct 17, 2010 9:13 am Post subject: Fuel Pressure Indication |
During my studying in order to rectify my too high fuel pressure indication (which for my 914 installation most probably is caused by a restriction - one way or another - in the fuel return line), I'm astonished to (re)learn that there is no requirement from Rotax to install a fuel pressure instrument.
The Installations Manual states: "There is no standard connection provided to measure the fuel pressure. For general observation and at engine troubles fuel pressure readings would be helpful". The text further describes how to go about fitting of an extra banjo bolt etc.
In other words: It's entirely up to the builder - or to follow local country requirements - to install such an indicator.
Nevertheless: The Rotax Operations Manual issue a warning (page 2-4) which says: "Exceeding the max admissible fuel pressure will override the float valve of the carburetor and to engine failure".
I would say that a check of the pressure would be damned "helpful" in this respect! Or, how would I know at all of any ill funktion before the donkey elects to stop over the biggest lake in Norway???
Now, can someone explain to me why the Rotax factory has such an indifferent approach to this issue in the Installations Manual, while the Operations Manual "paints the devil on the wall" in pointing out the dangers. And, there is no follow up whatsoever in procedures or check lists for high fuel pressure, as with other abnormalities. In other words: Rotax issue a Warning based on an abnormality you wouldn't stand a chance to know - if you didn't find it "helpful" to install the indicator system!
This can't be right!
Hans
LN-HJD, #334
rlborger(at)mac.com Guest
Posted: Sun Oct 17, 2010 12:27 pm Post subject: Fuel Pressure Indication |
Hans,
Tried to find the documentation from Rotax requiring the installation and use of the "Fuel/AirBox Differential Pressure Gauge" but can't find it right now.
In any case, Rotax now requires that a gauge and sensor system be installed to monitor the differential between fuel pressure and airbox pressure to ensure there is always sufficient fuel pressure to overcome airbox pressure in the carbs preventing fuel starvation issues. It also allows detection of excess fuel pressure which can cause the problems you already described.
UMA makes the system. I know that it is available from Aircraft Spruce:
http://www.aircraftspruce.com/catalog/inpages/umafuelairbox.php
And is probably available from other vendors as well.
Good luck in solving your fuel pressure problems. As you previously stated, there is probably some restriction in your fuel return.
Check six,
Bob Borger
Europa Kit #A221 N914XL, XS Tri-Gear, Intercooled 914, Airmaster C/S Prop
http://www.europaowners.org/forums/gallery2.php?g2_itemId=60232
http://www.biplaneforumgallery.com/index.php?cat=10046
Europa Flying!
3705 Lynchburg Dr.
Corinth, TX 76208
Home: 940-497-2123
Cel: 817-992-1117
On Oct 17, 2010, at 12:10, Hans J. Danielsen wrote:
Quote: | During my studying in order to rectify my too high fuel pressure indication (which for my 914 installation most probably is caused by a restriction - one way or another - in the fuel return line), I'm astonished to (re)learn that there is no requirement from Rotax to install a fuel pressure instrument.
Hans
LN-HJD, #334
budyerly(at)msn.com Guest
Posted: Sun Oct 17, 2010 12:41 pm Post subject: Fuel Pressure Indication |
<?xml:namespace prefix="v" /><?xml:namespace prefix="o" /><![endif]--> Hans,
You are right that they do not have a requirement, spelled out, but it is implied. Rotax does have parts for it and information is in the new Rotax installation manual. Copy attached (check currency), page 69.
I follow their instruction requirements very closely. Part numbers are in the parts catalogue.
UMA does make a pressure differential gauge to measure airbox vs. fuel pressure. I can do the math so I just use the raw fuel pressure and manifold pressure.
Explanation: My normal fuel pressure is 4-5psi. When I go to boost I glance at it to see if the pressure rose IAW the boost.
We know that 29.92 in HG is 14.7 psi so 2 inches of Hg is about 1 psi. ISH OK.
Example: On takeoff, at a boost pressure of 40 inches, that is 10 inches over atmosphere (that's 5 psi ish) so the fuel pressure must be above 2.3 ish min plus 5 psi or a min of 7.3 to keep the fuel going to the carbs to prevent fuel starvation as the operations and installation manuals state..
If I cruise at a fuel pressure of 5 psi at 30 inches MP at low altitude, that is OK, if I climb at 34 inches I'm looking for 6 ish and on takeoff, 8.
I don't cruise at high altitude normally, but as you climb, the outside pressure decreases and that lowers the fuel pump inlet head a bit, so as you climb your MP or outside pressure is around 17 inches HG at 15,000 MSL. (Remember, you loose 1 in HG per 1000 or so.) That means outside air pressure is 8-9 psi or so in round numbers below sea level pressure of 29.92 inches or 14.7 PSI. If you push the MP above 30 inches then, the engine may start to see some fuel starvation, so turn on the other pump when going above 10,000 and you can run max continuous power up to 15000 or so. Above 15,000 I haven't gone, but I imagine that one has to pay attention. Let's see. MP gauge reads 34 inches at 15,000 feet, minus 17 is 17 inches HG and that is about 8 psi, so 2.3 plus 8 is 10.3 at the fuel pressure meter... That needs both pumps to do, and it does it well.
So install a good MP gauge and a descent fuel pressure gauge or buy one of the UMA differential gauges and press on. I prefer to know my raw pressure. It is a preference for troubleshooting. When my math skills go, I'll buy the other gauge I guess.
Hope this wasn't too confusing. Check my math, I am getting older.
Bud Yerly
Custom Flight Creations, Inc.
Description: |
 Download |
Filename: |
914_Installationmanual_d03186.pdf |
Filesize: |
2.79 MB |
Downloaded: |
4878 Time(s) |
Posted: Tue Oct 19, 2010 2:53 am Post subject: Fuel Pressure Indication |
Thanks to those who supplied me with informations on this subject. To Bud: I'm aware of the additional parts spelled out in the Installations manual, I also have installed a fuel pressure instrument - otherwise i wouldn't have detected my problem (too high fuel pressure)!
My issue was the lack of coherence between the installations and operations manuals. (To give the builder an advice of an indicator system which "is nice to have" in one, while the other spells out danger if you experience a condition you would know nothing about - if you did not follow the advice).
Now - this is not the airlines (my background), but I'm pretty sure they would detect and correct such a mismatch immediately.
This is definitely a safety related issue and should be adressed by Rotax the sooner the better (to ammend the istallations manual to REQUIRE a fuel pressure indications system).
As to my problem: I sorted it yesterday. It was of course a pinched hose in there, and it was quite a feat to repair it! Now everything is nice and green again.
Hans, LN-HJD, #334
[quote] [b]
