klburris
Posted: Sat Oct 16, 2010 12:36 pm Post subject: Harbor Freight Riveter problems |
Folks;
If someone understands why Zenith uses flush blind rivits and reforms them
in the riviting process to a 'domed head' rivit, please elaborate on the
reasons.It just seems to me (yes, it's true, I'm a noobe and haven't started
a plane yet) that it would be much simpler to just use domed head pull
rivits - or maybe that's a dumb assumption.
Thanks in advance.
-- Keith
grs-pms(at)comcast.net Guest
Posted: Sat Oct 16, 2010 12:50 pm Post subject: Harbor Freight Riveter problems |
Hello, Keith:
I remember reading Chris Heintz' explanation of his use of modified Avex
rivets, some years back. He had a good reason for doing so. I'm sure a
call to the factory would get you the information. Perhaps it's in an old
issue of Zenith News.
George Swinford
Posted: Sat Oct 16, 2010 1:12 pm Post subject: Harbor Freight Riveter problems |
Hi Keith,
The domed heads have advantage as the head is drawn from a recess head to
the domed condition. The rivet grips aluminum better long term as the
strength is increased during the draw. The aircraft is not
a fast destination plane in general terms. The domed heads don't add drag to
any extent for the speeds we require, at least 150 mph or less. The thin
materials that are used in Zenith aircraft would also look
excessively bumpy between flush rivets. I used .020 and .025 to get around
the issue and improved surfaces in the sheet aluminum. This is not uncommon
even in flush riveted standard aircraft either if you look closely.
Repair of pulled rivets is considerably easier. Poorly set pulled rivets
can easily be drilled out where dimpled flush rivets as solid types present
more serious issues for repair. Once you get into it, you realize the
rivets don't really subtract from the plane. If you feel flush rivets are a
better solution, you should really consider building a RV or other type
designed for them. Do expect to spend a lot more time in the build process.
Best regards,
Z601c(at)anemicaardvark.c Guest
Posted: Sat Oct 16, 2010 1:17 pm Post subject: Harbor Freight Riveter problems |
On Saturday 16 October 2010 15:28:13 you wrote:
Folks;
started a plane yet) that it would be much simpler to just use domed head
pull rivits - or maybe that's a dumb assumption.
Thanks in advance.
My understanding was that flush blind rivets (specifically, Avex rivets) were
used to simplify construction. The domed head was to increase the strength, by
pulling the body of the rivet tighter.
Mind you, I'm out of my area of expertise. That's just what I remember.
Jim B. Belcher
BS,MS Physics, Math, Computer Science
A&P/IA
General Radio Telephone Certificate
Instrument Rated Pilot
Retired Aerospace Technical Manager
paulrod36(at)msn.com Guest
Posted: Sat Oct 16, 2010 3:12 pm Post subject: Harbor Freight Riveter problems |
<?xml:namespace prefix="v" /><?xml:namespace prefix="o" /><![endif]--> yes, there really is a reason. It was written somewhere in Zenith's pages, can't remember where. They recommend using countersunk rivets and the domed puller head so that, as the head is rounded, it work-hardens the rivet head. Makes it tougher.
Paul R
flyadive(at)gmail.com Guest
Posted: Sat Oct 16, 2010 3:24 pm Post subject: Harbor Freight Riveter problems |
Good Question Keith;
But WHY domed rivets at all! Dimple the skin and rib and use FLAT HEAD.
That is what I would like to do --- I will be making the cal or sending an email to find out WHY NOT!
Barry
On Sat, Oct 16, 2010 at 4:28 PM, <klburris(at)frontiernet.net (klburris(at)frontiernet.net)> wrote:
| Quote: | --> Zenith-List message posted by: <klburris(at)frontiernet.net (klburris(at)frontiernet.net)>
Folks;
If someone understands why Zenith uses flush blind rivits and reforms them in the riviting process to a 'domed head' rivit, please elaborate on the reasons.It just seems to me (yes, it's true, I'm a noobe and haven't started a plane yet) that it would be much simpler to just use domed head pull rivits - or maybe that's a dumb assumption.
Thanks in advance.
-- Keith
target="_blank">http://www.matronics.com/Navigator?Zenith-List
http://forums.matronics.com
le, List Admin.
Barry
"Chop'd Liver"
jeffrey_davidson(at)earth Guest
Posted: Sat Oct 16, 2010 4:22 pm Post subject: Harbor Freight Riveter problems |
At least part of it is that when the head is reshaped as it is pulled with
the modified rivet head, the metal is work hardened and becomes stronger.
Jeff Davidson
klburris
Posted: Sun Oct 17, 2010 9:38 am Post subject: Harbor Freight Riveter problems |
Hey guys;
Thanks for all the replies. The knowledge here is great.
-- Keith
