n4546v(at)mindspring.com Guest
Posted: Fri Oct 15, 2010 8:02 am Post subject: Harbor Freight Riveter/how to alter nose piece |
Here's one from the archives:
I am wondering the best way to modify the head for the domed rivets. What
is the best way to do this???
From the Zenith archives:
The Dremel works fine and fast, use a small green round ball (silicon
carbide) or any other stone that has a point or round end, Put the riviet
gun head in the lathe chuck and while spinning it, fire off the moto-tool,
hold it with both hands braced against whatever is nearby, and shape the end
in a nice conical shape, starting from the hole in the center and working
outward, keep the cone shallow, you can always go deeper. No gottem lathe?
Sure you do, put your fastest turning pistol grip drill motor in your
workbench vise, usually upside down with pistol grip up, (up is towards the
sky for you airplane builders!) tighten vise enough to hold drill case, not
crushing it where the armature will never turn again! Place the rivet head
in the drill chuck and lock the trigger back and grind away. Takes longer
to describe than to do, finish with emery cloth if your stones grind course.
Hope this helps.
Randy, Las Vegas, 701/plans
tigerrick(at)mindspring.c Guest
Posted: Fri Oct 15, 2010 9:55 am Post subject: Harbor Freight Riveter/how to alter nose piece |
Jeez, I feel so low tech!
Posted: Fri Oct 15, 2010 10:52 am Post subject: Harbor Freight Riveter/how to alter nose piece |
There was supposed to be more to that post!
I ended up making the initial dome in the nosepiece from simply and carefully starting with the tip of a suitable drill bit chucked up in a drill press, with the nosepiece firmly held in a vise on the stage. Final finish was easy with the nosepiece lightly chucked in the drill press, and a bit of emery cloth applied to the dome.
Am I making it too simple?
Rick
Z601c(at)anemicaardvark.c Guest
Posted: Fri Oct 15, 2010 11:11 am Post subject: Harbor Freight Riveter/how to alter nose piece |
I don't think so. I've been wondering why everyone went to so much trouble,
but was reluctant to comment.
I bought the pneumatic riveter from Zenith, and had no problems. However, I
modified a hand pop riveter to pull rivets in tight areas. For it, I installed
the head in the hand held riveter, and carefully installed it in a drill vise,
with the head facing upwards.
I picked a drill bit whose end seemed to be a reasonable match to the
curvature of the Zenith heads. I cut away metal from the head in the hand
riveter, until it looked like a reasonable match for the Zenith head. I've
been using that to pull the hard to reach rivets without difficulty (other than
my hands cramping, etc).
The emery cloth would have been a good idea, but for whatever reason, I didn't
think of it.
It might be worth mentioning that I cut away parts of the hand riveter, so it
would fit in some of those tight places.
On Friday 15 October 2010 13:49:49 you wrote:
<tigerrick(at)mindspring.com>
<snip of previous emails>
Jim B. Belcher
BS,MS Physics, Math, Computer Science
A&P/IA
General Radio Telephone Certificate
Instrument Rated Pilot
Retired Aerospace Technical Manager
Posted: Fri Oct 15, 2010 11:24 am Post subject: Harbor Freight Riveter/how to alter nose piece |
Hey Rick:
Your method is simple and completely legal as sanctioned by the Kitchen Sink
Technology Institute.
Where a problem could arise is if one runs into heat treated nose pieces.
They could be case hardened (a very hard skin say .008" deep) or through
hardened. I don't know if any are. But if they are, both heat treat
methods could be as hard or harder than your HSS drill. Abrasives don't
care about steel hardness for the most part.
Randy, Las Vegas
Rick
Posted: Fri Oct 15, 2010 11:58 am Post subject: Harbor Freight Riveter/how to alter nose piece |
Given the "bargain" nature of the Chinese made, disposable tools we're working with here, cutting into the nosepiece was a snap. Even the chrome plating didn't slow down the cutting of the bit much. But OK. I did cheat and use some cutting oil.
As soft as the nosepieces are, the rivets are even softer! Good thing!
Rick
psm(at)att.net Guest
Posted: Fri Oct 15, 2010 1:47 pm Post subject: Harbor Freight Riveter/how to alter nose piece |
Hi Rick,
This has been a wonderful exchange. It shows that there are no right or wrong answers to some of the challenges we face as isolated builders.
I think the nose piece modification demonstrates how this really is a learning experience for all of us. We all used what tools we had at hand to accomplish a similar task. If the resulting rivets are set properly then we all accomplished the goal. Bravo!
Paul
Camas, WA
