Fwd: iPad Mount update
flysrv10(at)gmail.com
PostPosted: Thu Sep 23, 2010 4:00 pm    Post subject: Fwd: iPad Mount update Reply with quote
I decided to relocate my iPad after my a flight test last weekend. I found the previous location a little too distant for my taste. I think the most ideal position is at eye level where John Miller has installed his. Hopefully the Gizmo guys will come up with a panel mount and give those in process of planning their panel another option.
I swapped the 2" standard clamp leg with a 6" long leg from Ram Mount (they are great people to deal with) and I think that I like this arrangement much better. The second picture shows the iPad in it's pilot-exit configuration. Will post a flight test report this weekend.
[img]cid:B7B47C67-B360-4723-B023-71E6C38EFB62[/img]
[img]cid:C9EC74F5-9A39-4EB1-87C2-ABEA01D766A0[/img]
[img]cid:04D2ED35-275D-4726-9FBA-52B83B13F452[/img]
Begin forwarded message:
From: Rob Kermanj <flysrv10(at)gmail.com (flysrv10(at)gmail.com)>
Date: September 13, 2010 6:17:08 PM EDT
Subject: iPad Mount
Reply-To: rv10-list(at)matronics.com (rv10-list(at)matronics.com)
I finally received my iPad mount from Ram Mounts. It is a good quality and strong mount.
I used a sheet of aluminum and formed it around the tunnel to use as a temporary bracket and to mount the iPad. Once flight testing t is complete, I will most likely remove the extra aluminum bracket and attach the mount with thru bolts to the tunnel cover.
I have pointed the iPad's charging port up under the panel; so that I can get a 12V charger and connect it behind the panel to charge continuously during flights.
Flight test, this weekend.
[img]cid:D1EFDAA2-7C60-45D8-BB73-35FD84B6F65C[/img]
[img]cid:7CEAB0A6-A98C-4B75-B4D3-A8FF2FDFA112[/img]
 Filesize:  48.72 KB
 Viewed:  6904 Time(s)
 Filesize:  42.59 KB
 Viewed:  6903 Time(s)
 Filesize:  54.17 KB
 Filesize:  57.87 KB
 Filesize:  32.25 KB
Deems Davis
PostPosted: Thu Sep 23, 2010 6:49 pm    Post subject: Fwd: iPad Mount update Reply with quote
Deems Davis
PostPosted: Fri Sep 24, 2010 6:35 am    Post subject: Fwd: iPad Mount update Reply with quote
Kelly McMullen
PostPosted: Fri Sep 24, 2010 7:06 am    Post subject: Fwd: iPad Mount update Reply with quote
Hey good buddy, got yor ears on? You is shootin' blanks.
On Fri, Sep 24, 2010 at 7:28 AM, Deems Davis <deemsdavis(at)cox.net (deemsdavis(at)cox.net)> wrote:
Kelly McMullen
A&P/IA, EAA Tech Counselor
KCHD
Tim Olson
PostPosted: Fri Sep 24, 2010 7:28 am    Post subject: Fwd: iPad Mount update Reply with quote
He's got something funky with his email program. I am
trying to pull it apart now and see if there is an attachment
to view. But here is the text I extracted. I noticed the message
had size, but just wasn't displaying....
<From Deems>
Rob, Thanks for the update, I've been following a thread on VAF that
is similar. I've flown about 40 hours with my Ipad, and have a pretty
good feel for how I use it (VFR). Today, I spent 30 + minutes in the
cockpit trying to identify the 'optimum' mounting location. The
Ram-Mount hardware is VERY impressive.
It was hard to find a location that both provides excellent access, AND
didn't interfere with another cockpit function. (I really like the way
my panel is laid out and don't want to compromise it) I came to the
conclusion that for me, a hard mount isn't the best bet. I've got moving
map gps/efis on the panel with approaches, etc. I'm only flying the
plane VFR now, so the main use for me is:
Pre-flight planning (means that it's got to be easily removable). I'm
not keen about having the 'empty mounting gear
Electronic POH _ I've got options on Primary and backup EFIS for
checklists, but I've converting my POH to a pdf, that I have on the IPAD
Sectional scanning - My EFIS only zooms out to 200 miles, and it doesn't
provide the ability to 'scroll' around and see what the surrounding
landscape holds
Flight Guide Replacement Airport info - With the changes to pricing for
the hard copy, it's really convenient to have it all in the IPAD.
So most of my usage is intermittent while in flight. I like being able
to grab the IPAD and do whatever I need to do, and then put it out ot
the way. When I need it it's really convenient to have visible with a
hands free view. (my wife is getting tired of 'here, hold this'). I
have a center console, that is now pretty empty , with all of the
charts, POH, and Flight Guide removed. So I think the solution for me,
is to fabricate a kneeboard-holder, that serves as a "platform" where I
can set/rest the Ipad when I need the information/function handy, (e.g.
airport/rwy data landing & TO) and my hands free. I'll make it with an
angle that allows for best viewing /access, but I'll probably put some
'non-skid' material on the back of it, and the knee-pad so that it can
be easily rotated and stored in the center console when its just in the way.
Deems
<mailto:deemsdavis(at)cox.net>> wrote:
Tim Olson
PostPosted: Fri Sep 24, 2010 7:42 am    Post subject: Fwd: iPad Mount update Reply with quote
After reading Deems's email I have to say that I didn't
want to even reply before, because I don't want to knock
anyones install, but I personally feel that I love
my panel layout. I wouldn't WANT an ipad on the panel.
I think it would be a pain in the butt to use in flight
on the panel and I think even hard mounted it would be
a pain in the butt in turbulence when you need it.
I think a mount might be nice as a holder, but for in
flight USE I think just hand-holding is great. It's
just a reference device....the panel holds all the real
navigation gear.
I do like holding it, and like being able to hand it
to the wife or kids, and if I were going to mount it
anywhere, it would be as a kneeboard. Although as
a kneeboard it's a little large. But, personally I
feel it's far more important to have a good place to
handily STOW it than it would be to mount it.
Other than that, it's the ideal cockpit sized device.
On the panel though I think it would really suck
in bumps.....there are days I can't even push the
buttons on my radios or turn a knob without
my hand bouncing around hitting the wrong thing....a
touchscreen would be miserable.
Tim Olson - RV-10 N104CD
sean(at)stephensville.com
PostPosted: Fri Sep 24, 2010 7:59 am    Post subject: Fwd: iPad Mount update Reply with quote
I think this has already been linked before. It seems a bit pricey,
but it *is* an "aviation" product. Smile
http://www.forpilotsonly.com/ipad.htm
-Sean
navigation gear.
Robin(at)PaintTheWeb.com
PostPosted: Fri Sep 24, 2010 8:32 am    Post subject: Fwd: iPad Mount update Reply with quote
I was at the Apple store yesterday and saw a cool iPad accessory that
converts the iPad to a back of the head rest mounted display (straps
around the headrest). An obvious choice for car rides or rear pax video
entertainment in a -10. Plus a good place to store it. Out of the way but
handy.
Robin
Tim Olson
PostPosted: Fri Sep 24, 2010 9:45 am    Post subject: Fwd: iPad Mount update Reply with quote
Now that is a NEED for me! I'll have to quick find out
about that and order one up for this trip!
handy.
Robin
Tim Olson
PostPosted: Fri Sep 24, 2010 10:09 am    Post subject: Fwd: iPad Mount update Reply with quote
Was it this one by chance?
http://www.zoogue.com/
Looks like they're sold out right now, but after Oct 14th
they are going to have more.
Some insane turkey on eBay marked them up 4X, too....nice...
http://cgi.ebay.com/IPAD-CASE-CAR-Headrest-mount-ZooGue-Smart-Case-seat-/110563554818?pt=LH_DefaultDomain_0&hash=item19be19f602
How do people think they'll fool someone that way?
handy.
Robin
PostPosted: Fri Sep 24, 2010 11:05 am    Post subject: Fwd: iPad Mount update Reply with quote
I have seen the Zoogue. It is a bit bulkier than I like but it does much more than the one I saw because it's a "convertible" much like the official apple case but I was not a fan of the Velcro portion
