Eric_Kallio
Joined: 29 Jan 2006 Posts: 149 Location: Baton Rouge, LA
Posted: Fri Aug 20, 2010 9:40 am Post subject: Nose fork lube |
I have been reviewing the plans regarding the nose wheel assembly. On the fork we install a zerk/grease fitting on the front, and plug the top, haven't found reference to servicing. I am going to use the same Aeroshell lube as the wheel bearings unless anyone has found a better solution.
Eric Kallio
