VOR Antenna Experiment - report
AirMike
PostPosted: Tue Aug 17, 2010 10:05 pm    Post subject: VOR Antenna Experiment - report Reply with quote
In building my RV10, I decided to bury my VOR antenna (running my Garmin SL30) in the upper front area of the cabin top using a thin copper tape that Vans sells as an antenna. I had checked it out on the Fallon NV VOR some time back, and it drove the NAV functions ok, but due to my phase 1 flight restrictions, I could not do an ILS over populated areas. Anyway today I did the Reno NV ILS and I was sorry to find quite a few anomalies as well as a general lack of sensitivity. By the way, it was pretty cool when the controller asked me to keep my speed up for a trailing 737, that we could run down the ILS at 165 kts.
At this point I do not think that I will mess with the Bob Archer thing. Looks like ugly or not that there are some cat whiskers in my RV10's future
Now the real question. Put it on top of the Vertical Stab or under the tail cone? Any suggestions on reception or sensitivity appreciated
See you OSH '18
Q/B - sold.
TimRVator(at)comcast.net
PostPosted: Wed Aug 18, 2010 2:44 am    Post subject: VOR Antenna Experiment - report Reply with quote
FWIW, I used an Archer antenna on my -6A and my -10. I've had no
problems using either for LOC or ILS approaches.
Tim Lewis -- HEF (Manassas, VA)
RV-6A N47TD -- 1090 hrs
RV-10 N31TD -- First Flight 20 Mar 2010
AirMike said the following on 8/18/2010 2:05 AM:
OSH '10 or Bust
Q/B - finally done
http://forums.matronics.com/viewtopic.php?p=309236#309236
bcondrey
PostPosted: Wed Aug 18, 2010 7:22 am    Post subject: VOR Antenna Experiment - report Reply with quote
"me too" I've got an Archer in each wingtip and have zero reception issues on any sort of VOR/LOC/GS tracking. With that said, they are apparently very sensitive to the installation, how wiring to other wingtip stuff is routed, etc. If you follow the install instructions to the letter you'll have great success otherwise... I've got one antenna feeding an SL-30 and the other feeding a GNS-430W.
The Archer comm antenna is a different story - nobody reports great success and even Bob Archer himself will tell you that they don't work well.
Bob
RV-10 N442PM
Tim Olson
PostPosted: Wed Aug 18, 2010 7:50 am    Post subject: VOR Antenna Experiment - report Reply with quote
Sorry to hear about the homebuilt antenna. At least
it's truly experimental then though.
I see probably 20% better reception with my whiskers
than the Archer. That's not to say the archer is
bad, but if you're really planning to use it for
approaches and stuff, I would say don't compromise
on reception and all and risk having something that
is easily shadowed in one direction like that.
The archer would probably work ok much of the time,
but the people that are huge proponents are more
that way because they like the cost and hidden aspect,
and that it basically works...but they're not necessarily
concerned with getting the absolute best receiving
antenna that they can get. It's personal choice
on priorities. I figure though that when you're
in the clouds on an approach, I'm not willing to
sacrifice the quality of reception on a navigational
antenna. Things like APRS antennas are non-critical,
and those are better served to prioritizing the
hidden aspect over performance if you choose.
Tim Olson - RV-10 N104CD
ILS at 165 kts.
RV10's future
appreciated
-------- OSH '10 or Bust Q/B - finally done
Kelly McMullen
PostPosted: Wed Aug 18, 2010 12:08 pm    Post subject: VOR Antenna Experiment - report Reply with quote
Since the Glideslope is rarely usable beyond 10nm, and you normally aren't using it beyond 5nm, signal strength should not be an issue. And you are not going to be in more than a 15 degree bank on an ILS(lets hope) so directional blanking should never be an issue. Only if you are using the VOR at great distance, say 100nm is signal strength going to be a big issue.  Given most are using GPS for primary and VOR for secondary nav, max signal strength to the VOR receiver really should not be an issue. As long as there isn't strobe or other electrical interference with the Archer antenna, it should be a non-issue for navigation. Even the cat whisker antennas are expensive, and the blade antennas are obscene in price.
On Wed, Aug 18, 2010 at 8:41 AM, Tim Olson <Tim(at)myrv10.com (Tim(at)myrv10.com)> wrote:
[quote] --> RV10-List message posted by: Tim Olson <Tim(at)myrv10.com (Tim(at)myrv10.com)>
-->  RV10-List message posted by: "AirMike"<Mikeabel(at)Pacbell.net>
ILS at 165 kts.
RV10's future
appreciated
le, List Admin.
Kelly McMullen
A&P/IA, EAA Tech Counselor
KCHD
Bob Turner
PostPosted: Wed Aug 18, 2010 5:45 pm    Post subject: Re: VOR Antenna Experiment - report Reply with quote
I'd guess the only localizer issue would be if you are, say, 10 miles out, and vectored onto the localizer with a 30 degree intercept that requires the wingtip antenna to look through the fuselage to "see" the localizer antenna. e.g., airport to your right if the antenna is in the left wing tip.
Can anyone comment on this scenario? Real world, is it an issue?
Bob Turner
RV-10 QB
AirMike
PostPosted: Wed Aug 18, 2010 9:36 pm    Post subject: VOR Antenna Experiment - report Reply with quote
I appreciate all of the thoughtful responses to my comments ( especially Tim L, Tim O, and Kelly). We asked Reno APP for vectors to the ILS. They essentially sent us in a teardrop pattern. Approaching from close to the airport we had some reception problems at 90 degrees off our rt wingtip - presumably the wingtip blanketing the signal.
Then the N to So. approach is VERY long due to the Sierra Mtns at 8000 to 10000 ft to the west. Reno sits at 4200 ft. At 5-6 miles and on in (Loc & G/S) there was no problem. It was out a ways like Kelly said on the intercept and even after the intercept (10-12 miles) that the signal was erratic. Reno is a real acid test of these antennas.
See you OSH '18
Q/B - sold.
MauleDriver(at)nc.rr.com
PostPosted: Thu Aug 19, 2010 6:55 am    Post subject: VOR Antenna Experiment - report Reply with quote
This raises the question I keep wanting to ask of the G430W folks flying
IFR - Are you still routinely and primarily flying precision approaches
using the ILS or RNAV? At controlled airports, do they gdefault to the
ILS or RNAV for vectored approaches? Can you freely use either when
available?
I haven't been flying in the system for a couple of years now and have
never seen/touched a precision RNAV approach. Just wondering what
reality is like out there now.
Bill "really wanting to fly this thing" Watson
OSH '10 or Bust
Q/B - finally done
http://forums.matronics.com/viewtopic.php?p=309356#309356
robertbrunk(at)mac.com
PostPosted: Thu Aug 19, 2010 7:39 am    Post subject: VOR Antenna Experiment - report Reply with quote
i general fly rnav approaches with vectors. they work great. robert
On Aug 19, 2010, at 9:53 AM, Bill Mauledriver Watson wrote:
This raises the question I keep wanting to ask of the G430W folks flying IFR - Are you still routinely and primarily flying precision approaches using the ILS or RNAV? At controlled airports, do they gdefault to the ILS or RNAV for vectored approaches? Can you freely use either when available?
I haven't been flying in the system for a couple of years now and have never seen/touched a precision RNAV approach. Just wondering what reality is like out there now.
Bob Turner
PostPosted: Thu Aug 19, 2010 9:13 am    Post subject: Re: VOR Antenna Experiment - report Reply with quote
At most (all?) airports around here ATC will let you fly whatever approach you want, except for maybe opposite to the traffic direction. Even then they often let you do it, asking you to break off and circle early (if vfr) for opposing traffic reasons.
Bob Turner
RV-10 QB
jesse(at)saintaviation.co
PostPosted: Thu Aug 19, 2010 12:06 pm    Post subject: VOR Antenna Experiment - report Reply with quote
They always give me whichever I ask for. I usually do the rnav.
Jesse Saint
I-TEC, Inc.
jesse(at)itecusa.org
www.itecusa.org
www.mavericklsa.com
C: 352-427-0285
O: 352-465-4545
F: 815-377-3694
On Aug 19, 2010, at 10:53 AM, Bill Mauledriver Watson <MauleDriver(at)nc.rr.com> wrote:
PostPosted: Thu Aug 19, 2010 1:29 pm    Post subject: VOR Antenna Experiment - report Reply with quote
When I was flying non-precision RNAV approaches, it was still 'awkward'
to get properly vectored or cleared for them. They controllers tended
to not be familiar with the T-style approaches at non-controlled
airports. The overlays worked fine. Never even tried to do an RNAV
non-precision at a controlled AP - just took vectors for the ILS.
Do you ever do the ILS for something other than proficiency?
Jesse Saint
I-TEC, Inc.
www.itecusa.org
www.mavericklsa.com
C: 352-427-0285
O: 352-465-4545
F: 815-377-3694
PostPosted: Fri Aug 20, 2010 6:51 am    Post subject: VOR Antenna Experiment - report Reply with quote
Actually, now that you mention it, I do remember one time that I was flying a non-precision GPS approach and when I asked for vectors to final, the controller said she didn't have the final approach fix on her map. That pretty much blew me away, but she cleared me to final anyway. I just had to get there by myself. That was actual conditions, and my first flight in actual conditions, but it all worked out well.
I will do an ILS if there is no precision RNAV/GPS and the conditions may require it, although I realize there may be very few of those left, and for proficiency. Very few of my flights actually require an approach, but I often ask for an approach just to keep current and proficient. I don't fly as much as I'd like to, which is likely the case for most of us.
Jesse Saint
Saint Aviation, Inc.
jesse(at)saintaviation.com
C: 352-427-0285
F: 815-377-3694
On Aug 19, 2010, at 5:27 PM, Bill Mauledriver Watson wrote:
When I was flying non-precision RNAV approaches, it was still 'awkward' to get properly vectored or cleared for them. They controllers tended to not be familiar with the T-style approaches at non-controlled airports. The overlays worked fine. Never even tried to do an RNAV non-precision at a controlled AP - just took vectors for the ILS.
> Jesse Saint
> I-TEC, Inc.
> www.itecusa.org
> www.mavericklsa.com
> C: 352-427-0285
> O: 352-465-4545
> F: 815-377-3694
> Sent from my iPhone
>>> Read this topic online here:
pilotdds(at)aol.com
PostPosted: Fri Aug 20, 2010 7:04 am    Post subject: VOR Antenna Experiment - report Reply with quote
My home airport defaults to ILS for vectors.The waas approaches are very cool but that extra 50 feet often makes a differnce in our tule fog.I woud be curious to here the CA central coast guys chime in.-Jim loving waas but still defaulting to ILS when possible
PS they will give you waas when you ask for it but if they {norcal} is busy at all you will get delaying vectors or a hold if weather is IMC..Just my 2 cents
