		dennisvh
				 Posted: Mon Aug 21, 2006 6:44 pm    Post subject: RPM drop Problem |
				I have a 1946 Ercoupe with a 85 HP (started as a 75HP) Continental engine with a 200 RPM drop on the right mag at run-up.  Mechanics have 100% eliminated as the problem both mags, all plugs, P-leads, and switch.  Also, the engine ran fine for 25 hours after a new ignition harness was installed.  The new harness was checked out yesterday on the engine and appears to be ok on all wires.  We don't where to go next.  Any advice will be appreciated.  Thanks, Dennis Hatfield.
  |  | - The Matronics Engines-List Email Forum - |  |   |  Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
  http://www.matronics.com/Navigator?Engines-List |
		Bob Buckthal
				 Posted: Mon Aug 21, 2006 8:28 pm    Post subject: RPM drop Problem |
				Dennis,
 Something that you think is OK isn't.  You didn't mention timing.  A late
 mag will produce a big drop.
 Bob
		jrccea(at)bellsouth.net Guest
				 Posted: Mon Aug 21, 2006 8:29 pm    Post subject: RPM drop Problem |
				The timing may have slipped on one mag.
 dennisvh wrote:
		cubflyr(at)comcast.net Guest
				 Posted: Tue Aug 22, 2006 6:39 am    Post subject: RPM drop Problem |
				 	  | Quote: | 	 		  The timing may have slipped on one mag.
 That was the first thing to pop into my mind, everything else being checked.
 Are the mags new or recently overhauled and reinstalled? Sometimes things
 can shift. It would be unlikely for a Woodruff key to be missing, but not
 impossible. This would allow a gear to shift. You may have to pull the mags
 and check them out, as well as to make sure they are installed with the
 timing mark in the correct place on the drive gears. It would be odd for
 this to be it as it sounds like it just started after being normal for a
 while. Something has moved out of place, most likely in the mags or gear
 drive.
 I recently put in a new set of ($20 each) spark plugs only to find after
 about 20 hours one was faulty. Have them pressure checked. If they are
 leaking, you can see blow-by gas products in the wiring harness end of the
 plug.
 Michael
				 Posted: Wed Aug 30, 2006 11:45 am    Post subject: RPM drop Problem |
				Dennis: did you ever arrive at a cause/solution for your RPM drop?
		margdon
				 Posted: Wed Aug 04, 2010 2:35 pm    Post subject: Re: RPM drop Problem |
				Hi my guess is a pour spark on two cylinders. Change plugs. Don
		qaz11
				 Posted: Wed Sep 01, 2010 2:20 am    Post subject: Re: RPM drop Problem |
				Try replacing the idle air control. But maybe try this test before you do. Sitting in the drive way, turn the steering wheel. The idle should go up. If it does not then it may be that the pressure sensor on the power steering pump is bad.
 Idle air control failure does not always show up with a check engine light coming on. Some times they do get dirty and others claim that they can be cleaned. But by the time you get into clean it why not replace it.
 The other things that may be wrong, there is a part on the throttle sensor that keeps the idle high for a little while before letting it drop down. It is called a throttle damping valve. The throttle position indicator may not be registering a return to idle. The temp sensor may not be telling the ecm what the actual temp of the engine is. But I have never seen these parts fail, the idle air control I have seen fail.
  Life Insurance Calculator | Life Insurance Comparison
