Model II Weight and Balance
Ken Potter
PostPosted: Sun Aug 01, 2010 4:07 am    Post subject: Model II Weight and Balance Reply with quote
Hi Folks;
I weighed and my plane yesterday and did the W&B calculation. The forward CG is ok, but the aft CG (at full load) is .3" outside the limit. Question, how sensitive is the KF to aft CG conditions. To trim this small amount out and reweigh will be a real pain.
Cheers
Ken
Ken Potter
Model II, No. 483
Rotax 582, C-Box,
99% Complete
C-FJKP
Lanark, Ontario
poasttown(at)yahoo.com
PostPosted: Sun Aug 01, 2010 4:51 am    Post subject: Model II Weight and Balance Reply with quote
Ken
I'm not sure this is an answer to your question but when I finished my model four back in 1996, with a Rotax 582, I had to add five piunds of lead shot up against the firewall to get my W&B correct. Since then I have changed to a Jabiru 2200 and I removed the lead shot.
Mike Chaney
--- On Sun, 8/1/10, Ken Potter <kjpotter(at)sympatico.ca> wrote:
Subject: Model II Weight and Balance
Date: Sunday, August 1, 2010, 8:08 AM
--> Kitfox-List message posted by: "Ken Potter" <kjpotter(at)sympatico.ca (kjpotter(at)sympatico.ca)>
Hi Folks;
Cheers
Ken
Ken Potter
Model II, No. 483
Rotax 582, C-Box,
99% Complete
C-FJKP
Lanark, Ontario
http://forums.matronics.com/viewtopic.php?p=307024#30702om/Navigator?Kitfox-List" target=_blank>http://www.matronics.com/Navigatosp; - MATRONICS WEB FO/" ; -Matt Dralle, List Admin==========
dave
PostPosted: Sun Aug 01, 2010 5:07 am    Post subject: Re: Model II Weight and Balance Reply with quote
Ken ,
I would re-weigh -- and re-check numbers again.
Some Kitfox had the c o G range extended AFT but I not sure what model.
Is your numbers are accurate as well as your scales ?
.3 is not alot and what was it solo?
What weights did you use for persons? 170 or actual ?
You must not have a dash tank? The dash tank would help this alot
Hundreds of Kitfox Movies
Most viewed Kitfox on youtube
Most popular on youtube
Highest rated on youtube
Ken Potter
PostPosted: Sun Aug 01, 2010 5:48 am    Post subject: Re: Model II Weight and Balance Reply with quote
Dave,
The scales I used belong to EAA chapter 245 in Ottawa and are relatively new. I checked them with a test weight and they were + - 1 lb.
My plane is one of the later model II's with the 1.5 gal tank behind the seat. The battery is mounted forward on the rear side of the firewall. The only piece of equipment not on board was my Garmin 296 GPS but that is mounted right under the datum line anyways.
One thing I didn't mention is that the plane has come out relatively heavy at 550 lbs empty, probably from my full polyfibre paint treatment.
As per the instructions in the original Denny manual for full gross weight aft CG calculation, I used me in the pilot seat and weights in the pax seat to bring it up to gross of 950. That's the calculation which came out as .3" aft of limit. The pilot only (fwd CG) came out well within limits.
I'm going to re-crunch the numbers this morning just to double check the calculations. If I need weight forward I'll just install a larger battery. Better to have that weight providing some benefit.
Cheers
Ken
Ken Potter
Model II, No. 483
Rotax 582, C-Box,
99% Complete
C-FJKP
Lanark, Ontario
Tom Jones
PostPosted: Sun Aug 01, 2010 6:57 am    Post subject: Re: Model II Weight and Balance Reply with quote
Pat, work up one weight and balance sheet with a loading that puts the CG right at the aft limit and another that puts it at the forward limit. Keep these in the plane to show if asked at a ramp check.
Adding weight to stay within the CG limits is productive only if it allows the payload to increase too.
Tom Jones
Classic IV
Ellensburg, WA
dave
PostPosted: Sun Aug 01, 2010 7:07 am    Post subject: Re: Model II Weight and Balance Reply with quote
Ken,
Do you have a excel sheet that you can input numbers on ?
Reason I ask is that did you actually measure everything or did you use someone else's numbers.
550 lbs is heavy for a model 2 ------
I would bet that you will be ok flying it.
Ken Potter
PostPosted: Sun Aug 01, 2010 7:18 am    Post subject: Re: Model II Weight and Balance Reply with quote
Dave,
I measured the main gear moment (2.375") and the tail wheel moment myself on the actual A/C. I'm going out to re-measure again as I trust the scales and think that a miss-measurment, especially of the tailwheel moment could have given me the .5 inch out of limit in the full gross state.
I have excel but I've also rechecked my calculations, and other than one small mistake, they check out. The only other thing I can think of is that I did the full gross calcuation with the behind-the-seat fuel tank full.... but then, that tank is full when in flight anyways so in my mind should be included.
Cheers
Ken
Ken Potter
Model II, No. 483
Rotax 582, C-Box,
99% Complete
C-FJKP
Lanark, Ontario
dave
PostPosted: Sun Aug 01, 2010 7:48 am    Post subject: Re: Model II Weight and Balance Reply with quote
KEn, I hope these numbers might help you but this is for my IV model
Notice my Empty weight was for before the last paint job but still light and great performer. It makes me wonder where some Kitfox get so heavy but you can see why their performance sucks.
Skystar Kitfox Model IV ( 4) ser. #1717 C-FDUG
WEIGHT AND BALANCE FOR AIRCRAFT Wheels orig copy Installed
THE DATUM : Leading Edge of wing
Leveling Means: Bubble level on longitudinal fuselage floor tubing below the cabin
Maximum Gross Weight:1050
Forward CG limit 11.37 Aft CG limit 16.00
ALL WEIGHTS IN LBS, DISTANCES IN INCHES and AFT (unless marked "-")
PART ONE
(EMPTY WEIGHT DATA)
IF YOU DON'T KNOW, GO TO PART TWO
ENTER EMPTY AIRCRAFT WEIGHT HERE = 520 LBS
ENTER AIRCRAFT EMPTY CG HERE = 12.95 IN.
ENTER EMPTY MOMENT HERE = 6734 INCH/LBS
CALCULATED EMPTY AIRCRAFT MOMENT = 6734 INCH/LBS
PART TWO
(CALCULATING EMPTY WEIGHT DATA)
FIGURING EMPTY WEIGHT CG.
MAIN WHEELS DATA WEIGHTS
RIGHT MAIN WHEEL WEIGHT = 244 LBS
LEFT MAIN WHEEL WEIGHT = 242 LBS
MAIN WHEEL DISTANCE FROM DATUM = 2.9 IN.
MAIN WHEEL MOMENT = 1409.4 INCH/LBS
CALCULATED MAIN WHEEL MOMENT = 1409.4 INCH/LBS
TAIL WHEEL/NOSE WHEEL DATA
TAIL/NOSE WHEEL WEIGHT = 34 LBS
NOSE WHEEL DISTANCE FROM DATUM= 156.6 IN.
NOSE MOMENT IF KNOWN = INCH/LBS
CALCULATED TAIL/NOSE MOMENT = 5324.4 INCH/LBS
TOTAL WEIGHT = 520 LBS
CG MOMENT
EMPTY WEIGHT CENTER OF GRAVITY DATA 12.95 IN 6734 INCH/LBS AFT of datum
FIGURE FINAL CG BELOW
ENTER THE FOLLOWING AS NEEDED
SUBJECT WEIGHT X ARM X MOMENT
AIRCRAFT EMPTY WEIGHT = 520 X 13.29 X 6884.22 INCH/LBS
PILOT WEIGHT = 170 X 18.3 X 3111 INCH/LBS
PASSENGER WEIGHT = 170 X 18.3 X 3111 INCH/LBS
FUEL WEIGHT (7.2 LBS/GAL) = 56 X -8 X -448 INCH/LBS
OIL WEIGHT (1.9LBS/QT) = 3.8 X -21 X -79.8 INCH/LBS
BAGGAGE WEIGHT = X 30 X 0 INCH/LBS
Wing tanks (7.2 LBS/GAL) 72 X 16.5 X 1188 INCH/LBS
ELT 3.3 X 0 X 0 INCH/LBS
First Aid Kit 1.5 30
X X 0 INCH/LBS
TOTALS 996.6 LBS 13766.42 INCH/LBS
AIRCRAFT CENTER OF GRAVITY = 13.81 INCHES Aft of DATUM
Equipment list included in Weight and Balance report as required by CARS 549.13 Equipment and Instruments
Additional Equipment List:
ELT, First aid kit Added to Weight and Balance report
MAINTENANCE SCHEDULE STATEMENT
The described maintenance has been performed in accordance with the applicable airworthiness requirements
Date:_______________
____________________________________
(Signature)
akflyer
PostPosted: Sun Aug 01, 2010 8:09 am    Post subject: Re: Model II Weight and Balance Reply with quote
if it is anything like the Avid, the CG range is very conservative. Dean Wilson told me that I could safely go back to 19" or so, and it would fly better. He said not to stall it at more than 20" without using flaps or I may never get the nose back down in time.
I flew mine at 18" and the performance was much better. No running out of elevator in the flair. Slow flight and STOL was much better at 18" versus the more forward CG mine comes in at empty.
DO NOT ARCHIVE
Leonard Perry aka SNAKE
Soldotna AK
Avid "C" / Mk IV
IVO IFA
Full Lotus 1450
Tom Jones
PostPosted: Sun Aug 01, 2010 8:54 am    Post subject: Re: Model II Weight and Balance Reply with quote
Pat, just to be sure you didn't forget it. Did you remember to subtract the tare weight from the tail wheel weight?
Tom Jones
Classic IV
Ellensburg, WA
MichaelGibbs(at)cox.net
PostPosted: Sun Aug 01, 2010 9:20 am    Post subject: Model II Weight and Balance Reply with quote
Ken sez:
limit.
How did you accomplish a "full load"? Did you have weight in the
baggage area to reach "full"? This might just indicate that you
cannot have that much behind the seats when operating at higher
weights in the real world.
If, on the other hand, you only had weight in the seats and the CG
moves past the aft limit before reaching maximum gross weight, you
may have to resort to adding ballast.
Mike G.
N728KF, Kitfox IV-1200 Speedster
Phoenix, AZ
Ken Potter
PostPosted: Mon Aug 02, 2010 7:57 am    Post subject: Re: Model II Weight and Balance Reply with quote
Thanks everyone for your help on this one. I re-weighed the plane and it came in almost exactly as before for empty weight. When I re-measured the tail wheel moment I discovered that I had measured 1 1/2" to long. After re-running the calculation it is now just under the max aft CG at max gross of 950 lb.
Because the plane is 25lb heavy I guess I'll have to lose weight myself to compensate.
Cheers
Ken
Ken Potter
Model II, No. 483
Rotax 582, C-Box,
99% Complete
C-FJKP
Lanark, Ontario
msm_9949(at)yahoo.com
PostPosted: Mon Aug 02, 2010 9:29 am    Post subject: Model II Weight and Balance Reply with quote
Ken,
My Model 2 came in at a "heavy" 535 lbs empty. (alot of shiny Aerothane aboard). Since doing W&B I've added a cargo pod and other gear that brings it up to about 550. With myself and full fuel (13 US gal) there's still enough left for a 170 lb passenger. It flies great, especially solo.
Marco Menezes N99KX
Model 2 582-90 C Box 3:1 w/clutch
--- On Mon, 8/2/10, Ken Potter <kjpotter(at)sympatico.ca> wrote:
Subject: Re: Model II Weight and Balance
Date: Monday, August 2, 2010, 11:57 AM
Cheers
Ken
Ken Potter
Model II, No. 483
Rotax 582, C-Box,
99% Complete
C-FJKP
Lanark, Ontario
http://forums.matronics.com/viewtopic.php?p=307191#30719om/Navigator?Kitfox-List" target=_blank>http://www.matronics.com/Navigatosp; - MATRONICS WEB FO/" ; -Matt Dralle, List Admin==========
Float Flyr
PostPosted: Tue Aug 03, 2010 10:39 am    Post subject: Model II Weight and Balance Reply with quote
The last line is only for certified aircraft. Wink
Noel
Noel Loveys
Kitfox III-A
Aerocet 1100 Floats
dave
PostPosted: Tue Aug 03, 2010 1:50 pm    Post subject: Re: Model II Weight and Balance Reply with quote
Noel
Noel you are wrong.
Mine is registered as Amateur built that is what is req'd in Canada
(Signature)
Float Flyr
PostPosted: Sun Aug 08, 2010 7:44 am    Post subject: Model II Weight and Balance Reply with quote
In that case you won't be able to fly it in Canada unless it is signed off
by a certified AME. (Not one would sign it.) That is a release statement
which says that the plane is kept to "Applicable airworthiness standards.
No Amateur plane built, by definition, meets those standards.
The statement, in Canada, also means any part on the plane can be traced
back to the manufacturer as a certified part. Can you say that for every
nut and bolt on your plane? No. Good, it means you are flying amateur
built Wink.
BTW At one time if you put a certified engine in your plane it is supposed
to have the serial number modified to make it uncertified. This is still
done when transferring a plane from Certified to Owner Maintained category.
I'm not sure if it is still to be done on Amateur category.
The log book of my 'Fox had the maintenance signed off by the original
owner/builder and also lists his pilot number. The words, "Applicable
Airworthiness Standards" doesn't appear in my logs at all.
Noel
Noel Loveys
Kitfox III-A
Aerocet 1100 Floats
