Posted: Tue Apr 25, 2006 1:44 pm Post subject: Dangerous or just scary |
oooooh, better not let the prozac lapse again.
On 25, Apr 2006, at 4:04 PM, planecrazzzy wrote:
<planecrazzzy(at)yahoo.com>
When "I" was asking about this "one" nicco BULLSHIT...
IT WAS ABOUT SAFETY.....But it got SWITCHED around about critisizing
your CRAFTSMANSHIP
Which I NEVER did....
At one time I didn't give a FUCK....
Now I'm a Pilot...
And I don't give a FLYING FUCK....
KMA- Duane the PLAIN
.Do not archive
http://forums.matronics.com/viewtopic.php?p=30645#30645
dhkey(at)msn.com Guest
Posted: Tue Apr 25, 2006 1:59 pm Post subject: Dangerous or just scary |
famous again!! usually takes a month or so to get famous again huh?
Reply-To: kolb-list(at)matronics.com
To: <kolb-list(at)matronics.com>
Subject: RE: Re: Dangerous or just scary
Date: Tue, 25 Apr 2006 16:55:51 -0400
(CONTENTS OF MESSAGE EDITTED)
<SNIP>
Ahhhh, there is that eloquence you are so famous for...wondered how long
till that came out.
Jeremy "had my mouth washed out long time ago" Casey
DAquaNut(at)aol.com Guest
Posted: Tue Apr 25, 2006 3:27 pm Post subject: Dangerous or just scary |
In a message dated 4/25/2006 9:28:51 A.M. Central Standard Time,
NeilsenRM(at)comcast.net writes:
My personal rule is don't change the structural design of your airplane
unless you KNOW you are making a overall improvement. Even then it is a good
idea to check with the designer or someone else that DOES KNOW about these
things.
Be careful out there.
Again this advice is worth what you paid for it.
Rick Neilsen
Redrive VW powered MKIIIc
Rick,
This Is some of the most useful advice I have seen on this list!!!!!
Ed Diebel Firefly # 62
beauford(at)tampabay.rr.c Guest
Posted: Tue Apr 25, 2006 3:44 pm Post subject: Dangerous or just scary |
Same here, Mike.... well... "BOOOM" ..... You're blocked at my
house....
Whatever,
Go Fly...
Beauford
Richard Pike
Posted: Tue Apr 25, 2006 3:47 pm Post subject: Dangerous or just scary |
The builders manual that came with the MKIII and the FSII both specify 2
nicos per end of each cable.
Richard Pike
MKIII N420P (420ldPoops)
DAquaNut(at)aol.com wrote:
things.
Rick Neilsen
Rick,
Kolb MKIII N420P (420ldPoops)
Kingsport, TN 3TN0
Denny Rowe
Joined: 10 Jan 2006 Posts: 89 Location: Leechburg, PA
Posted: Tue Apr 25, 2006 4:41 pm Post subject: Dangerous or just scary |
Did I mention how much I like your dog?
Duane is a good guy also.
Denny
ul15rhb(at)juno.com Guest
Posted: Tue Apr 25, 2006 6:19 pm Post subject: Dangerous or just scary |
Rick and others,
My elevator and rudder cables are the originals and have never been changed in 19 years. I used to inspect them every year, then it was every 2 years, then every 5 years. Every time, they are perfect with no detectable wear. I have untwisted them where they go around the pulley with all strands intact.
Ralph
Original Firestar
19 years flying with 2 nicros at each end
-- "Richard & Martha Neilsen" <NeilsenRM(at)comcast.net> wrote:
We need to move on to new things but...
In a previous post I talked about some backyard engineers changing things to
make something stronger but in fact creating weakness. I checked out a
MKIIIc last summer were the builder had changed the control wires for the
elevator from stock to what looked like 1/4 - 5/16 galvanized steel cables.
I don't remember if any of the fittings on this control system were beefed
up, I don't think so. My comment at the time was wow you must get some major
cable slap.
Now that I think more about this, I feel that this is a good example of us
backyard engineers trying to make something stronger but actually making it
weaker. The stock cables are plenty strong. Seems like someone stated that
they are rated at 480lbs. By increasing the size of the cables they fixed
some thing that wasn't broken. By increasing the size of the cables they
added weight. More importantly this weight has to be carried by pulling the
cables with considerably more force than is necessary to keep the lighter
cables suspended in the fuselage tube. When they taxi on rough ground the
stress on the control system goes up big time. The control system is only as
strong as its weakest link and the cables were likely never the weakest link
(but I'm not a structural engineer). My point is this added stress could
cause a critical control system failure just by having to carry the added
stretched cable weight.
things.
Rick Neilsen
________________________________________________________________________
Try Juno Platinum for Free! Then, only $9.95/month!
Unlimited Internet Access with 1GB of Email Storage.
Visit http://www.juno.com/value to sign up today!
Posted: Tue Apr 25, 2006 7:17 pm Post subject: Dangerous or just scary |
In a message dated 4/25/2006 6:47:47 P.M. Central Standard Time,
richard(at)bcchapel.org writes:
Richard Pike
Richard,
My Firefly quickbuild kit came that way from factory. So far so good.
Ed Firefly # 62
Rex Rodebush
Joined: 10 Jan 2006 Posts: 209 Location: Branson West area, Missouri
Posted: Wed Apr 26, 2006 4:24 am Post subject: Dangerous or just scary |
Wanted to add some information on nicos before this thing totally blows
up!
The first time I used the small "bolt on each side" nico compressor tool
the nicos came out lopsided. Turned out the top and bottom halfs of the
clamp were not aligned. The top and bottom of the holes were shifted at
the center line. I bought another tool thru Aircraft Spruce and the
holes were perfectly centered. The nicos came out looking like they
were supposed to with a good fit on the go-no go gage. I don't remember
where I got the first tool.
I also used two nicos per the plans. Sorry if I offend.
Rex Rodebush
Posted: Sun Apr 30, 2006 1:46 am Post subject: Dangerous or just scary |
<<this added stress could cause a critical control system failure just by
having to carry the added stretched cable weight.>>
Hi Rick,
not to mention the fact that if the diameter of the cables had been
increased then then the diameter of the pulleys should have been increased
also.
Good advice. Dont fix it unless you are aware of the ramifications,
especially if it aint broke !
Cheers
Pat
No virus found in this outgoing message.
Checked by AVG Free Edition.
Version: 7.1.385 / Virus Database: 268.5.1/327 - Release Date: 28/04/2006
