Erich_Weaver(at)urscorp.c Guest
Posted: Wed Jul 28, 2010 7:53 am Post subject: intermittent intercom |
Feeling dumb about this question, but what the heck. My SL-40 radio is wired to a PS Engineering PM1000 II intercom. Everything initially worked well, but the intercom function is now intermittent from the pilots microphone side only. Transmit and reception are still fine. I cleaned the headphone plugs and corresponding socket contacts with no change. I have also made an initial inquiry with PS Engineering, who indicated that the intercom circuit was dead simple and the unit itself was very unlikely to be the problem. However, I have now realized that I often can temporarily fix the problem by turning the intercom power off, then back on once or twice. Doesnt that in itself indicate that the problem is indeed internal to the intercom? Given those symptoms, is there really anything else to check before sending the unit back to the manufacturer?
thanks
erich
dalamphere(at)comcast.net Guest
Posted: Wed Jul 28, 2010 8:44 am Post subject: intermittent intercom |
Erich,
I have that very same intercom installed in my Wittman Tailwind - connected to a KX125. While they (PS1000II) are a little more expensive than other brands, they are really good quality and work really well - even in a noisy cockpit. One thing I found out debugging my installation is the need to keep the jacks isolated from the aircraft's ground. It's really picky about that. You might verify those mike, headset sockets are not contacting ground (and any socket contacts that could be shorting out to each other or ground). Also check the aux mike and headset sockets (that you can use when the intercom is removed).
Maybe you have an intermittent short to ground somewhere in your installation.
I have to agree that it is doubtful the intercom unit is faulty - possible, but not likely.
Hope you find the fix!
Dave L.
N365DL
bakerocb
Posted: Thu Jul 29, 2010 3:03 am Post subject: intermittent intercom |
7/29/2010
Hello Erich, You wrote:
1) "Doesnt that in itself indicate that the problem is indeed
internal to the intercom?"
Not quite.
2) "Given those symptoms, is there really anything else to check before
sending the unit back to the manufacturer?"
Yes, make absolutely sure that it is not a headset problem. I trouble shot
my intermittent PS intercom / radio system extensively and communicated with
the PS factory who agreed to let me send it to them for a rather expensive
set fee for checkout and repair. But luckily before I sent it off I
discovered with a headset swap that I had an intemittent wire connection
inside one of my headsets.
Please let us know what fixes the problem.
'OC' Baker Says: "The best investment we can make is the time and effort to
gather and understand knowledge."
PS: The Lightspeed headset company did a superb job of repairing and
updating the long time out of warranty faulty headset at only the cost of
shipping it to them -- great customer service.
Time: 08:53:22 AM PST US
Subject: intermittent intercom
ked
d
I
at
ely
k on
ed
ng
thanks
erich
