longg(at)pjm.com Guest
Posted: Tue Jul 20, 2010 10:47 am Post subject: Looking for a do-hicky thingy |
I’m having trouble getting a reading from Klaus’s Plasma III box (RPM pulse) to my Dynon. Either Klaus or Dynon is telling me fish stories.
I’m looking for a gadget that fits as a pass through to a DB15 connector and has stubs or leads off the side so it would allow me to test values passing through DB15 the connector.
This sounds reasonable but I have no idea if such things exist?
Any ideas on where I might find something like this?
If they do exist, what are they called?
Glenn
ronr(at)advanceddesign.co Guest
Posted: Tue Jul 20, 2010 11:09 am Post subject: Looking for a do-hicky thingy |
How about a jumper cable where you crimp two wires to each pin. Then you could take the extra wires out to a test plug.
Ron Raby
rjquillin(at)cox.net Guest
Posted: Tue Jul 20, 2010 11:17 am Post subject: Looking for a do-hicky thingy |
The fancy version, for those with more $$$ than time
http://www.breakoutboxes.com/
At 11:46 7/20/2010, you wrote:
[quote]I’m looking for a gadget that fits as a pass through to a DB15 connector and has stubs or leads off the side so it would allow me to test values passing through DB15 the connector.
If they do exist, what are they called?[b]
Posted: Tue Jul 20, 2010 11:35 am Post subject: Looking for a do-hicky thingy |
On 7/20/2010 1:46 PM, longg(at)pjm.com wrote:
Glenn
Google 'inline db15 breakout connector'.
1st one I hit on was:
http://www.winfordeng.com/products/brk15mf.php
If you do a bit more digging (try Black Box), you can probably find one
that is just 3 dB connectors back to back to side, allowing insertion
in-line with existing cables/chassis and giving you probe access on the
3rd connector
Charlie
Thanks Ron,
Yeah, that's a pain 'cause Klaus has those wires shrunk in there tighter
than you know what...
Today I learned something from one of our subscribers. It's called a
Break Out Box.
http://device-connect.com/product/hdbreakout/hdbreakout.php
Glenn E. Long
Posted: Tue Jul 20, 2010 11:39 am Post subject: Looking for a do-hicky thingy |
Wow,
If I buy that I’ll put Bob out of business. I don’t what to go into the business, just get an lousy RPM reading on my Dynon. I’ll dig for either used or a harbor freight something.
Glenn E. Long
From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Ron Quillin
Sent: Tuesday, July 20, 2010 3:16 PM
Subject: Re: Looking for a do-hicky thingy
If they do exist, what are they called? | Quote: | | http://www.matronics.com/Navigator?AeroElectric-List | 0123456789
retasker(at)optonline.net Guest
Posted: Tue Jul 20, 2010 11:57 am Post subject: Looking for a do-hicky thingy |
http://www.bipom.com/products/us/3376564.html (which seems to be the same as above)
These used to be readily available for troubleshooting RS232 cables but I cannot seem to find any but those above.
As someone else mentioned, you can make your own with either solder or crimp DB15 connectors by just including a second wire connected to each DB15 interconnect wire.
Dick Tasker
longg(at)pjm.com (longg(at)pjm.com) wrote: | Quote: | <![endif]--> <![endif]-->
Glenn
Posted: Tue Jul 20, 2010 7:19 pm Post subject: Looking for a do-hicky thingy |
At 02:33 PM 7/20/2010, you wrote:
Thanks Ron,
Break Out Box.
Yeah, I've got a fist full of those that have proven
handy in my business for over 50 years. When you're
working with low current D-sub signals, here's a little
trick . . .
http://aeroelectric.com/Pictures/Tools/Test_Equipment/Quck_n_Dirty_Breakout.jpg
A piece of ribbon cable and some munch-on connectors
can be assemble in a variety of useful combinations.
A M-F patch cable of appropriate length can be
'enhanced' with a female connector either between the
ends . . . or on a "flying tail". Last time I built
one of these was to look at some signals on a black-box
buried about 3' away from anyplace I could get access
to in flight.
I took a 4' piece of ribbon cable and munched the
M-F pair on one end about 4" apart. On the other
end, I put a female connector to serve as an array
of tiny "pin jacks" where ir proved easy to eavesdrop
on what was happening at the other end of the cable.
If I were in better shape for being unpacked and sorted
out, I could send you the break-out adapter shown in
the picture. If you can't get ribbon cable and connectors
locally, a friend of mine in Wichita could assemble one
for you from inventory (Lloyd's Electronics) and mail
it to you. The whole thing goes together in about 5 minutes
for about five dollars.
