Long and short hot feeders
DCS317(at)aol.com
PostPosted: Fri Jul 09, 2010 7:14 am    Post subject: Long and short hot feeders Reply with quote
Reviewing the Z-14 diagram, there is no fuse protection from the panel switch turning on or off the main battery contactor. In my airplane with a battery in back, this means a 7 foot always hot lead. Should I be concerned?
PostPosted: Fri Jul 09, 2010 12:28 pm    Post subject: Long and short hot feeders Reply with quote
What's the failure mode? If that wire gets shorted
to ground, what happens? If that wire gets shorted
to the battery, what happens? Are their any failure
modes you can deduce that would cause a hazardous
level of current to flow in that wire?
Bob . . . [quote][b]
mrspudandcompany(at)veriz
PostPosted: Fri Jul 09, 2010 1:19 pm    Post subject: Long and short hot feeders Reply with quote
This may be a low probability, but what if the coil in the contactor were to short?
Roger
PostPosted: Fri Jul 09, 2010 4:15 pm    Post subject: Long and short hot feeders Reply with quote
This may be a low
[/b]
The wire in the contactor opens up. It's small gage
wire total enclosed in a metal container.
PostPosted: Sat Jul 10, 2010 4:55 am    Post subject: Re: Long and short hot feeders Reply with quote
DCS317,
No. Every time the master switch is turned on, it shorts this wire to ground. If this wire is accidentally shorted to ground, the main contactor coil restricts the current flow. The contactor will energize and you will lose the ability to shut it off. The danger of fire or smoke is minimal. If installed with secure terminations and care to prevent mechanical damage, then there should be no problem.
Joe
Joe Gores
