fvalarm(at)rapidnet.net Guest
Posted: Mon Jul 05, 2010 12:07 pm Post subject: Microphone levels |
Would you expect that the microphone output level from a standard Aviation
headset to be similar/ or even the same as a standard handheld audio
microphone as used with a professional sound board? I don't own an audio
meter but just need to be close for a non-aircraft related project.
Bevan
Rv7A Implementing Z13/8
Posted: Mon Jul 05, 2010 2:30 pm Post subject: Microphone levels |
At 03:04 PM 7/5/2010, you wrote:
No. Aircraft microphones are victim to legacy compatibility
standards that emulate the original carbon granule microphones
(like those in telephones through the 70s).
http://en.wikipedia.org/wiki/Carbon_microphone
The audio output is not only very high (as much as 1 vrms) it is
generated with a power supply delivered by the transmitter.
Hence, most aircraft microphones have active electronics so
that modern TINY voltage microphones can dress up like
a carbon mic.
| Quote: | I don't own an audio
Sound boards are generally set up to accept 100 mV pk-pk
(30 mV rms) output from dynamic mics delivered on twisted pairs.
Posted: Mon Jul 05, 2010 8:46 pm Post subject: Microphone levels |
Thanks Bob, exactly what I'm looking for.
Bevan
Posted: Tue Jul 06, 2010 12:07 pm Post subject: Microphone levels |
My interface circuit which brings a line level output through an impedance
matching transformer to the mic input of the aircraft radio may need to go
through a capacitor to block the DC bias voltage coming from the radio from
getting to the output of the matching transformer. Do you agree with this
method and can you recommend a value for this cap?
Bevan
Posted: Tue Jul 06, 2010 1:34 pm Post subject: Microphone levels |
At 02:58 PM 7/6/2010, you wrote:
Some experimentation is probably called for. You
need to find a resistor value that becomes a
'dummy microphone'. The resistor probably wants
to have 2-3 volts dropped across it while the
transmitter is 'talking'.
Then make sure the effective output impedance and
signal level of your transmit audio source can
drive the necessary signal into this load . . .
3 v pk-pk is probably a good upper bound to
strive for. Then pick a capacitor who's reactance
at say 100Hz is about 1/10 that of the sum of
dummy load resistor + source output impedance.
rjquillin(at)cox.net Guest
Posted: Tue Jul 06, 2010 1:48 pm Post subject: Microphone levels |
At 14:36 7/6/2010, you wrote:
| Quote: | signal level of your transmit audio source can
strive for. |
Without grabbing my scope, 3Vpp --sounds-- a bit hot for a mic input.
Is that value a typo?
Ron Q.
Posted: Tue Jul 06, 2010 3:35 pm Post subject: Microphone levels |
> strive for.
Nope. That's what can come out of an aircraft microphone
the emulates the legacy carbon mic. Of course, REAL
carbon microphones are exceedingly rare in service now.
Just for grins, put your scope on the mic line of
a headset and see what kinds of signals can be
seen there. They may have migrated down over the
years . . .
Posted: Tue Jul 06, 2010 3:52 pm Post subject: Microphone levels |
strive for. |
Without grabbing my scope, 3Vpp --sounds-- a bit hot for a mic input. |
years . . .
P.s. Just checked some links as follows:
http://www.capitalavionics.com/tip_0909.asp
http://tinyurl.com/24g4wjf
and a number of others that 'specd' aircraft
mics for sensitivity, current draw, bias voltage
but failed to call out the output voltage
present when those specs are being satisfied.
I think it was DO170 that talks industry
specifics.
I did see an anecdotal reference to 100-500 mv
which would translate to 300-1500 mv pk-pk.
Same ball park. We used to design for 3v pk-pk
to have zero risk of clipping . . . at least in
THAT part of the circuit!
