carlossa52(at)gmail.com Guest
Posted: Sun Jul 04, 2010 12:51 pm Post subject: stabilizer attachment |
Hello, all
I am building the rear fuselage, and before committing to the position of parts, I decided to check how the stabilizer would align.
Looks like I'll have to move it forward somewhat (2 or 3 cm), and perhaps add a little shim to the rear attachment, so the width looks ok.
My question to the group is about edge distance: the (CH601-HD) construction manual (Edition 3, Jan 1995) says, in the "tail installation on the fuselage" section (page 26): "watch for a minimum edge distance of 13 mm to any edge."
While the dimensions of 6F2-7 and -8 (6B3-3/4 on the XL) allow for this, 6T2-1 and 6T2-3 do not - or at least I don't see how.
Therefore, I am assuming that the 13 mm statement refers to the HT attachment brackets only (6F2-7 / 8 on the 601-HD and 6B3-3 / 4 on the XL).
I would appreciate the group's comments on this.
Thanks in advance
Carlos
CH601-HD, plans
naumuk(at)windstream.net Guest
Posted: Mon Jul 05, 2010 5:04 am Post subject: stabilizer attachment |
Carlos-
You're right, it's impossible to maintain a 13mm edge distance on both the F and T parts. FWIW, I laid out the 13mm edge distance on the F parts, pre-drilled the holes, clamped the stab in place and backdrilled the T parts.
Bill
mtherr(at)yahoo.com Guest
Posted: Mon Jul 05, 2010 7:14 am Post subject: stabilizer attachment |
I'll have to check for the part numbers.. I remember I had difficulty to maintain minimum edge distance on the HT plates on the side of the fuselage. After checking with CH, I decided to use 0.050" 4130 steel. CH warned me of checking for corrosion.
Michel Therrien CH601-HD, C-GZGQ
http://mthobby.pcperfect.com/ch601
http://pages.infinit.net/mthobby
--- On Mon, 7/5/10, Bill Naumuk <naumuk(at)windstream.net> wrote:
Subject: Re: stabilizer attachment
Received: Monday, July 5, 2010, 8:58 AM
Carlos-
Bill
Posted: Mon Jul 05, 2010 1:00 pm Post subject: stabilizer attachment |
Thanks, Bill and Michel for your input !
Carlos
