japhillipsga(at)aol.com Guest
Posted: Wed Jun 23, 2010 6:00 pm Post subject: Fuel Tanks TestingII |
We have and so does everybody else, but somehow a percentage still have leaks to contend with when the juice goes in so why not fluid test before mounting?
| | - The Matronics RV8-List Email Forum - | | | Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
dan.pat.b(at)gmail.com Guest
Posted: Thu Jun 24, 2010 10:50 am Post subject: Fuel Tanks TestingII |
BILL:
VANS HAS A KIT WHICH ALLOWS YOU TO PRESSURE TEST YOUR TANKS WITH COMPRESSED AIR. I USED IT AFTER FINISHING UP MY TANKS SEVERAL YEARS AGO - IT'S CLASSIC VANS - ECONOMICAL AND SIMPLE AND IT WORKS. YOU SIMPLY MAKE SURE THE FILLER CAPS ARE NICE AND TIGHT; SCREW A NIPPLE INTO THE VENT LINE FITTING AND TAPE A BALLOON OVER IT; SCREW AN AIR VALVE INTO THE FUEL LINE FITTING AND PUMP SOME AIR INTO THE TANK WITH A BICYCLE PUMP - DO NOT USE AN AIR COMPRESSOR. THE BALLOON WILL EXPAND AND KEEP YOU FROM OVER PRESSURISING THE TANK. DISCONNECT THE PUMP AND WATCH THE BALLOON. I ALSO BRUSHED SOAPY WATER ONTO ALL THE RIVET LINES. IF THE BALLOON STAYS INFLATED AND YOU DON'T SEE ANY BUBBLES - YOU'RE HOME FREE. SURE BEATS FOOLING AROUND WITH 21 GALLONS OF GASOLINE - AVGAS OR MOGAS. I'VE NEVER HAD A LEAK.
DAN BERGERON
RV-7A - N307TB
152 HOURS SINCE FIRST
FLIGHT ON 08/04/09
On Wed, Jun 23, 2010 at 9:59 PM, <japhillipsga(at)aol.com (japhillipsga(at)aol.com)> wrote:
[quote] We have and so does everybody else, but somehow a percentage still have leaks to contend with when the juice goes in so why not fluid test before mounting?
