tn3639(at)hotmail.com Guest
Posted: Sun Apr 23, 2006 1:51 pm Post subject: Sensenich prop data |
I recently put a new 80 pitch Sensenich propeller on my 160HP RV6A. I made
a cross country trip and here are my initial results. At 8500 at
approximately 60 degrees F, I was indicating 158 mph, 2530 rpms at WOT and
1680 lbs. After doing the math that wound up being 185 mph TAS and the
ground speed according to my GPS was 195 mph which would be about right as
there should have been a slight 5-8 knot tail wind component according to
Dans web sites wind calculator. After climbing to 9500 the results were
still 158 mph indicated, 58deg F, 2500 rpm at WOT which works out to 188 mph
TAS, 197 mph GPS ground speed. Again with the expected tail winds this was
right on. This is the first time I have been able to fly at WOT and the CHTs
and the EGTs were much more uniform.
All in all the new prop is doing exactly as advertised. Note: These are not
super picky test pilot figures, just what was noted during a flight from a
fly-in with my lovely bride taking notes
__________________
Scott Frierson
N162RV
RV6A 160HP
ronlee(at)pcisys.net Guest
Posted: Sun Apr 23, 2006 3:15 pm Post subject: Sensenich prop data |
| Quote: | I recently put a new 80 pitch Sensenich propeller on my 160HP RV6A. I made
1680 lbs.
Shouldn't you be able to turn around 2700 RPM at 8000' Density Altitude?
Does the possible low RPM suggest too much pitch?
Ron Lee
Do not archive The answer might be worth saving
sportav8r(at)aol.com Guest
jsflyrv
Posted: Sun Apr 23, 2006 4:05 pm Post subject: Sensenich prop data |
Ron Lee wrote:
>1680 lbs.
Ron Lee
Ron, remember that this is a 160 hp and the prop is restricted to 2600 rpm
Posted: Sun Apr 23, 2006 6:12 pm Post subject: Sensenich prop data |
| Quote: | >>I recently put a new 80 pitch Sensenich propeller on my 160HP RV6A. I made
>>1680 lbs.
>Ron Lee
I did not know that. Graci.
Ron
sisson(at)consolidated.ne Guest
Posted: Mon Apr 24, 2006 5:23 am Post subject: Sensenich prop data |
james frierson wrote:
__________________
Scott Frierson
N162RV
RV6A 160HP
sounds pretty good.......... Phil
