jon(at)finleyweb.net Guest
Posted: Sat Jun 19, 2010 2:04 pm Post subject: OT: Temperature Control Relay |
Hi all,
Very off topic.
I am looking for a small 12 VDC temperature control relay. I want to enable the relay at ~120 degrees F. and disable it at 100 degrees F. The maximum relay capacity can be quite small (I can add a larger relay if required).
My searches are overwhelmed with AC versions and very expensive versions. This seems like something that should be available for about $10.
Thanks very much!
Jon
Posted: Sat Jun 19, 2010 3:16 pm Post subject: OT: Temperature Control Relay |
At 05:02 PM 6/19/2010, you wrote:
| Quote: | Hi all,
Very off topic.
My searches are overwhelmed with AC versions and very expensive versions. This seems like something that should be available for about $10. |
What you're looking for (I think) is a thermostat
that closes on temperature rise at 120 and does not
open until the temperature falls below 100F.
Here's a part for clothes dryers.
http://tinyurl.com/25ksfkq
It's SKU number is 39076 on this page
http://tinyurl.com/2gy4tma
[/b] My local washer repair parts store
shows it as an LD120 for $5 net/$11 list.
It's a single pole, double throw device
so you can use it for open or close on
temperature rise.
Bob . . . [quote][b]
Posted: Sat Jun 19, 2010 3:47 pm Post subject: OT: Temperature Control Relay |
Hi Bob,
Very, very close!
This is to operate a pump that circulates solar heated water thru my hot tub. What you found is functionally correct, my only additional requirement is that I can mount the sensor in water (in the solar tubes). Since I am learning, it might be good for the set points to be adjustable. However; I am after cheap so that is certainly not a requirement.
Thanks!
Jon
From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Robert L. Nuckolls, III
Sent: Saturday, June 19, 2010 5:19 PM
Subject: Re: OT: Temperature Control Relay
Hi all,
Very off topic.
temperature rise.
Bob . . . | Quote: | | http://www.matronics.com/Navigator?AeroElectric-List | 0123456789
Checked by AVG - www.avg.com
06:35:00
Bob McC
Posted: Sat Jun 19, 2010 6:33 pm Post subject: OT: Temperature Control Relay |
Jon;
Assuming your circulation system is plastic pipe, can you put a short piece of thin wall metal (copper or aluminium) tube in the water loop at a convenient location and clamp the thermostat offered by Bob to its exterior wall??? The temperature differential through the tube wall would be insignificant and you would then have a readily accessible part which wouldn’t require breaking into the water system to replace or experiment with different values should your initial estimation require changes. If your loop system is already metal pipe, just clamp the thermostat offered to the tube wall. Wrapping the assembly in insulation would further ensure virtually no differential between the water temperature and the thermostat’s reading.
Bob McC
From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Jon Finley
Sent: Saturday, June 19, 2010 7:47 PM
Subject: RE: AeroElectric-List: OT: Temperature Control Relay
Hi Bob,
Very, very close!
Thanks!
Jon
Subject: Re: AeroElectric-List: OT: Temperature Control Relay
Hi all,
Very off topic.
temperature rise. <![if !supportLineBreakNewLine]> <![endif]>
| Quote: | | http://forums.matronics.com |
| Quote: | | http://www.matronics.com/contribution |
06:35:00 01234567890123456789
_________________ Bob McC
Falco #908
(just starting) |
Posted: Sun Jun 20, 2010 8:12 am Post subject: OT: Temperature Control Relay |
YES! Very good ideas Bob – I will pursue!
Thanks for everyone’s help!!
Jon
From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Bob McCallum
Sent: Saturday, June 19, 2010 8:29 PM
Subject: RE: OT: Temperature Control Relay
Jon;
Bob McC
Hi Bob,
Very, very close!
Thanks!
Jon
Hi all,
Very off topic.
temperature rise.
Bob . . . | Quote: | | http://www.matronics.com/Navigator?AeroElectric-List http://forums.matronics.com http://www.matronics.com/contribution |
06:35:00 0123456789
0123456789 | Quote: | | http://www.matronics.com/Navigator?AeroElectric-List | 0 | Quote: | | http://www.matronics.com/Navigator?AeroElectric-List | 1 | Quote: | | http://www.matronics.com/Navigator?AeroElectric-List | 2 | Quote: | | http://www.matronics.com/Navigator?AeroElectric-List | 3 | Quote: | | http://www.matronics.com/Navigator?AeroElectric-List | 4 | Quote: | | http://www.matronics.com/Navigator?AeroElectric-List | 5 | Quote: | | http://www.matronics.com/Navigator?AeroElectric-List | 6 | Quote: | | http://www.matronics.com/Navigator?AeroElectric-List | 7 | Quote: | | http://www.matronics.com/Navigator?AeroElectric-List | 8 | Quote: | | http://www.matronics.com/Navigator?AeroElectric-List | 9
17:50:00
