gordonrsmith921@yahoo.com
Posted: Mon Jun 14, 2010 2:08 pm Post subject: Active Notification of Low Voltage |
Many current OBAM aircraft have electronic EFIS and/or EIS systems installed in their panels. Most of these systems have the capability to monitor various engine and electrical parameters. Limits can be programmed so that when a parameter is outside of the set limits, this is enunciated via audio and/or visual notification (a warning light).
Is the use of these EFIS/EIS systems adequate for proper stand alone “Active Notification of Low Voltage”? Or is it recommended that additional equipment be employed? This additional equipment would be such as AEC9005, AEC9024 (when available), or other such devices on the market.
Gordon Smith
Posted: Tue Jun 15, 2010 5:19 am Post subject: Active Notification of Low Voltage |
At 05:06 PM 6/14/2010, you wrote:
| Quote: | Many current OBAM aircraft have electronic EFIS and/or EIS systems installed in their panels. Most of these systems have the capability to monitor various engine and electrical parameters. Limits can be programmed so that when a parameter is outside of the set limits, this is enunciated via audio and/or visual notification (a warning light).
Is the use of these EFIS/EIS systems adequate for proper stand alone “Active Notification of Low Voltage”? Or is it recommended that additional equipment be employed? This additional equipment would be such as AEC9005, AEC9024 (when available), or other such devices on the market. |
Your choice. The operative word is "active".
If the nature of the warning provided as a
feature of a panel mounted accessory is sufficient
to get your attention within a minute of
onset of LV, then the design goals have been
met.
The B&C LR series regulators are shipped with
a rather obnoxious yellow warning light assembly
that is guaranteed to get your attention.
It's something you can experiment with in
flight. Shut the alternator off. Judge for
yourself if the resulting indication is sufficiently
attention getting.
Bob . . . [quote][b]
chasb(at)satx.rr.com Guest
Posted: Thu Jun 17, 2010 5:41 am Post subject: Active Notification of Low Voltage |
Time: 09:07:05 AM PST US
From: Charles Brame <chasb(at)satx.rr.com (chasb(at)satx.rr.com)>
Subject: RV-List: Re: Active Notification of Low Voltage
Bob, et. al.,
I'm one of the guilty ones with an electronic EFIS and no warning
light for a low voltage. In a low voltage situation, my EFIS voltmeter
does flash, but I have determined that isn't a sufficient warning.
Thus I would like to install a low voltage warning light. To
complicate matters: however, I have a generic Ford regulator that does
not have a low voltage warning circuit. Is there a simple solution for
this situation?
Charlie Brame
RV-6A N11CB
San Antonio
Time: 06:19:27 AM PST US
From: "Robert L. Nuckolls, III" <nuckolls.bob(at)aeroelectric.com (nuckolls.bob(at)aeroelectric.com)>
Subject: Re: Active Notification of Low Voltage
"Active Notification of Low Voltage"? Or is it recommended that
on the market.
met.
attention getting.
longg(at)pjm.com Guest
Posted: Thu Jun 17, 2010 6:06 am Post subject: Active Notification of Low Voltage |
Charlie,
It may sound too simple but just install a low voltage warning light. B
& C, Bob or Eric have simple, low cost jobs to fit the bill. I have a
Dynon that displays internal, bus and master voltages but I still like
to see the idiot light on the panel.
Glenn
Posted: Thu Jun 17, 2010 7:29 am Post subject: Active Notification of Low Voltage |
At 09:05 AM 6/17/2010, you wrote:
Charlie,
I'll re-enforce Glen's suggestion by offering the simple-
ideas that have driven my design goals for active notification
of low voltage for over 30 years . . .
Most low voltage notification systems built into glass
screens and alternator regulators are not stand-alone,
attention getting, auto-preflight tested systems.
Every low voltage warning device I've crafted has
no other function nor does it depend on functional
integrity of any other device in the airplane.
The recommended indicator lamp is bright. Installation
instructions call for putting it right in front of the pilot.
When we flash it, a rate of 2.5 to 3 times per second
is the targeted rate shown to be the most attention
getting. Installers are encouraged to test the
installation for sun-light view ability.
By installing active notification of low voltage
right on the main bus, it's the first thing that
comes on with the master switch and it stays on
until the alternator comes on line. I.e., you get
a pre-flight test of functionality whether or not
it's am item on your checklist.
Having said all this, folks tend to gravitate toward
the notion that loss of an alternator is somehow
an emergency that should be annunciated with lots
of sirens, bells, flashing lights and waving
flags.
NOT SO.
The whole purpose for active notification of low
voltage is to PREVENT loss of an alternator from
becoming an emergency. This is accomplished by
offering the pilot timely encouragement to implement
plan-B. No more, no less.
Once plan-B is in effect, the well crafted and
maintained system offers a no-sweat alternative
for return to earth.
A thread common to many loss-of-alternator
scenarios in the library of dark-n-stormy-night
stories is LACK OF AWARENESS about alternator
functionality combined with LACK OF AWARENESS
of system condition and capability. I.e., not
knowing the condition of the ship's battery and
a complete WAG as to how long needful things will
run on the battery's contained energy.
It's the classic case of what you don't know is
that which might become a disappointing surprise.
Indeed, many of the dark-n-stormy-night narratives
illustrate the fact that the pilot didn't know
the alternator wasn't working until the
panel went black and options for battery
load shedding were already expended.
That little yellow light is not the end-all,
be-all of electrical system warning gadgets.
It is but one link in the chain of thoughtful
set of design goals for crafting a FAILURE
TOLERANT system. Like all chains, the design
is no stronger than the weakest link which
can manifest in poor architecture, poor battery
maintenance, poor testing of failure hypothesis,
AND warnings that are too benign to get one's
attention in the cockpit under all flight
conditions.
bakerocb
Posted: Fri Jun 18, 2010 3:06 am Post subject: Active Notification of Low Voltage |
6/18/2010
Hello Glenn, There is definetely more to this than just simply installing a
(low cost?) light. What is to activate the light?
Is this some of the hardware that you have in mind? Thanks.
http://www.periheliondesign.com/lvwaabm.htm
http://www.bandc.biz/primary-regulators.aspx
http://www.aeroelectric.com/Catalog/AEC/9005/LV_Warn_Fab_and_Install.pdf
'OC' Baker Says: "The best investment we can make is the time and effort to
gather and understand knowledge."
Time: 07:06:43 AM PST US
Subject: RE: Active Notification of Low Voltage
Charlie,
Glenn
