glcasey(at)adelphia.net Guest
Posted: Sat Apr 22, 2006 4:40 am Post subject: Engine mount bolts |
I'm installing my Lycoming and I'm not sure what kind of bolt to use
in the four engine mount isolators. I'm assuming a standard bolt and
nut with a flat washer and a star washer. Is that the right
combination? No locking nuts or no castle nuts?
Gary Casey
| | - The Matronics Engines-List Email Forum - | | | Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
http://www.matronics.com/Navigator?Engines-List |
s_korney(at)hotmail.com Guest
Posted: Sat Apr 22, 2006 6:10 am Post subject: Engine mount bolts |
Grade 8 bolts with castle nuts and cotter pins... Torque to proper
specifications for the mounts... There should be a spacer between the two
rubber mount halfs...
Best... Steve
----Original Message Follows----
Reply-To: engines-list(at)matronics.com
Subject: Engine mount bolts
Date: Sat, 22 Apr 2006 05:37:56 -0700
Gary Casey
Mark Phillips in TN
Joined: 10 Jan 2006 Posts: 431 Location: Columbia, TN
Posted: Sat Apr 22, 2006 7:29 pm Post subject: Engine mount bolts |
Here's what Van's sells:
http://www.vansaircraft.com/cgi-bin/catalog.cgi?ident=1145762374-232-600&brows
e=engines&product=engine-boltkit
Or go to Van's webstore and search for " EA DYNA BOLT " for dynafocal mounts-
search engines & accessories section for conical etc.
_________________ From The PossumWorks... |
