N81JG(at)aol.com Guest
Posted: Sun Jun 06, 2010 5:23 pm Post subject: Com antenna |
Hi Bob,
I have been flying a Rutan VariEze for many years with several changes in com antennas. All have been suboptimal. I am planning on mounting a dipole in the wing-winglet with ferrite donuts at the coax as used with the copper tape antennas. The plan is to use a length of copper tubing for each leg of the dipole and thread it up the leading edge of the winglet in the underlying styrafoam and horizontally in the leading edge of the wing foam. The center coax lead will be connected to the vertical winglet pole and the shield to the horizontal wing pole. I was planning on using 1/8 inch copper tubing. Would that size tubing give me adequate bandwidth? Do you see any other pitfalls in this plan? I want to make sure it will work before I cut the 2-3 inch hole in the wingtip-lower winglet junction in order to thread the tubing in and connect the coax.
John Greaves
VariEze N81JG
Redding, CA
Posted: Sun Jun 06, 2010 7:44 pm Post subject: Com antenna |
At 08:17 PM 6/6/2010, you wrote:
| Quote: | Hi Bob,
I have been flying a Rutan VariEze for many years with several changes in com antennas. All have been suboptimal. I am planning on mounting a dipole in the wing-winglet with ferrite donuts at the coax as used with the copper tape antennas. The plan is to use a length of copper tubing for each leg of the dipole and thread it up the leading edge of the winglet in the underlying styrafoam and horizontally in the leading edge of the wing foam. The center coax lead will be connected to the vertical winglet pole and the shield to the horizontal wing pole. I was planning on using 1/8 inch copper tubing. Would that size tubing give me adequate bandwidth? Do you see any other pitfalls in this plan? I want to make sure it will work before I cut the 2-3 inch hole in the wingtip-lower winglet junction in order to thread the tubing in and connect the coax. |
What kinds of antennas have you tried so far?
What's your criteria for judging them sub-optimal?
Are there other VariEze builders who have already
built the antenna you propose? Have THEY made any
Antenna A versus Antenna B comparisons that would
encourage you to carry out this surgery on the
airplane?
What is the height of the winglet? Can you get
a half-wave radiator up the winglet? There's
a unique center-fed half-wave that runs a
feedline up the center of the lower element.
See:
http://www.miracleantenna.com/AirWhip.htm
This might be easier to install. But
before you start carving on the airplane,
it would be useful to calibrate your
expectations against the physics of
contemporary airborne antenna performance.
Bob . . . [quote][b]
Posted: Sun Jun 06, 2010 9:00 pm Post subject: Com antenna |
Hi Bob,
I originally had a foil dipole with 20.3 inch limbs and 3 ferrite donuts on the coax that worked reasonably well until I had to change my brake lines from Nyloseal to aluminum. That detuned and ruined the antenna. Next I had a similar tape dipole on the seat back, but my body detuned that. Now I have the Miracle Whip inside the front fuselage that works within a few 10's of miles(OK only for inside airport areas), but is too directional probably due to metal and my legs nearby. Other VE's have had these wing-winglet dipole antennas and I think they have been satisfactory and I think superior to all other buried antennas, but I am waiting for reply on the canard aviators site. The surgery on the plane is minimal since I have a wire conduit in the foam wing from root to the tip just under the fiberglass tip that I can access easily and also thread the copper tubing in the foam from.
The winglet height is adequate for the 20.3 inch vertical limb. I would use the Miracle Whip, but it is too long for the winglet height. I considered extending it along the outer wing foam with the last 1/2 of the tip in the vertical part of the winglet, but that would require quite a bit of surgery to bury the base load box in the wing foam near the center of the wing and might compromise the foam-skin stress structure of the wing( a definite no go there option).
I could go to an external whip antenna with a ground plane of wire or aluminum, but I would prefer not to add parasitic drag. The wingtip idea is less invasive surgery.
Thanks for your reply. I hope I have answered you questions.
John Greaves
In a message dated 6/6/2010 8:45:31 P.M. Pacific Daylight Time, nuckolls.bob(at)aeroelectric.com writes:
| Quote: | At 08:17 PM 6/6/2010, you wrote:
| Quote: | Hi Bob,
airplane?
See:
Bob . . . | Quote: |
List href="http://www.matronics.com/Navigator?AeroElectric-List">http://www.matronics.com/Navigator?AeroElectric-List
ms.matronics.com/">http://forums.matronics.com
tp://www.matronics.com/contribution">http://www.matronics.com/contribution
Posted: Mon Jun 07, 2010 8:48 pm Post subject: Com antenna |
Agreed.
Okay. How about a 1/4 wave with 'half' a ground
plane? Run a 21 inch piece of copper up the winglet
and two to five radials into the foam toward the
fuselage. Connect all the radials together at the
coax shield, center conductor to the winglet radiator
and ditch the donuts.
Don't worry about bandwidth. Proximity effects
of conductors for de-tuning and/or pattern
modification are profoundly more hazardous to
performance than SWR.
sportav8r(at)gmail.com Guest
Posted: Tue Jun 08, 2010 5:12 am Post subject: Com antenna |
Yeah, until the transmitter power amp stage folds-back at higher SWR to protect the output transistor - that's a performance-killer, sometimes. Bandwidth can matter...
| Quote: | >Don't worry about bandwidth. Proximity effects
performance than SWR.<<
On Tue, Jun 8, 2010 at 12:50 AM, Robert L. Nuckolls, III <nuckolls.bob(at)aeroelectric.com (nuckolls.bob(at)aeroelectric.com)> wrote:
[quote]--> AeroElectric-List message posted by: "Robert L. Nuckolls, III" <nuckolls.bob(at)aeroelectric.com (nuckolls.bob(at)aeroelectric.com)>
Agreed.
"im">
-List" target="_blank">http://www.matronics.com/Navigator?AeroElectric-List
le, List Admin.
Posted: Wed Jun 09, 2010 9:10 am Post subject: Com antenna |
HI Bob,
Thanks for your replies. I have one question on the dipole with several radial base wires. That would be easy to set up, but I don't understand why I could ditch the toroids at the end of the coax. Does the balance of the coax and dipole work out due to many ground radials or does the arrangement turn the antenna into a simple base loaded 1/4 wave whip? I assume the latter is what happens. Would the base on only the wing side of the vertical element make it quite directional or not significantly directional?
John Greaves
In a message dated 6/7/2010 9:49:28 P.M. Pacific Daylight Time, nuckolls.bob(at)aeroelectric.com writes:
| Quote: | --> AeroElectric-List message posted by: "Robert L. Nuckolls, III" <nuckolls.bob(at)aeroelectric.com>
Agreed.
Bob . . . ========================= Use utilities Day ================================================ - MATRONICS WEB FORUMS ================================================ - List Contribution Web Site sp; ===================================================
Posted: Wed Jun 09, 2010 8:24 pm Post subject: Com antenna |
At 11:17 AM 6/9/2010, you wrote:
| Quote: | HI Bob,
Thanks for your replies. I have one question on the dipole with several radial base wires. That would be easy to set up, but I don't understand why I could ditch the toroids at the end of the coax. |
They don't really do much unless they're of a material
appropriate to the operating frequency and then only
when they add significant inductance to the currents
flowing in the shield.
Since inductance is proportional to the square of
the turns, you need 9 toroids on the coax (nine
series connected inductors of 1-turn each) to equal
1 toroid with three turns of coax wound through
the center. Take the miracle whip "can" apart
and you'll find a single core with multiple turns
through it.
The idea was to improve the interface between an
unbalanced feeder (coax) and a balanced antenna (dipole)
but it takes quite a few of the RIGHT toroid to do
the best job . . . and tens of thousands of airplanes
have successfully fed balanced VOR cat-whiskers
at the top of the vertical fin with coax and NO
toroids for decades.
Correct. Adding radials to the "base" of a single
vertical makes it an unbalanced antenna that more
closely approximates a ground plane. And yes,
it's radiation patter will not be 'round' but
if it's more efficient, a few bumps in the radiation
plot may not matter. Having say 4 radials at the
base make the sum total of their radiation resistance
1/4th that of the vertical radiator. This makes
the radiator do it's magic with the majority of
energy arriving at the end of the feedline.
Further, the antenna is now decidedly unbalanced
and the toroids are no longer suggested . . .
although they were of limited value in the first
place. A coax balun does a better job but also narrows
the bandwidth of the system. A broadband balun has
a wider bandwidth but adds its own losses.
1/4 wave comm antennas over ground planes have
been doing a really good job on viritually EVERY
radio equipped airplane since the Lear LTRA6
and Narco VT1 radios gave voice to little GA
aircraft in the 50's.
I think you the highest probability for success
lies in getting as close to that configuration
as the layout of your winglet allows. The more
radials the better. 4 is enough and 8 is
probably not practical.
Posted: Thu Jun 10, 2010 2:38 pm Post subject: Com antenna |
Thanks much Bob for the explanation. It looks like the radial base may be my best bet for coming close to a standard aircraft cats-whisker antenna. I will try that first and I can lay it out on the outer skin and measure the SWR for confirmation of the efficiency before I install it in the foam. I will also see how different the SWR will be between the outer surface and inside the foam. I will report back.
John Greaves
In a message dated 6/9/2010 9:25:27 P.M. Pacific Daylight Time, nuckolls.bob(at)aeroelectric.com writes:
| Quote: | At 11:17 AM 6/9/2010, you wrote:
| Quote: | HI Bob,
through it.
Posted: Thu Jun 10, 2010 4:38 pm Post subject: Com antenna |
At 05:31 PM 6/10/2010, you wrote:
| Quote: | | Thanks much Bob for the explanation. It looks like the radial base may be my best bet for coming close to a standard aircraft cats-whisker antenna. I will try that first and I can lay it out on the outer skin and measure the SWR for confirmation of the efficiency before I install it in the foam. I will also see how different the SWR will be between the outer surface and inside the foam. I will report back. |
Good show! Inquiring minds want to know . . .
Get a plot over the whole comm range.
