eryan(at)cpasforyou.net Guest
Posted: Fri Jun 04, 2010 3:04 am Post subject: Lightning-List Digest: 3 Msgs - 06/03/10 |
I have an AV8OR ACE that I need to get rid of. It has Bluetooth,
weather and charts. I have had for a year with very little use. I
just like my 396 better since I am doing light sport now.
ED
| Quote: | *
Today's complete Lightning-List Digest can also be found in either of the
of the Lightning-List Digest and can be viewed with a generic text editor
HTML Version:
http://www.matronics.com/digest/digestview.php?Style=82701&View=html&Chapter 10-06-03&Archive=Lightning
Text Version:
http://www.matronics.com/digest/digestview.php?Style=82701&View=txt&Chapter 10-06-03&Archive=Lightning
Lightning-List Digest Archive
Total Messages Posted Thu 06/03/10: 3
Today's Message Index:
1. 05:24 AM - Re: Rust in carburetor (N1BZRich(at)aol.com)
2. 06:39 AM - Re: Re: Rust in carburetor (Pete Krotje)
3. 07:51 AM - Re: Re: Rust in carburetor (Bernard Melendez, Jr.)
________________________________ Message 1
_____________________________________
Time: 05:24:18 AM PST US
Subject: Re: Rust in carburetor
Hi Bernardo,
Thanks for your comments on the newsletter. Your feedback on articles
and items in the newsletter help me know what is really helpful and thus
important to Lightning builders and flyers.
As to the FAA accident case study about the Jabiru engine failure due
to rust in the Bing carb, I hope everyone that reads the newsletter will
take the time to follow the link to the FAA write up on this fatal accident.
Although I suspect that if a Jabiru engine is only fed a diet of aviation
fuel (or certainly no ethanol in any auto fuel) and if that engine is run
regularly, there probably would be no problem like this article describes.
But information like presented in this article is knowledge, and I am a
firm believer of knowing as must as possible about the "equipment" we fly.
Good luck on your Lightning build. Keep the "Newsletter staff"
informed of your progress so we can have good things to write about.
Blue Skies,
Buz
In a message dated 6/3/2010 1:18:59 A.M. Eastern Daylight Time,
n45bm(at)yahoo.com writes:
Hi Buz,
Nice newsletter! I was pleasantly surprised to see my emails to you along
with the pictures of my little Corby Starlet, "Estrellita". Thank you.
I read with interest your June 2010 newsletter link to "Accident Case
Study, A Fatal Case of a Little Corrosion in the Worst Place".
I think that not only should this be required reading for all those with
Bing carburetors on their aircraft engines, but that it should be an annual
inspection item, to assess if all is smooth and shiny inside the
carburetor, with no binding. Hard to imagine a little rust can be
fatal as it
was in
this case. I know that I will check mine annually, at least, or more often.
Of course, my preference would be to have fuel injection on my engine for
better fuel distribution, no carburetor icing issues and better fuel
economy. Is that available? I've experienced carburetor icing
before and I was
not a happy camper. It really grabs your attention! We don't want the
cooling fan to stop in mid air because if it stops, you start
sweating. Remember,
air is soft, ground is hard. "Mis dos centavos" ($.02).
Bernardo Melendez
________________________________ Message 2
Time: 06:39:40 AM PST US
Subject: RE: Re: Rust in carburetor
The only problem with the story in the FAA newsletter about corrosion in the
carb is that it was not the corrosion in the carb that caused the engine
stoppage. In addition to the corrosion there was a sticky substance in the
carb that held the piston open in spite of gravity and the spring trying to
close it. When he applied full power for take off the piston was pulled up
into the dome. Then when power was reduced for cruise the piston stuck up
in the dome holding the jet needle up and allowing a lot of fuel to flow
through the jet while the throttle butterfly closed a bit and reduced
airflow through the carb. The resulting over rich condition caused the
engine to eventually stop. The sticky substance may have come from a
substance used to repair a leak in the fuel tank.
While the corrosion in that carb may have lead to an early carb rebuild I
don't think it was much of a factor in this accident. If the author of the
article had waited for additional results of the NTSB investigation he may
have reached a different conclusion or the article may have been better
titled "Foreign Substance in Fuel System"
Pete Krotje
Arion Aircraft, LLC
931-680-1781
www.flylightning.net
[mailto:owner-lightning-list-server(at)matronics.com] On Behalf Of
N1BZRich(at)aol.com
Sent: Thursday, June 03, 2010 7:23 AM
Hi Bernardo,
As to the FAA accident case study about the Jabiru engine failure due to
rust in the Bing carb, I hope everyone that reads the newsletter will take
But information like presented in this article is knowledge, and I am a firm
Good luck on your Lightning build. Keep the "Newsletter staff" informed
Blue Skies,
Buz
Hi Buz,
I read with interest your June 2010 newsletter link to "Accident Case Study,
inspection item, to assess if all is smooth and shiny inside the carburetor,
with no binding. Hard to imagine a little rust can be fatal as it was in
economy. Is that available? I've experienced carburetor icing before and I
was not a happy camper. It really grabs your attention! We don't want the
cooling fan to stop in mid air because if it stops, you start sweating.
Remember, air is soft, ground is hard. "Mis dos centavos" ($.02).
Bernardo Melendez
________________________________ Message 3
Time: 07:51:56 AM PST US
Hello Pete,
=0AThanks for your input. I had not thought it through about the "sticky"
=0Asubstance, but in retrospect, it makes sense.
That's what I like about this group, always on top of things. Like a chicke
n on a June bug.
Best regards,
Bernardo Melendez
=0A=0A=0A =0A =0A=0A=0A=0A=0A=0A=0AThe only problem with the story in the F
AA newsletter about=0Acorrosion in the carb is that it was not the corrosio
n in the carb that caused=0Athe engine stoppage.=C2- In addition to the c
orrosion there was a sticky=0Asubstance in the carb that held the piston op
en in spite of gravity and the=0Aspring trying to close it.=C2- When he a
pplied full power for take off the=0Apiston was pulled up into the dome.=C2
- Then when power was reduced for=0Acruise the piston stuck up in the dom
e holding the jet needle up and allowing a=0Alot of fuel to flow through th
e jet while the throttle butterfly=C2- closed a=0Abit and reduced airflow
through the carb.=C2- The resulting over rich=0Acondition caused the eng
ine to eventually stop.=C2- The sticky substance may=0Ahave come from a s
ubstance used to=C2- repair a leak in the fuel tank. =0A=0A =C2- =0A=0A
While the corrosion in that carb may have lead to an early carb=0Arebuild I
don=99t think it was much of a factor in this accident.=C2- If=0At
he author of the article had waited for additional results of the NTSB=0Ain
vestigation he may have reached a different conclusion or the article may
=0Ahave been better titled =9CForeign Substance in Fuel System
=9D =0A=0A =C2- =0A=0APete Krotje =0A=0AArion Aircraft, LLC =0A=0A931-680
-1781 =0A=0Awww.flylightning.net =0A=0A =C2- =0A=0A =C2- =0A=0A =C2-
=0A=0A=0A=0A=0A=0AFrom:=0Aowner-lightning-list-server(at)matronics.com=0A[mail
to:owner-lightning-list-server(at)matronics.com] On Behalf Of N1BZRich(at)aol.com
=0ASent: Thursday, June 03, 2010 7:23 AM
=0ATo: lightning-list(at)matronics.com
=0ASubject: Re: Rust in carburetor =0A=0A=0A=0A=0A=0A =C2
- =0A=0A=0A=0A=0A=0AHi Bernardo, =0A=0A=0A=0A=0A=0A=C2-=C2-=C2-=C2
-Thanks for your comments on the=0Anewsletter.=C2- Your feedback on art
icles and items in the newsletter help me=0Aknow what is really helpful and
thus important to Lightning builders and=0Aflyers. =0A=0A=0A=0A=0A=0A=C2
-=C2-=C2-=C2-As to the FAA accident case study about=0Athe Jabiru e
ngine failure due to rust in the Bing carb, I hope everyone that=0Areads th
e newsletter will take the time to follow the link to the FAA write up=0Aon
this fatal accident.=C2- Although I suspect that if a Jabiru engine is
=0Aonly fed a diet of aviation fuel (or certainly no ethanol in any auto fu
el) and=0Aif that engine is run regularly, there probably would be no probl
em like this=0Aarticle describes.=C2- But information like presented in t
his article is=0Aknowledge, and I am a firm believer of knowing as must as
possible about the=0A"equipment" we fly.=C2- =0A=0A=0A=0A=0A=0A=C2-=C2
-=C2-=C2-Good luck on your Lightning build.=C2-=0AKeep the "Newslet
ter staff" informed of your progress so we can have=0Agood things to write
about. =0A=0A=0A=0A=0A=0ABlue Skies, =0A=0A=0A=0A=0A=0ABuz =0A=0A=0A=0A=0A
=0A=0A=0A=C2- =0A=0A=0A=0A=0A=0A=0A=0AIn a message dated 6/3/2010 1:18:59
A.M. Eastern Daylight Time,=0An45bm(at)yahoo.com writes: =0A=0A=0A=0A=0A=0A
=0A =0A =0A Hi Buz,
=0A Nice newsletter! I was pleasantly surprised to see my emails to you al
ong=0A with the pictures of my little Corby Starlet, "Estrellita". Thank
=0A you.
=0A I read with interest your June 2010 newsletter link to "Accident Case
=0A Study, A Fatal Case of a Little Corrosion in the Worst Place".
=0A I think that not only should this be required reading for all=0A thos
e with Bing carburetors on their aircraft engines, but that it should be=0A
an annual inspection item, to assess if all is smooth and shiny inside th
e=0A carburetor, with no binding. Hard to imagine a little rust can be fat
al as it=0A was in this case. I know that I will check mine annually, at l
east, or more=0A often.
=0A Of course, my preference would be to have fuel injection on my engine
for=0A better fuel distribution, no carburetor icing issues and better fue
l economy.=0A Is that available? I've experienced carburetor icing before
and I was not a=0A happy camper. It really grabs your attention! We don't
want the=0A cooling fan to stop in mid air because if it stops, you start
sweating.=0A Remember, air is soft, ground is hard. "Mis dos centavos" ($.
02).
=0A Regards,
=0A Bernardo Melendez =0A =0A =0A=0A=0A=0A=0A=0A=0A =C2- =C2-http://w
ww.matronics.com/Navigator?Lightning-Listhttp://forums.matronics.comhttp://
www.matronics.com/contribution =C2- =0A=0A=0A=0A=0A=0A=0A=0A
| | - The Matronics Lightning-List Email Forum - | | | Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
http://www.matronics.com/Navigator?Lightning-List |
