mlfrancke(at)charter.net Guest
Posted: Fri Apr 21, 2006 2:03 pm Post subject: Wing Skins |
Anyone?
This might be a stupid question, but when you turn over the wings and cleco top skin on the inside.
Then turn over and do the bottom skin when you go to rivet bottom skin on skeleton, how do you remove the clecos from
the inside on the top skin.
Mel Francke CH601XL working on wings
Growing old is mandatory, growing up is optional.
Life should NOT be a journey to the grave with the intention of arriving
safely in an attractive and well preserved body, but rather to skid in
sideways, chocolate in one hand, wine in the other, body thoroughly
used up, totally worn out and screaming "WOO HOO what a ride!"
gboothe(at)calply.com Guest
Posted: Fri Apr 21, 2006 2:15 pm Post subject: Wing Skins |
Mel,
As I recall, ZAC recommends doing the bottom first. I believe their exact
phraseology was to the effect that you want your best work on top (where
it's seen). At any rate, install clecoes on the outside of all skins. That
means you have to be careful if you intend to lay the wing down on installed
clecoes. Be sure to Einstein a method of having something to support the
wing between the clecoes.
Gary A. Boothe
Cool, Ca
601HDSTD, WW Conversion
Tail Complete, Working on wings
Jaybannist(at)cs.com Guest
Posted: Fri Apr 21, 2006 2:25 pm Post subject: Wing Skins |
Mel, I thought that was a bad idea also. I left the clecoes outside the top
skin and just used more steel tubes under the spar and rear channel to get
the proper angle on the spar and make sure the clecoes were clear of the table.
This is pretty fresh, since I did just that today! I am working on the left
wing with the right one complete and in storage.
Another trick I developed to align the nose ribs. Once the spar edge of the
nose skin has been clecoed, I slip a 1 x 2 between the skin and just above the
nose of the rib. That way, I can drill a pilot hole (the last one toward the
nose) without drilling thru the rib flange. Then I can align the centerline
mark on the rib flange thru this pilot hole. Works every time.
Jay in Dallas w/601XL
naumuk(at)alltel.net Guest
Posted: Fri Apr 21, 2006 3:10 pm Post subject: Wing Skins |
Mel-
Cleco on the outside and use the biggest shims you can afford to set the
wings on. Out here in the boondocks, we can get 6x6 roughcut blocking for
next to nothing (If not nothing). Very nice being able to set or pull clecos
without having to re-level everything.
Bill
agustafson(at)chartermi.n Guest
Posted: Fri Apr 21, 2006 3:24 pm Post subject: Wing Skins |
Me too am working on wing skins lately. On the second wing, which looks
better than the first, I did the final rivet on the top skin before I even
drilled the bottom. They say you can do some straightening by tapping on
rivets but I didn't find that worked well. Use a small square to make sure
the rib flanges are at 90 degrees before you start or the flanges will pull
your skins out of flat. On my next 601 (((NOT))) I will do everything better
and faster! Make sure your table is flat w/ a level.
Aaron do not archive
Posted: Fri Apr 21, 2006 4:17 pm Post subject: Wing Skins |
Aaron-
What do you mean, NOT! Wouldn't you like to do it right the first time?
Even if it is the second time!
Bill
Posted: Fri Apr 21, 2006 6:56 pm Post subject: Wing Skins |
I guess I am confused by this question. When I do wing skins, the
clecos go on the outside rather than the inside. The only ones on
the inside are in places that will always be accessible like the
baggage compartment.
Paul
XL wings.
At 02:56 PM 4/21/2006, you wrote:
| Quote: | This might be a stupid question, but when you turn over the wings
nfivesl(at)yahoo.com Guest
Posted: Sat Apr 22, 2006 6:41 am Post subject: Wing Skins |
Paul:
If you cleco the inside of your wingskin, then rivet
the other side, you will have no way to remove the
clecos. You should cleco the skin on the outside,
turn the wing over and use some sort of spacers (2x2's
or metal beams) so the clecos don't hit the table,
then rivet the side that is up. In the case described
below, the bottom is riveted first so the clecos
should be on the outside of the top skin with the wing
resting on spacers. The assembly manual available on
the ZAC builder's page is pretty clear on this.
Some of the questions I read on this list lead me to
believe not everyone knows about the updated assembly
manuals. ZAC will give you the password if you call
them in Mexico, MO.
Scott Laughlin
www.cooknwithgas.com
Wiring my yoke
--- Paul Mulwitz <p.mulwitz(at)worldnet.att.net> wrote:
| Quote: | I guess I am confused by this question.
Paul
XL wings.
over the wings
to rivet bottom
browse
Subscriptions page,
FAQ,
Admin.
JAPhillipsGA(at)aol.com Guest
Posted: Sat Apr 22, 2006 7:40 am Post subject: Wing Skins |
Mel, all of us that have built the wings know the issue and there are
probably as many ways to resolve it as XLs out there. What I did was build the wing
on top of two 12 foot steel I-beams that I mounted semi permeant on my 12x4
building table. I got them level with a digital level and each time I flipped the
wings it took two folks and we lifted high enough to clear the bottom
inverted clecos and re set so the clecos cleared the beams. I built the whole wing
without riveting until all skins and holes were ready. Then I riveted the bottom
(minus flap attachment area where I inserted clecos up side down), top skin,
then nose skin, then tip. I'm sure it can be accomplished other ways, but the
beams assured everything was square and plum. best regards, Bill of Georgia
JohnDRead(at)aol.com Guest
Posted: Sun Apr 23, 2006 3:09 pm Post subject: Wing Skins |
Hello All:
Regarding wings and any part of the aircraft that you would
like to build true. It is imperative that the building table is flat with no
twist or humps in it. My table is a welded truss frame that will not twist.
Any spacers that are used to hold clecoed wings or other parts should also be
parallel and true. How flat and true (within 1/32 over 12 feet, if you want
the plane to fly straight)?
Regards, John Read, Starting a CH701
Posted: Sun Apr 23, 2006 6:24 pm Post subject: Wing Skins |
I agree it is important to have a flat workbench and if it is also
level it is even better.
On the other hand, I don't think it is necessary to have something as
big as a wing within 1/32 inch of perfect. This is only one of many
things that can impact a plane's natural ability to fly straight and
true. Some of the other things include: Rigging of both structure
and control surfaces; presence or absence of a passenger; exact fuel
situation; power setting; weight and balance impact of baggage and
cargo; and general weight and balance of the structure. In the end
it is elevator and aileron/rudder trim that will make the plane fly straight.
I think it is a great idea to build as true a structure as you can,
but I wouldn't lose sleep over how close to perfect it comes out.
Paul
XL wings
| Quote: | Regarding wings and any part of the aircraft that you would
