aeronca2(at)99main.com Guest
Posted: Thu Apr 15, 2010 6:36 am Post subject: noise suppression |
Installation instructions for a 12volt, 8amp wind driven generator specify shielding on the output lead with no other noise suppression requirements. Electrical system schematics for later models of the aircraft, having engine driven generators, specify 0.01 microfarad capacitors on the armature and stator leads. On the wind driven generator, the regulator is housed within the generator unit and the only external wires are the output and ground leads.
Should a capacitor be installed on the wind driven generator output lead at the generator terminal for noise suppression in addition to the original shielding requirement? If a capacitor is recommended, it must be weather resistant. Therefore, please advise on part number and source information if a capacitor is recommened.
Thanks for any input to my question and request.
Posted: Thu Apr 15, 2010 7:49 am Post subject: noise suppression |
At 09:31 AM 4/15/2010, you wrote:
| Quote: | | Installation instructions for a 12volt, 8amp wind driven generator specify shielding on the output lead with no other noise suppression requirements. |
Shielding of such leads is a pointless effort. Any
noise produced by the generator will be CONDUCTED along
its power feed wire, not electro-statically coupled to
other potential victims.
| Quote: | Electrical system schematics for later models of the aircraft, having engine driven generators, specify 0.01 microfarad capacitors on the armature and stator leads. On the wind driven generator, the regulator is housed within the generator unit and the only external wires are the output and ground leads.
Thanks for any input to my question and request. |
Try it and see. The responsible supplier will
conduct noise tests in a lab and supply
necessary noise suppression technology as
part of the product. If the as-delivered
generator didn't come with filters (and they're
not called out on installation instructions) then
an assumption follows that no filtering is
needed.
Some rudimentary flight-testing after installation
will go to proving/disproving that assumption.
Come back to this discussion with your findings
if indeed the critter turns out to be noisy.
Bob . . . [quote][b]
Posted: Thu Apr 15, 2010 8:03 am Post subject: Noise suppression |
Installation instructions for a 12volt, 8amp wind driven generator specify shielding on the output lead with no other noise suppression requirements. Electrical system schematics for later models of the aircraft, having engine driven generators, specify 0.01microfarad capacitors on the armature and stator leads. On the wind driven generator, the regulator is housed within the generator unit and the only external wires are the output and ground leads.
If a capacitor is recommened, it must be weather resistant. Therfore, please advise on part number and source information if a capacitor is recommened.
Hugh Loewenhardt
aeronca2(at)99main.com (aeronca2(at)99main.com)
restoring Fairchild 24C8C, N15076
Stonington, Ct
