dons701
Posted: Mon Mar 29, 2010 4:42 am Post subject: Nose Gear Castering Springs |
While landing the nose wheel to the ground with appropriate crosswind rudder input, I have noticed some nasty kickback through the pedals.
Has anyone added springs to the rudder pedal nose gear linkage to help with centering the wheel when landing in crosswind conditions ? If so what kind of spring pressure, length or spring rate was used ? I have seen pictures that utilized spherical rod bearings attached to the pedals, cushioned with springs on either side where the strut rods pass through. It looks like a nice improvement, but I do not know what springs were used. Any help or suggestions would be appreciated by me and many others.
Thanks, Don.
_________________ Zenith 701 #76120
Jabiru 2200A #2456 95 hours
Sensenich Wood 64-PJ-36 Prop |
lrm(at)skyhawg.com Guest
Posted: Mon Mar 29, 2010 7:14 am Post subject: Nose Gear Castering Springs |
Check my site. I don't remember how strong the springs are.
www.skyhawg.com. Larry, N1345L
dons701 wrote:
Thanks, Don.
Zenith 701 #76120
Jabiru 2200A #2456 55 hours
http://forums.matronics.com/viewtopic.php?p=292182#292182
dons701
Posted: Mon Mar 29, 2010 8:27 pm Post subject: Re: Nose Gear Castering Springs |
Hi Larry, your springs do not look very heavy. If you were to guess the pounds required to compress these springs, what would they be ? Thank You Larry. Hopefully more will respond to share their ideas.
Thanks, Don
