Phil.Perry(at)netapp.com Guest
Posted: Sat Mar 27, 2010 9:10 am Post subject: Static lines |
Getting ready to put the static lines in the tailcone before the space gets really tight.
Are most folks running the static line forward on the right or left side of the airplane? I'm trying to decide which side to install the T.
Phil
speckter(at)comcast.net Guest
Posted: Sat Mar 27, 2010 10:02 am Post subject: Static lines |
Put the T on the top equal distant from each so that any condensate will run down hill and out. Then run it to one of the sides.
Gary Specketer
40274 Flying
From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Perry, Phil
Sent: Saturday, March 27, 2010 1:07 PM
Subject: Static lines
Phil
~í²¬ރg(ӍӇqzn [quote][b]
jeff(at)westcottpress.com Guest
Posted: Sat Mar 27, 2010 10:25 am Post subject: Static lines |
I'm going up the right side as I'm pretty filled up on the left side with the fat battery wire taking up a lot of the available space
On Mar 27, 2010, at 10:07 AM, "Perry, Phil" <Phil.Perry(at)netapp.com (Phil.Perry(at)netapp.com)> wrote:
Phil ¦·›~‰í²,ÞÙÊ%¢½4ÓM4}§r‹«‰êç{(º¸ž
Kelly McMullen
Posted: Sat Mar 27, 2010 6:29 pm Post subject: Static lines |
I'm planning on running up right side, right under the right baggage
compartment cover, so it doesn't have to dip down under baggage floor.
Tee near top of tail cone, then angle down and right after passing
through a grommet in next bulkhead.
On Sat, Mar 27, 2010 at 11:12 AM, Jeff Carpenter <jeff(at)westcottpress.com> wrote:
| Quote: | I'm going up the right side as I'm pretty filled up on the left side with
On Mar 27, 2010, at 10:07 AM, "Perry, Phil" <Phil.Perry(at)netapp.com> wrote:
really tight.
Phil
¦·›~‰í²,ÞÙÊ%¢½4ÓM4}§ r‹«‰êç{ (º¸ž
A&P/IA, EAA Tech Counselor
KCHD |
hotwheels
Posted: Sun Mar 28, 2010 7:49 pm Post subject: Re: Static lines |
Left side as my dual GRT AHRS is mounted aft on that side. Dual means twice the fun in this case.
Jay
johngoodman
Posted: Mon Mar 29, 2010 8:08 am Post subject: Re: Static lines |
Plan on TWO lines - one for static going forward, and one for pitot going aft. Assuming you plan on putting your AHARS in the tail. Can't say for all of them, but my GRT AHARS is where you connect both pitot & static.
John
_________________ #40572 Phase One complete in 2011 |
n223rv(at)wolflakeairport Guest
Posted: Mon Mar 29, 2010 9:52 am Post subject: Static lines |
I have the Dynon SkyView, and you need pitot, static, and an AOA tube
going to the tailcone area. I also ran the static to the IP area for
an alternate static switch.....
On Mar 29, 2010, at 12:08 PM, "johngoodman"
<johngoodman(at)earthlink.net> wrote:
John
#40572 QB. Engine on, wing attach coming soon. Panel delivery soon.
N711JG reserved
http://forums.matronics.com/viewtopic.php?p=292228#292228
Bob Turner
Posted: Mon Mar 29, 2010 9:56 am Post subject: Re: Static lines |
Is anyone running two pitot lines? I went and installed the Van's pitot as well as a (not yet purchased) heated one on the other wing. Is there any value in using an unheated pitot on the back up instruments? (If I lose power there won't be any electricity to a heated pitot anyway, although certainly the primary instruments could fail for reasons other than power loss.)
_________________ Bob Turner
RV-10 QB |
Kelly McMullen
Posted: Mon Mar 29, 2010 12:09 pm Post subject: Static lines |
Would you share on or off list your impressions/ salient points on the
Skyview? On or off list. It is probably at the top of my list right
now, with GRT and AFS close behind. Thanks,
Kelly
On Mon, Mar 29, 2010 at 9:59 AM, Michael Kraus
<n223rv(at)wolflakeairport.net> wrote:
I have the Dynon SkyView, and you need pitot, static, and an AOA tube going
to the tailcone area. I also ran the static to the IP area for an alternate
static switch.....
On Mar 29, 2010, at 12:08 PM, "johngoodman" <johngoodman(at)earthlink.net>
> John
> N711JG reserved
KCHD |
