installing thedoor seal gasket
Fergus Kyle
PostPosted: Thu Mar 25, 2010 1:34 pm    Post subject: installing thedoor seal gasket Reply with quote
In the process of installing the gasket I have run into the very resistant qualities of this item at the sharp corners of the door. I tried tapping the “claws” onto the edge but it tries to rotate out before I can convert its bad behaviour into submission.
What did you do – especially at the corners?
Happy landings
Ferg [quote][b]
rparigoris
PostPosted: Thu Mar 25, 2010 9:01 pm    Post subject: installing thedoor seal gasket Reply with quote
Hi Ferg"In the process of installing the gasket I have run into the very resistant qualities of this item >>> What did you do - especially at the corners?"I really didn't have too much problems, I started at one end and using a piece of Oak bout 3/4" x 3/4" x 6" long pounded into position a little at a time, always forcing seal towards part that was fully in position (where you started from). In the sharp corners again always force towards where you started from so you don't undo what you just did.Ron Parigoris [quote][b]
