mtherr(at)yahoo.com Guest
Posted: Mon Apr 17, 2006 6:55 pm Post subject: Murphy's law did not apply |
Hello group!
Well, this evening, I've been lucky with some bad luck
(or more precisely, bad design).
After dinner, I decided to go flying at sunset. I
departed CSB3 at 19h30EAT and went to Mascouche
(CSK3). Then, I took position to depart from runway
11. Several seconds after applying full throttle, the
engine came back to idle and the throttle lever was
non effective. The plane started to decelerate on the
runway.
I parked it at the end of the runway, removed the
cowling and quickly noticed that my throttle lever was
disassembled. When I modified the carburetor, I cut
down the throttle lever and made a plate what would
accomodate the throttle push rod I'm using. This
plate is (or was) attached to the Carburetor throttle
arm with two A5 Avex rivets.
The plane flew more than 200 hours before the rivets
failed ant the plate detached from the throttle arm!
Should Murphy have made this happen 10 seconds later,
I,would have been in deep s..t (there are no good
options for emergency landings during a moment after
take off on that runway). But the law did not apply
and I simply had a good workout pulling the plane to a
hangar I have access to (which was near the other end
of the runway).
Here are some pictures showing that plate:
http://mthobby.pcperfect.com/ch601/images/DCP02135.JPG
http://mthobby.pcperfect.com/ch601/images/DCP02158.JPG
This being said, I would suggest looking at any
situation where a couple of rivets hold a critical
part that is subject to constant stress and vibration.
These two rivets will be replaced with two AN3 bolts
and lock nuts in the next few days!
Michel
Michel Therrien CH601-HD, C-GZGQ
http://www.zenithair.com/bldrlist/profiles/mthobby
http://pages.infinit.net/mthobby
JohnDRead(at)aol.com Guest
Posted: Mon Apr 17, 2006 7:15 pm Post subject: Murphy's law did not apply |
Hi Michel:
Were the rivets steel or aluminum?
John (soon to start building a CH710)
JohnDRead(at)AOL.COM Guest
Posted: Mon Apr 17, 2006 7:20 pm Post subject: Murphy's law did not apply |
Hi Michel:
I took look at your pictures. Why did you not weld the
modified bracket as opposed to rivets?
nfivesl(at)yahoo.com Guest
Posted: Mon Apr 17, 2006 7:27 pm Post subject: Murphy's law did not apply |
Michel that is very timely news! A few days ago I
made a similar installation on my throttle where I
installed two rivets - then, the day after I installed
it, I drilled them out and installed AN3 bolts because
it didn't feel right after sleeping on it!
It's good to hear you got a break on that one!
Scott Laughlin
--- Michel Therrien <mtherr(at)yahoo.com> wrote:
Hello group!
luck
Posted: Tue Apr 18, 2006 2:19 am Post subject: Murphy's law did not apply |
The plate is made of 6061-t6, 0.063". It would sure
be a better idea to weld a 4130 plate, but at that
time, I had no steel and no talent for welding.
I looked at my plate yesterday, no distorsion on it,
no cracks and the hole for the pushrod is still very
much round... I'll put it back in.
do not archive.
The rivets were the A5 Avex rivets that we use to
build the plane.... I know one of my friend has a
similar setup, but with AD rivets (solid rivets) and
he has not have that situation. (yet?) Seriously, I
don't think our soft pull rivets measure up with AD
solid rivets in term of resistance to fatigue and
strenght.
Michel
bill_dom(at)yahoo.com Guest
Posted: Tue Apr 18, 2006 4:33 am Post subject: Murphy's law did not apply |
I read or saw somewhere that throttle linkage need to
be installed in such way that in case of failure, the
spring should open the throttle to full position
instead of closing it. Then you will use mixture
control to reduce power and when in final for landing,
you can turn off the engine and glide to the runnway.
I thought this was common practice. Is there a reason
why not to do this?
William Dominguez
Plansbuilt Zodiac 601XL
Hello group!
luck
the
the
runway.
was
throttle
later,
a
end
of the runway).
Posted: Tue Apr 18, 2006 7:47 am Post subject: Murphy's law did not apply |
I had the same thought yesterday... I heard that Rotax
engines are designed this way (full throttle in case
of throttle failure). I'll be looking at how to
implement something similar on my installation.
Michel
PS: But all of this is temporary More on that
very soon!
--- William Dominguez <bill_dom(at)yahoo.com> wrote:
to
the
landing,
runnway.
reason
why not to do this?
William Dominguez
